Registered Loser
One-off W9 motor built as a thesis project. INSANE
Here is the website...
http://www.atomracing.se/6M.html
Owner of a wrecked 944
Old 02-12-2007, 11:30 AM
Banned
fastpat's Avatar
That's a stunningly beautiful piece of industrial art. Thanks.
Old 02-12-2007, 11:51 AM
"Max power (est.): 526 hp@ 10700 rpm (bmep: 14,6 bar ; 211 psi), dimensioned for Tri-Turbo 1005 hp" from a 2.7L! Would love to hear it run.
For a MS thesis project, someone has a deep pockets or really good finding.
gary
Old 02-12-2007, 12:04 PM
Zeke's Avatar
Now that I would put in the back of a 911.
Old 02-12-2007, 04:45 PM
Monkey+Football
Icemaster's Avatar
Send a message via AIM to Icemaster
Not sure it would fit.
Nontheless, wow.
<Insert witty comment>
85 Targa Wong Chip Fabspeed M&K Bilsteins and a bunch of other stuff.
Old 02-12-2007, 05:05 PM
Detached Member
Hugh R's Avatar
Stunning! I'd love to see how it actually works.
Hugh
Old 02-12-2007, 05:40 PM
Banned
fastpat's Avatar
I'd love to hear it run, nine cylinders must make some kind of music as they pass through 8k looking for 10k.
Old 02-12-2007, 06:21 PM
SanDiegoDon
Guest
Posts: n/a
+1
Old 02-12-2007, 06:38 PM
Cars & Coffee Killer
legion's Avatar
I used to own a 5 cylinder MB 300D.
To this day, if there is a 5 cyl. MB within a half mile, I can pick it out.
I'd imagine that a 9 cyl. engine would have a similarly distinct sound.
5 liters of VVT fury now
-Chris
Old 02-12-2007, 06:45 PM
Interesting engine.
With the 60-0-60 layout, it seems the firing order is not evenly spaced.
That is 6 of the cylinders would fire 240 crankshaft degrees apart, the outside cylinders. The 3 center cylinders would fire between every two outside cylinders, giving an uneven pulse.
That is, said another way, at 0, 60, 120, 240, 300, 360 480, 540 & 600 crankshaft degrees.
One outside bank firing at 0, 240 & 480 degrees.
The other outside bank firing at 120, 360 & 600 degrees.
The center bank interspersed at 60, 300 & 540 degrees.
Leaving gaps at 180, 420 & 660 degrees.
Am I missing something?
DOUG
'76 911S 2.7, webers, solex cams, JE pistons, '74 exhaust, 23 & 28 torsion bars, 930 calipers & rotors, Hoosiers on 8's & 9's.
'85 911 Carrera, stock, just painted, Orient Red
Old 02-15-2007, 10:41 PM
Senior Member
I want to hear it run... sure looks nice.
Old 02-16-2007, 12:25 AM
beepbeep's Avatar
The guy is from Luleå. That explains it. Too much snow and too little to do.
Thank you for your time,
Old 02-16-2007, 05:47 AM
Gon fix it with me hammer
svandamme's Avatar
speaking of which , whatever happend to Project Lumina??
Stijn Vandamme
BIMDIESELBMW116D2019
Old 02-16-2007, 06:14 AM
beepbeep's Avatar
Mattias became father so he wanted to get rid of the car. I just bought a flat so I didn't have the time to finish it. I still have some bits and parts over so I just need to settle down before diving into car project again.
Old 02-16-2007, 06:22 AM
1967 R50/2's Avatar
3/8ths of a radial engine.
1967 R50/2
Old 02-16-2007, 08:27 AM
Targa, Panamera Turbo
M.D. Holloway's Avatar
Janus, that is too cool! That kid must have some deep pockets or access to some serious equipment. I have to think it was heavily funded by an auto maker.
It got me wondering and thinking about other W engines. Here is one from VW. Some of you may have seen it. It is in production. Here is the site: www.seriouswheels.com/cars/top-VW-W12-Roadster.htm
a W12! Janus thanks agian for making me wonder!
Michael D. Holloway
https://5thorderindustry.com/
Old 02-16-2007, 08:35 AM
opps...here is the engine in:
Michael D. Holloway
Old 02-16-2007, 08:36 AM
Michael D. Holloway
Old 02-16-2007, 08:38 AM
Banned
fastpat's Avatar
That engine is quite a bit different in that is is a "Double V" engine instead of a "W" engine. Each of what appears to be a bank is in reality a V-6 with only 15 deg. between each bank, with a common head. Interesting layout. And, the article says there's a "Double V" 16 cylinder model as well. The mind boggles.
Old 02-16-2007, 08:46 AM
Bill is Dead.
cashflyer's Avatar
I've run plenty of 9 cylinder engines.
But they were all round.
Old 02-16-2007, 02:13 PM
