LinkBack Thread Tools Rating: Thread Rating: 1 votes, 3.00 average.
Targa, Panamera Turbo
M.D. Holloway's Avatar
What The HE!! is a HTTP+Proxy and Why Do I Keep Getting This Message?
I ran my spyware and even booted up in safe mode but I still get this message. My IT people are of no help and frankly I think I have been infected with the computo version of the freak'n bird flu!
So, you bunch IT slackdaddies and keybored scallywags have any idea what the heck this is and what I should do about it?
Michael D. Holloway
https://5thorderindustry.com/
Old 06-20-2006, 02:01 PM
canna change law physics
red-beard's Avatar
Are you supposed to be using a proxy server from work?
James
Red-beard for President, 2020
Old 06-20-2006, 02:13 PM
Gon fix it with me hammer
svandamme's Avatar
a proxy server is a gateway , usually used in work places , so instead of users roaming the internet directly , it goes through hte proxy
it caches content but also allows for filtering, and monitoring...
Stijn Vandamme
BIMDIESELBMW116D2019
Old 06-20-2006, 02:53 PM
svandamme's Avatar
check IE options
connections
LAN settings
uncheck proxy if enabled ( at least if you know you ain't need one)
Stijn Vandamme
Old 06-20-2006, 02:55 PM
I use the Proxy Server when at work and disable when wireless at home. It has been enabld and working fine here.
Michael D. Holloway
Old 06-20-2006, 02:58 PM
svandamme's Avatar
so , how do you get online if you get that error? other computer??
Stijn Vandamme
Old 06-20-2006, 03:01 PM
Slackerous Maximus
HardDrive's Avatar
Are you trying to access the internet from home or at the office?
2014 Cayman S, PDK
Old 06-20-2006, 03:07 PM
I'm at work. In the Internet Properties, I have checked off the selct proxy server. I know that in the past wneh I disable it I am unable to get on-line. I am proxy enabled.
Michael D. Holloway
Old 06-20-2006, 03:28 PM
svandamme's Avatar
but when do you see the error?? at work or at home?
the point is , if you see that error , does it affect your surfing or not??
what does it affect, and when does it do so??
Stijn Vandamme
Old 06-20-2006, 03:34 PM
84porsche's Avatar
Send a message via Yahoo to 84porsche
Do you have a user account/password for your work log in? If so, if you enter this , does it let you access the internet. Maybe someone changed the proxy settings recently to require authentication.
Modes of Transportation:
1984 Porsche 911 Targa
2003 VW Jetta GLI
Old 06-20-2006, 06:54 PM
If usirvisa01.nch.com:80 is the correct server, then it could just be either that a saved password is no longer saved and needs to be retyped or as 84p suggests maybe it didn't require auth before and now it does. I've worked places where it didn't require a password and other places where it did. The other idea that pops into my head is that often the proxy password is passed from the OS because it's the same as the domain login. Are you properly logging into the domain?
Old 06-20-2006, 07:15 PM
Slackerous Maximus
HardDrive's Avatar
I think maraum is right.
Your proxy server requires you autheticate before you are allowed to surf.
What is strange is that if you have already logged in, you should not have to reenter your credentials.
2014 Cayman S, PDK
Old 06-20-2006, 09:14 PM
The message only pops up when I am at work - I have no problems on-line or anything else. This message just pops up every so often. I click cancle and it goes away for awhile.
Michael D. Holloway
Old 06-20-2006, 09:27 PM
Slackerous Maximus
HardDrive's Avatar
I think your IT folks are full of baloney. I think they were allowing anonymous internet usage, and now they want to lock things down, or do auditing so they can see who is surfing what, so they changed the proxy to require authetication.
Either way though, if you are successfully logging into the network, it should not be prompting you for credentials.
Sorry were are all being so vague, but we need all sorts of details if you want a real answer.
What operating system are you running and what service packs are installed?
What is the proxy product?
Do you run any third party firewall software?
2014 Cayman S, PDK
Old 06-20-2006, 10:28 PM
