Basic basic electrical question (Ohm's law)
What am I doing wrong here guys-
I have a tiny auto light bulb and want to know its wattage so I can go shopping.
It draws 120mA as measured by an in-serries ammeter at 12VDC. Ohms law says that means it is approx. a 1.44 watt bulb and its resistance is 100ohms.
But measured filiment resistance is 9.5 ohms...huh? What's wrong here?
Old 04-01-2006, 02:31 PM
Banned
Try a diffrent DVOM.
Thats all I can think of.
Old 04-01-2006, 03:00 PM
canna change law physics
red-beard's Avatar
As the wire heats and glows, the resistence goes up.
James
Red-beard for President, 2020
Old 04-01-2006, 03:55 PM
Banned
Oh yeah thats right. I forgot about that.
Old 04-01-2006, 05:24 PM
Red-beard -so it's normal that cold resistance would be that low and the 1.44W calc is OK? Thanks.
Old 04-01-2006, 05:40 PM
Banned
fastpat's Avatar
Re: Basic basic electrical question (Ohm's law)
What does the manual call for in the position the bulb goes in? You're not working on a car without a maintenance manual open are you?
Old 04-01-2006, 05:43 PM
Banned
http://www.geocities.com/SiliconValley/Circuit/1858/resiscale.htm
Yes it is normal.
I used to know that, but I never need to use some of that knowlege anymore. so you know, it gets forgotten.
Old 04-01-2006, 05:49 PM
red-beard's Avatar
The nominal wattage may be 2 watts. Where is the bulb located? The speedo/guage cluster?
James
Old 04-01-2006, 05:58 PM
red-beard's Avatar
Also remember, car are 12v nominal, 13.8V at the battery and about 15vdc when charging.
James
Old 04-01-2006, 06:00 PM
It's a bulb from the 3rd brake light array on my 993. It's a little one, and there are 20-something of them.
Old 04-01-2006, 06:08 PM
