TerryBPP's Avatar
Do I need a 1/2 ton or 3/4 ton?
I am considering buying a 2003 22' Sea Ray Cabin Crusier and I need to pick out a truck to tow it with. I'm looking at Dodge Rams and I'm not sure if a Ram 1500 will tow that much boat with ease. Do I need to bump up to a 2500? I'm not biased as to which brand the truck is so same applies to F150/250 & Chevy 1500/2500.
The ramp we kick off at is pretty steep so I want it to be effortless.
Any experience?
Old 04-26-2007, 12:55 PM
It depends.
How often are you going to be hauling this thing?
You may want to rent an old duelie wheel box van from rent-a-wreck and save the monthly payment.
Old 04-26-2007, 01:28 PM
TerryBPP's Avatar
We are pretty frequent boaters. You can pick up a decent used truck for $10k so i won't be making payments.
Old 04-26-2007, 01:33 PM
chapo's Avatar
Go 3/4. A half ton could pull it, but the added safety with the 3/4's larger brakes and suspension are worth it. Plus, most of the larger trucks already have a nice frame mounted hitch installed.
Patrick
Old 04-26-2007, 02:05 PM
I have a 3/4 ton which I use for towing my car to the track. It is a 2000 Chevy work truck--paid around $9,000. Larger rear brakes vs. half ton. Suspension and brakes would be the two major differences. I have towed with my 2005 Tahoe and I prefer the 3/4 ton. The Tahoe works fine but the 3/4 ton feels safer driving--if that makes any sense. Personally, if I was towing a 22' boat, I would try to locate a 3/4 ton. Also, make sure you find a vehicle with a transmission cooler. My 2 cents.
2011 Cayman Speed Yellow
1988 924S (Sold) 2000 Boxster S (Sold)
2006 Cayman S (Sold) 1990 964 C2 (Sold)
1978 911 SC (Sold)
Old 04-26-2007, 02:06 PM
Z-man's Avatar
How much does the boat & trailer combined weigh? And how much stuff would you be packing in the pickup?
-Z
2010 Cayman S - 12-2020 -
2014 MINI Cooper S Coupe - 05-17 - 05-21
1989 944S2 - 06-01 - 01-14
Carpe Viam.
Old 04-26-2007, 02:34 PM
JOT MON ABBR OTH
Groesbeck Hurricane's Avatar
Without know more than you give, I'd say a 3/4 tonne, but a heavy 1/2 might easily do the job. How much weight are you planning to pull? I don't know how much those boats weigh...
Limited slip differential. Can't stress it enough!!! 3.73 rear end, 4.10 will give great towing, horrible fuel consumption.
'83 SC Targa (sold ) MANLY babyblue honda '00 F250 7.3L (MINE!)
'15 F250 Gas (Her Baby) '95 993 (sold )
I don't take scalps. I'm civilized like white man now, I shoot man in back.
Old 04-26-2007, 04:33 PM
Parrothead member
VINMAN's Avatar
A 1500 will tow that with no problem. But if you plan on towing it any kind of long distance, the 2500 will be a little more stable on the highway. Also are u planning on a regular cab, or extended cab? The longer wheelbase on the extra cab will add to the stabilty
Vinny
Old 04-26-2007, 05:22 PM
pwd72s's Avatar
All good advice. Also, 3/4 tons usually have heavier duty wheel bearings than the 1/2 tons...so, it's more than pulling power, springs, and brakes. Definitely a +1 here on the trans cooler advice. It easy to go too light on a tow vehicle choice, hard to go too heavy.
Old 04-26-2007, 05:28 PM
Southern Class & Sass
Dixie's Avatar
Pick anything but a Dodge. Dodge has the worst build quality known to mankind.
Dixie
Bradenton, FL
2013 Camaro ZL1
Old 04-26-2007, 06:11 PM
Jim Bremner's Avatar
If you've ever under bought anything before you'll buy a 3/4 truck now!
and I can't say enough about my cheby truck. My Dad, a long time ford guy says his next truck will be a cheby
Old 04-26-2007, 06:16 PM
Re: Do I need a 1/2 ton or 3/4 ton?
Originally posted by TerryBPP
I am considering buying a 2003 22' Sea Ray Cabin Crusier ...
Any experience?
That size boat combined with steep, and WET boat ramps make a 3/4 ton almost mandatory imo... while a 1/2 'might' work don't even think about it...
Old 04-27-2007, 05:22 AM
Parrothead member
VINMAN's Avatar
I beg to differ.... Ive always been a long time Ford person, Ive owned 6 ford trucks From a BroncoII up to a crew-cab F350.
My Dodge Ram 3500 It probably one of the best vehicles Ive owned. There is absolutely nothing wrong with its build quality. The truck is a tank.
Vinny
Old 04-27-2007, 05:26 AM
I concur Vinny, I've got a beater Ram 250 w/ 180K still going strong...
Old 04-27-2007, 05:38 AM
Control Group
Tobra's Avatar
Get a 3/4 ton, Chevy or Ford. These guys saying Dodge trucks are okay have just been lucky enough not to have problems with the brakes, or front end, or transmission that I heard about nearly every day when I lived in Texas.
If it does not have trans/diff cooler install one. If it has an 4 sp auto, tow in 3rd.
Old 04-27-2007, 07:13 AM
Parrothead member
VINMAN's Avatar
Every brand of vehicle has its problems.
Vinny
Old 04-27-2007, 08:09 AM
pwd72s's Avatar
Only a 1/2 ton...
Old 04-27-2007, 09:51 AM
Team California
speeder's Avatar
What you want is a Ford with the Dodge engine (Cummins) and the Chevy trans (Allison).
Denis
Old 04-27-2007, 12:00 PM
Unregistered
sammyg2's Avatar
Toyota tundra dual cab 5.7 liter with tow package. More that you will ever need and confortable and fun to drive to boot. If you're gonna get a truck, you might as well get a good one.
I know better that to buy a chrysler product and would rather walk than drive a ford. I'm allergic to having a POS break down on me and leave me stranded. I'm also not fond of having little bits and pieces of plastic fall off while I'm driving.
Old 04-27-2007, 02:53 PM
Hell Belcho
Nostril Cheese's Avatar
I'd have to second on the Dodge build quality
my uncle had a 2006 Ram 1500 with the 4.7L V-8
at 22K it needed new valve lifters
transmission went at 30k
he traded it in for a Toyota and hasnt had a problem since
Old 04-27-2007, 03:21 PM
