Digital Camera Help
All of a sudden, Windows XP doesn't recognize my Olympus IR 300 camera. Always did before, and auto ran camera and scanner wizard.
Still sees it, but only as a removeable storage device. WTF did I do now?
Howard 73 914 2.0 'Suzi' 73 914 5.0 'Moby' 99 996 Tip Cpe 'Dietrich' www.thehowardagency.com http://www.youtube.com/watch?v=bOY2x-Uh6cU |
Maybe not as simple as this, but mine does the same thing..unless I make sure I turn the camera on after hooking it up. If I turn it on before hooking it up, it won't recognize it. Hope this helps.
78 SC Targa Black....gone 84 Carrera Targa White 98 Honda Prelude 22 Honda Civic SI |
howard clear your screen so only icons appear. plug camera in. turn camera on. puter should start making noise(scary) and wa-la screen should pop up showing pics being downloaded. make sure camera batteries are new or charged fully. hope that helps.
Interesting. Two choices on the camera screen when attached to USB, 'PC' or 'Print'. Select PC=Storage device, select 'Print' and wizard starts. When using print, I can't delete pix from camera (with windows).
Plug and Pray. Thanks guys.
You do not have permissi
Double check control panel/system/device manager for the device also(?). Nothing should have changed it as default.
Meanwhile other things are still happening. |
since i have a 2 story house and a pool below......................at this point, my camera and computer would be sailing over upstairs wall into the ...................ABYSS! kersplash!
has anyone been on your computer since the last time you were on? my kids USED to crash me all the time. now NOBODY screws w/my puter................nobody! i found that going direct off of my camera vs card reader always worked. card reader was finicky. it was a 6 in 1 reader..................kersplash! |
Detached Member
No solution to why it happened, but right click on "Start" and use explore to see if you can find the external drive (E) usuallly and see if you can open your pics and copy to your hard drive.
Hugh |
