The Cuddly One
ring removal
I "borrowed" one of my daughters rings a few days ago and now I can't get it off.
I'd rather not cut it and I've tried soap and water, cold water and I've just got a swollen finger for my trouble. HELP!!!! Any ideas?
-Isa 911E 3.0 (Tristezza, the Rattus Maximus) and Jimmy the Mini lll Dum vivimus, vivamus! Man braucht nicht reparieren was funktioniert! |
dish soap, no water
poof! gone |
Gon fix it with me hammer
find a pickpocketing gippo.
Stijn Vandamme EX911STARGA73EX92477EX94484EX944S8890MPHPINBALLMACHINEAKAEX987C2007 BIMDIESELBMW116D2019 |
Dept store Quartermaster
Soak it in cider
Cornpoppin' Pony Soldier |
I'm with Bill
Buy the daughter a new one and thank her for your new ring.
Try some handcleaner like Go-Jo
Electrical problems on a pick-up will do that to a guy- 1990C4S |
or find a yakuza...
I'm with Bill
I am Rick V's wife.
Try using an ice pack to reduce the swelling, and a lubricant of your choice. Beth V
I'm with Bill
I'm with Bill
For some reason it didn't go so I'll try again.
This is Beth and no you get no more pics! ![]()
Banned
Keep your hand in the upright position (like you're waving) for a while to let the blood drain, along with the ice and dish soap.
Good luck. |
D idn't E arn I t
Makita grinder or a really stout set of bolt cutters.
rjp
In the movies only bad guys sleep in king size beds. |
canna change law physics
Soak the hand in water with Epsom Salts which will get the swelling down, along with ice. You might also take an Anti-inflammatory drug to reduce the swelling in the knuckle.
James The pessimist complains about the wind; the optimist expects it to change; the engineer adjusts the sails.- William Arthur Ward (1921-1994) Red-beard for President, 2020 |
If it is stuck at the knuckle- try the above and good luck.
If it is stuck due to the swelling take a long thin piece of string or thread- monofilament works as well. Double it up and slowly wrap it- pretty tight- from the finger tip down- tight enough to compress the finger. As you get down to the ring, pass the two ends under the ring. Then try wiggling it off. I have heard of this working. Good luck. If all else fails most rings can be repaired after being cut with a ring cutter. Gary |
In the shop at Pelican
hacksaw
The Cuddly One
Thanks guys, I got it off.
And for those who suggested Hacksaws and boltcutters - I had no intention of cutting my finger off to get the ring off
