problem with my benz.
Hello,
I'm having a little trouble with my 1982 240D. Sometimes when I start my car, drive it and then turn it off - it does turn off. When this happens, the car doesn't really shift or at least until the redline. Also, the brake pedal gets really stiff. Where do you think I should look to fix this one? Thanks.
We can share the women, we can share the wine - Jack Straw. 1970 911t w/3.0 1971 914 w/2.0 1987 300E |
Gon fix it with me hammer
automatic?
Stijn Vandamme EX911STARGA73EX92477EX94484EX944S8890MPHPINBALLMACHINEAKAEX987C2007 BIMDIESELBMW116D2019 |
pm'ed you
Mike |
S - yes, automatic.
MP - got the PM - thanks.
dunno how benzes work, but i'm thinking a hydraulic link between teh two (tranny / brake system ) and a leak somewhere...
Banned
The problem is a vacuum leak, somewhere in the system. (one of the door locks is likely leaking.)
The fuel shut-off (engine shut-off) is vacuum actuatated. To manually shut off the engine, open the hood, and push the lever which reads "STOP." Last edited by Saab Pilot; 10-01-2006 at 10:31 AM.. |
vacuum line from cruise computer to injection pump
Unconstitutional Patriot
vacuum leak. You need a vacuum gauge, like a Mityvac. You will either have a failed vacuum pump (can possibly be rebuilt), or you have a leak in one of the lines or fittings. You need to isolate each line and test for leaks, and you can check the vacuum pump while the engine is running.
Thanks fellas.
Any ideas on where the best place to start looking for the leak might be? It seems like there's a 'black hose' that might be the source of the leak. Come to think of it, when I manually turn the car off, I do hear the hissing of a leak. The heat coming from the engine makes me reluctant to chase it down at that time though (I do like my fingerprints - haha). Thanks again.
