Targa, Panamera Turbo
M.D. Holloway's Avatar
Engineering / Physics Teaser Question on Gyroscopic Motion
A physicist played a prank on his friend by placing a large spinning wheel inside a suitcase. He asked his friend to go to the next room and bring back the suitcase. His friend picked up the handle of the case in his left hand, unaware that the wheel was spinning inside in a counterclockwise motion, with the top of the wheel moving towards the front of the case. What happened to the case when his friend exited the room and made a left-hand turn?
Michael D. Holloway
https://5thorderindustry.com/
Old 05-17-2007, 08:18 AM
Kantry Member
oldE's Avatar
He tripped over the case.
Les
Best
Les
Old 05-17-2007, 08:43 AM
Tree-Hugging Member
Jim727's Avatar
Well, Mr. Wizard....
Assuming the axis of the gyroscope is horizontal and rigidly fixed to the inside of the suitcase, the suitcase would attempt to rotate clockwise wrt the guy carrying it. At least if I remember my right-hand-rule correctly.
Politicians should be compelled to wear uniforms like NASCAR drivers, so we could identify their owners.
Old 05-17-2007, 08:48 AM
Un Chien Andalusia
Aerkuld's Avatar
If I'm thinking about this correctly the rotating flywheel would attempt to rotate clockwise along a horizontal axis when viewed from behind. The combined action of the rotation about the vertical axis and the flywheels reactive rotation would cause the top rear corner of the suitcase to move towards the carrier and the bottom front corner of the suitcase to move away, effectively causing a rotation around a roughly diagonal axis.
2002 996 Carrera - Seal Grey (Daily Driver / Track Car)
1964 Morris Mini - Former Finnish Rally Car
1987 911 Carrera Coupe - Carmine Red - SOLD :-(
1998 986 Boxster - Black - SOLD
1984 944 - Red - SOLD
GO DAWG GO's Avatar
The gyroscopic effect would only stabilize the suitcase and maintain the heading or orientation of the wheel and limit translation.. If the carrier turned the suitcase would not eccelerate in the vector it would continue in its present processive course. That is if the rotational axis is horizontal.
If I understand your scenerio correctly.
1 bad 930
Old 05-17-2007, 09:14 AM
Rick Lee's Avatar
If it's inside the case, it can't be seen and so Heisenberg's Uncertainty Princ. kicks in. Shining light on it (opening the case) would affect the movement. So there's no way to know to really know what happens. Sort of like a tree falling with no one around to hear it.
2022 BMW 530i
2021 MB GLA250
2020 BMW R1250GS
Old 05-17-2007, 09:22 AM
GO DAWG GO's Avatar
After reading the question again..I completely agree with oldE. He is absolutely right. even if the wheel was spinning the opposite direction. The suit case would trip the guy....
1 bad 930
Un Chien Andalusia
Aerkuld's Avatar
I think you have to assume that the person carrying the case does try to rotate it about it's vertical axis.
I'm thinking about the way you lean a motorcyle into a corner by turning the steering in the opposite direction to the turn of the corner.
Old 05-17-2007, 09:48 AM
Bill is Dead.
cashflyer's Avatar
Torque-induced gyroscopic precession will cause the case to pitch perpendicular to the rotational axis, about 90 degrees forward of the point of induced torque.
Old 05-17-2007, 10:18 AM
Un Chien Andalusia
Aerkuld's Avatar
I agree. What your saying is that the spinning flywheel will produce a rotation at 90 degrees to the original input rotation and 90 degrees to the axis of rotation of the flywheel. But do you not then get a resultant rotation that is a combination of the intended rotation and the torque induced rotation?
Old 05-17-2007, 10:30 AM
GO DAWG GO's Avatar
Cashflyer, The rotational ecceleration are very limited....Your right if they are ~2+ G eccelerations. The component of torque would be negligable
THUS... Tripping the guy!
1 bad 930
Old 05-17-2007, 10:32 AM
Bill is Dead.
cashflyer's Avatar
Hey... I only know helicopter blades, not suitcases. That requires a whole different field of study.
Old 05-17-2007, 10:35 AM
Un Chien Andalusia
Aerkuld's Avatar
To answer my own question - NO.
Old 05-17-2007, 10:37 AM
Cars & Coffee Killer
legion's Avatar
Is this another thread where Lubey is never really going to give us the answer?
5 liters of VVT fury now
-Chris
Old 05-17-2007, 10:48 AM
Dog-faced pony soldier
Porsche-O-Phile's Avatar
My guess is that the gyroscope did not stay rotating once the case was closed due to improper lubrication by an inferior grade of industrial lubricant.
Black Cars Matter
Old 05-17-2007, 01:43 PM
Ok, here goes...
The case pivoted top over bottom due to gyroscopic motion. The top of the case rotated sideways towards his friend's leg while the bottom of the case rotated upwards, away from him. Gyroscopic motion is fairly complicated, but can be explained by picturing the spinning wheel as a square ring with a heavy fluid flowing through it. As the friend turns left, the fluid flowing in a vertical (up or down) motion does not change direction. The fluid flowing horizontally, does change direction as the case is turned. A portion of the fluid that is flowing vertically (up or down) is forced to travel in a curve as the friend turns left. This exerts a force on the side of the case, forcing the bottom to lift away from the friend and the top to rotate towards him. The resulting motion of the rotating wheel is exactly the same as the fluid flowing through the square ring.
Michael D. Holloway
Old 05-17-2007, 01:47 PM
I always did like the way you thought!
Michael D. Holloway
Old 05-17-2007, 01:51 PM
Seldom Seen Member
Burnin' oil's Avatar
Very small rocks?
Why do things that happen to white trash always happen to me?
Got nachos?
Tree-Hugging Member
Jim727's Avatar
Originally posted by LubeMaster77
Ok, here goes...
Clockwise. TaDaaaaaaa!
Old 05-17-2007, 01:55 PM
Hey ya'll watch this
Hoots's Avatar
You could have just said oldE was correct.
Hoots
Midvale School for the Gifted
Class of 1990.
Old 05-17-2007, 03:11 PM
