Mac help please...
I have been traveling for a while with my G4 and have been backing up important data religiously onto a 1GB memory stick.
When I tried to do this today all I get is a screen that says: "Disk Insertion The disk you inserted was not readable by this computer." The screen then gives three options: "Initialize Ignore Eject" I clicked the latter two without success. (The memory stick icon does not appear.) I will not click the first one for fear of deleting everything from the memory stick. The memory stick is far from full, and I have been using it every day for several months without any problem. The data that is on it is very important. Any suggestions on what has gone wrong or what I should do would be much appreciated.
_____________________ These are my principles. If you don't like them, I have others.—Groucho Marx |
you can try running disk utility, then inserting the drive, then seeing if disk utility can mount it and/or fix it.
Free minder
Has the stick been in a PC, by any chance?
Aurel
1978 SC Targa, DC15 cams, 9.3:1 cr, backdated heat, sport exhaust https://1978sctarga.car.blog/ 2014 Cayenne platinum edition 2008 Benz C300 (wife’s) 2010 Honda Civic LX (daughter’s) |
The Unsettler
Being in a PC should not affect, I regularly move files from a PC to my Mac using thumb drives. Unless of course said PC had a disc erasing virus on it.
I would actually try sticking it in a PC and see if it mounts. If not and Disc Utility does not help then you need a recovery utility. I have one so if there is nothing sensitive on the drive and you want to send it to me as a last resort I'll see what I can recover. I owe the Vancouver contingent a favor. Scott
"I want my two dollars" "Goodbye and thanks for the fish" "Proud Member and Supporter of the YWL" "Brandon Won" |
