Arched sheetrock question
Before I run off to buy a book I thought I'd hit up any experts lurking on the board. For my next DIY home project I want to arch all the lower level hallway entries. This is the look I am going for.
![]() I have 7 standard squared hallway transitions and 1 entertainment nook all with bullnosed corners that I want to convert. Here is a picture with arrows of some candidates ![]() I am planning to build arched plywood fittings (sorry for lack to technical jargon) that will screw into the existing openings. Then I would remove the existing sheetrock to the nearest vertical stud on each side and replace with a single piece cut that will accomodate my arch. I have little experience with drywall edging so I'm wondering how do I deal with the existing bullnose edging? Do I need to rip it out down to the floor and redo or can I blend my arched portion into what's already there? I want to do as much as possible myself as I'm on a limited budget (buying supplies for upcoming master bath tile job). Any suggestions would be most appreciated. Thanks
Don't worry about the drywalling, that bit is easy! The part requiring a good eye will be the mudding (plastering). Also, you will have to redo the headers above the openings. I would start by tearing out the d-wall above the opening to see what you should do to make the header. You are on the right track with the 'plywood fitttings'.
-Jeremy
'73 911 and other cool stuff |
What do you mean by bullnose corner? That usually describes a stair tread or counter top edge. Go to a building supply house (not Home Depot or Lowes) that supplies drywall to the trade. They will have pre-segmented drywall, edging, and plywood to make just about any shape that you want.
07 997 cab sold 95 993 cab sold 87 911 cab sold |
Platinum Member
If you can't find the archway bead, you can cut standard bead (one side) every inch or so. Use plastic not metal.
Since your openings are different widths, you may want to use a more gradual arch instead of half circles. Keeping the bottoms(and tops) at the same height and vary the radius usually looks better. I'll second the 1/4" sheetrock. Or score the back of 1/2" sheetrock every few inches perpendicular to the bend, and skim coat the whole arch. Set the corner beads carefully, and use a wide knife to fill in between with spackle. Use a paint mixer in an electric drill to mix the spackle and it will go on smoother.
Political polls are often to give you an opinion, not to find out what your opinion is - Scott Adams Last edited by dad911; 04-23-2006 at 03:31 PM.. |
errr, I just looked at the photo of your house again, and I would do some inspecting before you get your hopes up about that project. It looks as though there may be a beam above those openings. I don't think you've got the height to do the arches within the current opening so whether or not there is a beam there is kinda important.
-Jeremy
Attached is a picture I took in the framing stage of the entertainment nook and the entry/hallway (left & middle arrows of the original picture).
![]() I was not intending on removing what's there (d-wall) . Clearance would be a problem for a full half circle so I'm going for something less - sorry that did not come across in my original post. I was thinking of arches that start on the ends and meet near the middle. Procon - the segmented arch bead looks like a probable match. I'll have to take a look. What about the transition from the arch bullnose bead to the existing bullnose bead. Do I demo what's there and replace with a single strip (floor to arch to floor) or can I mud the transition enough to look good and not crack over time? I'm kinda lame in the sheetrock finishing dept. Great tips on using 1/4". I've walked through construction sites and seen them use that and/or 1/2" scored every couple inches. |
JW Apostate
Take some measurements. Plan ahead.
When setting up you plywood frames you need them to finish without sheet rock, the same dimension thickness as the wall framing. So, maybe 1/2 ply + 2 1/2 wood + 1/2 ply to equal 3 1/2 if it's 2x4 framing. I'd attach the 2x to the head and run the verticals down to lowest point of your arches with a taper at the bottom for the arch shape. Put the plywood on and then ad blocking every few inches along the inside of the arch. use a framing nailer or screws. Hand nailing would be a nightmare. Attach the sheetrock as a rectangle and dremel/roto-zip in place. Use the flexible round corners and let them overlap the existing corners. One layer of 1/4 sheet rock on the inside of the arches should be great. Don't rush...ask questions. KT
'74 914-6 2.6 SS #746 '01 Boxster |
Slackerous Maximus
Call.......a........contractor......
EDIT: I'm not just being a wise arse. I built out my entire basement. Framing, wiring, windows, hung doors...but I got contractors for sheet rock and trim work. Sheet rock SUCKS. Its not hanging the sheet thats the problem, its the mudding. You might get it right after a *****load of sanding, but the pros make it look to easy, and your house looks great. Those curves are not going to easy. Sorry to be a kill joy, but I'm just trying to save you grief.
2022 Royal Enfield Interceptor 2012 Harley Davidson Road King 2014 Cayman S, PDK Mercedes E350 family truckster Steam locomotive. Yes, you read that right. Last edited by HardDrive; 04-23-2006 at 11:46 PM.. |
Platinum Member
Platinum Member
If you want to build confidence before trashing your house, wood & sheetrock is cheap. Build an arch as a test, and see how it comes out before cutting into your walls. Just like I would try welding scrap metal before trying to weld my 911..... |
I really think you should make some cardboard mock ups and tape them in place, just to see if you hit your head on the sides or feel weird walking through them. Judging from your photo I wouldn't go that route if it were my house because I'm tall and so are a lot of my friends, and I have trouble walking straight most of the time, so walking straight through the arch to avoid smacking my head would be hard for me.
Sorry: I think you should make some cardboard mock ups to see if you can get the look that you want (countour and rate of arch) within the confines of the opening. I know you could make some 6"R fillets and call it an arch, but I don't think that is what you are looking for.
Thanks for the great responses. I'll mock up some cardboard arches this weekend and see how it looks.
"You go to the track with the Porsche you have, not the Porsche you wish you had." '03 E46 M3 '57 356A Various VWs |
I did this exact project in my house several years ago. I went the whole route; building a frame, scoring and bending strips of rock, cutting and installing the bead.
After lots of mud, sanding, and cursing, it came out pretty darned good. The real cursing started when a friend showed me a cataloge full of foam curves and arches that you tape in place, skin with mud and paint. That would have saved tons of time and trouble.
Jamie79SC |
A while back I was online and came across something similar but didn't bookmark the URL. Do you have any more details?
I wish I did. It was a paper catalog and I didn't keep it. I'm sure Google is your friend. A 30 second search found this: http://www.globalms.com/Arches.html - not exactly what you're after, but they might point you the right way.
Jamie79SC |
