Unregistered
Re-pipe entire house?
I just found a hot water pipe leak under the slab of my house. It's the third leak in two years. I fixed the other two myself but I'm getting tired of that.
I figure it's time to bite the bullet and either re-pipe the house or go with one of those systems that coats all the existing pipes with epoxy (no holes in walls). Any experiences? House is 3 bedroom 2 bath and was built in 1969. Any guesses what the cost will be? Tanks. |
Can you use pvc pipe in your area? If so, just plumb your fixtures from outside by removing siding and drilling holes for the pipe through the wall studs or even bury them along the house and run them up at a central location at bathroom, kitchen, etc. If you can open a glue can and push two fittings together you can handle pvc pipe. This is the cheapest fix, sometimes it begins as a temporary patch, but ends up staying because there is no problem, and if there was you could easilly access the pipes to repair them. Good luck.
Replumbed entire house two years ago due to sub-slab leaks here in Vegas. (historic distict - 43 year old house, any where else this is new construction). Plumber used Wirsbo Aquapex, a translucent plastic tubing that is "uncoiled" and much easier to work with than traditional copper pipe. Apparently has been in use in Europe for decades with "billions" of feet of plumbing installed. Very pleased with results. Reduced pipe noise, quicker hot water to faucets. Seems to be a great product.
JP
JP 86 930/4 tribute beasty 81 sc beach beater ‘55 Belair ‘40 Ford pickup |
Detached Member
What will the City of Orange permit? Do a permit if you ever want to sell. I'm guessing you have galvenized based on the year of the house. Look at the underslab versus overhead piping. When my house was repiped the underslab was abandoned and pulling the overhead piping out and using the same holes to fish new copper was not difficult. If you use copper consider the "K" commercial grade, don't use the really cheap stuff. Pick up a piece of the three grades at Home Depot and heft it and you'll see the difference.
Hugh |
Dog-faced pony soldier
Ouch, do you actually have to cut the slab to get at the piping? If so, that's a terrible design. Piping conduits are your friend for under-slab applications. If the monkeys that built the place actually laid down the pipe and poured the slab on top of it, there isn't much you can do short of abandoning the pipe and re-routing the lines or saw-cutting. If you decide to saw-cut the slab (dicey proposition), you could always add conduits for any new piping before re-pouring the portion of the slab, but at that point you're into the job for thousands - not to mention that cutting the reinforcing on an existing slab is never a great idea and should be avoided if at all possible. It's unlikely your slab is acting as a structural diapragm or anything, but it's still never a great idea and should involve consultation with an engineer or architect.
Flexible piping like PVC or thermoplastic is a good idea in an area like this because of seismic considerations (rigid metal piping will tend to spring leaks easier in a quake). PVC is a decent choice (if permitted) as it tends to have a bit more "give" to it - it's more flexible. If you use PVC, make sure they use a "tracer wire" on the piping so you (or the next guy) can find it 15 years from now. It's kind of hard to find PVC pipe with a metal detector. I'm not sure how good the spray-on type "fix-it" stuff holds up over time. It might be good or it might just be a "band aid" type fix - I'm not terribly familiar with it (I can do some checking). I suppose it can't hurt to try as a short-term fix, right? If it holds, it holds. What kind of piping do you have now anyway? Copper? Steel? It's hard to make any sort of recommendation without knowing exactly what you've got.
A car, a 911, a motorbike and a few surfboards Black Cars Matter |
UFLYICU
Same issue in my house. I re-piped during a remodel when I had all the plumbing walls open anyway. Ran the pipes through the attic with feeders down the walls.
_______________________ Racer Rix Spec911 #5 prc-racing.com |
Unregistered
JP and Zoanas, about how much did it cost? I'm trying to decide if I should have the house re-piped or keep fixing the leaks.
My house has copper piping that is about 4" under the slab. The last two times I had leaks I used my infra-red gun to locate the hot spots, then carefully dug out the grout and lifted the tiles around the hot spot. Then I rented an electric jack hammer (bosch of course) for $50 a day and jack-hammered a big hole. I dried out the system and soldered in a new section of copper pipe. total cost was around $75 per leak and 12 hours of hard labor. of course that price included beer. Unfortunately the problem keeps coming back in different areas so I figure all the hot water pipes (and maybe the cold too) are ready to go. I found very small pin hole leaks in the piping I cut out with green corrosion around the pin holes. I'm told that is typical in this area. Here's a picture of the last time: ![]() I was lucky that time because I only had to pull up two tiles. This leak is under the bathroom, about 10 feet away. |
Unregistered
Here's the tool of choice and the floor before I cleaned everything up:
"Now, to put a water-cooled engine in the rear and to have a radiator in the front, that's not very intelligent." -Ferry Porsche (PANO, Oct. '73) (I, Paul D. have loved this quote since 1973. It will remain as long as I post here.) |
Registered Cruiser
Go with the epoxy coating. A friend who owns a large plumbing company brought this technology over from Europe about 7 years ago. It has been used in Europe for nearly 25 years with great success. It costs less than 25% of a conventional repipe and can repair a 2" hole in a 4" pipe. I have a 50 year old building with 13 suites that is going to be done in the fall. They bring a compressor on-site, turn off the water, scope the pipes, blast air through the lines to dry them and then coat the inside of the pipe. This can be done by one guy in one day. The coating is very thin and doesn't significantly reduce the inside pipe diameter. It is totally non-invasive and is guaranteed for at least 10 years. Tenants aren't displaced and drywall is left intact.
87' Carmine Red Carrera - Keeper 82' Silver SC - Sold 79' Gran Prix White SC - Sold 05' Black C2S - Daily driver I have never really completely understood anything. |
Unregistered
The problem with the epoxy is cost. I was told it would be between $7500 and $8000 for my 3 bedroom 2 bath single story house.
I figure that is waaaaay too much money for one day's labor. I have a guy coming over this afternoon to give me a firm quote, if it's in the same price range as I got on the phone I will say thank you and good day to him. |
Where did you buy your tile at sammyg2 ? I have the exact same tile in my house.
Bill MID9 #4 if i cant play with it ,,i dont want to own it |
Unregistered
IIRC we got it at a tile and flooring store in the city of Brea. Can't remember the name but it is a small independant store.
The wife brought home about a zillion different samples until she finally decided on that one. i told her we could time the entire house with just the samples like a collage. She didn't think it was funny. |
Funny, because Home Dept carries the same thing. Same here, the wife picked it out.
Registered Cruiser
"....I was told it would be between $7500 and $8000 for my 3 bedroom 2 bath single story house."
Your right that is way too much. I was quoted less than 10K to do my whole building.
Cost was around $5000.00 for 4 bed 4 bath, 4500 square foot house. This included hose bibs, stucco and drywall repair. Expensive, but the peace of mind was worth it.
I believe that home depot does carry aquapex at this time. JPh
Unregistered
The sales guy from the pipe coating place just left, he came down to $6200 after I told him that i would not spend $7500 on his process as soon as he came in the door.
Need to do a little more research and weigh the options...................... |
Friend of Warren
I think you need to figure out the source of the problem. Certain soils can aggressively corrode copper pipe. I suspect that is your problem. As the corrosion is happening from the outside in I am not sure epoxy coating the inside of the pipes is going to help. I would replumb the entire house.
Kurt V No more Porsches, but a revolving number of motorcycles. |
Unregistered
The corrosion is not happening from the outside. On the two pieces of pipes i removed, both had green corrosion built up on the inside around a small pinhole leak which had all indications of leaking from the inside out.
Thread Tools | |
Rate This Thread | |
