notfarnow's Avatar
kit car questions
Here's something that perplexes me.
Why aren't there tube frame kits available for 914s? Basically, take the suspension & running gear from a rusty donor car, and swap it into a tube frame. Rusty but driveable 914s are around for ~$2000
I think that would make a fantanstic base for a mid-engined sports car or kit car. Imagine a speedster body, or 904, or anything else. Plus, there are so many engine swap options. 911, subaru, SBC...
I see complete dune buggy tube frames for ~$1000, would it really be that much more complex to build a tube frame for a 914?
I've seen plenty of custom built 914 tube frames online, but no plans, kits or complete chassis seem to be available.
Even a kit that allowed you to reinforce a cut down tub would be great. Something like this:
A complete tube frame would be even better.
'03 Carrera 4s
+ a whole bunch of boats
Old 05-18-2007, 09:21 AM
Gon fix it with me hammer
svandamme's Avatar
kit cars tend to be stuff that's to expensive to buy
904's , 550's, 917's
914's are pretty much very cheap and plenty available
so anybody who want's one , can get one for a lot less money then a kit would cost
just check the Caterham webpage for pricing and you'll know what i mean...
besides, it wouldn't be a 914, it would be replicrap that isn't a real Porsche, sure , light and fast, but it wouldn't even be allowed in many of the classes that 914's now race in...
Stijn Vandamme
BIMDIESELBMW116D2019
Old 05-18-2007, 09:26 AM
notfarnow's Avatar
I'm not talking about having a "kit car" of a 914, I'm talking about using 914 suspension & drivetrain as a basis for a car. Surely that would be a step up from a VW pan under a speedster kit.
Don't think replicrap, think low buck ariel atom
'03 Carrera 4s
Old 05-18-2007, 09:29 AM
svandamme's Avatar
not all kit cars are based on an existing chassis
cat-7's aren't
even if you use a 914 engine , drivetrain and suspension geometry
if you don't chop a real 914 chassis, it's not a 914 but a 914 based kit car
if you do chop a 914 chassis, it's not a kit car, but a 914 modification kit
i doubt there's a bit market for either, which would only make the cost even higher in order to make it profitable
and as long as it's not based on a real chassis, it's replicrap to me... no Porsche vin.
imho why make an atom look like a 914
get an atom if that's what you want
if you want a 914, get a 914...
but that's just me
Stijn Vandamme
Old 05-18-2007, 09:37 AM
notfarnow's Avatar
but that's just me
I wouldn't make anything look like a 914, I'd ditch the body.
Maybe a fiberglass 356 body, or no body at all
'03 Carrera 4s
Old 05-18-2007, 09:54 AM
svandamme's Avatar
then why use a 914 chasis?
or anything else 914 based ????
there's enough 356 kit cars out allready,
and i'm sure there's tubeframe stuff to be found too
why would they base anything on a 914 chassis if there are so much more VW chassis to work with
there are hot kit's out there that only retain the VW chassis to have a vin to use for registration.... a 914 would cost so much more and if just hte vin is used, what's the point in doing it on a 914 ??
Stijn Vandamme
Old 05-18-2007, 10:03 AM
boba's Avatar
[i]
Maybe a fiberglass 356 body, or no body at all [/B]
Done, next.
notfarnow's Avatar
-mid engined
-lots of engine swap options
-inexpensive
-good suspension
Boba, I've seen pictures of that car before, but didn't realize it was 914 based. Neat stuff!
'03 Carrera 4s
Old 05-18-2007, 10:29 AM
svandamme's Avatar
but you're talking about a tube frame
you can midengine all you want if you want a tube frame
all you do is get the tranny and then anything you want
i'm sure there are kits out there that do just that, but not 914 based because that's not inexpensive at all compared to the alternatives
just look up the PGO speedster
tubeframed
mid engined
Peugeot GTi engine..
Stijn Vandamme
Old 05-18-2007, 10:35 AM
notfarnow's Avatar
Now I'm going to have to buy a 914 and do it on my own, just because you're pissin' me off
'03 Carrera 4s
Old 05-18-2007, 10:44 AM
svandamme's Avatar
hey man , i'm just trying to explain what is "perplexing" you
it's economics and practicality, pure and simple
Stijn Vandamme
Old 05-18-2007, 10:47 AM
RallyJon's Avatar
I think when choosing donor parts for a kit car, having lots of swap and upgrade options defeats the purpose. Lemme get this straight, I can use the suspension, brakes, engine and transmission from a 914. But then I have to upgrade the the suspension and brakes and swap the engine? How about if I just use the transmission? But it would probably be better to use a newer, stronger 'box, or else spends thousands upgrading it.
How about instead you start with a 914 shell and swap in double wishbones, brakes, a modern engine and a gearbox that shifts? Maybe from a Honda donor.
993 · 911 · STI · S4 · rally car
Old 05-18-2007, 11:21 AM
Laneco's Avatar
Actually, there are more tube frame rear engined speedster kit cars than there are pan based ones (at this time).
If you build a 550 spyder, they are already tube frame for mid-engine. Here's an affordable way to build a really cool one:
Take a rusted out 914, use the suspension, steering, steering column, brakes, pedal assembly, shifter, shift linkage, instruments (refaced for an authentic look), engine, transmission, axles, parking brake and wheels.
Build the 550. When we built our 550, we used an early 911 as a donor and got the transaxle/shifter/linkage from a 914. It would have been less expensive to build from a 914 base.
The black one in this picture is ours. One of the silver 550 cars is a subaru engine.
angela
Hello
Old 05-18-2007, 11:32 AM
notfarnow's Avatar
Exactly what I was wondering about! Thanks Angela
So is there already a 550 tube frame designed to use these 914 components?
'03 Carrera 4s
Old 05-18-2007, 11:51 AM
check out
factoryfive.com
they do some pretty insane kits
www.superformance.com
I've been considering doing a kit myself for a long time...
the other route to go is to get one custom welded. Drawing up something to mate to suspension/engine would be an interesting challenge, and paying to have it welded up and powdercoated shouldn't be that expensive...
Seems that one could be able to make themselves an ariel atom type rig for about 10 grand, or less, depending on how much time you could put into it. Very time consuming, and the end result is probably pretty similar to a miata/914 but still....
66 911... no more
90 mazda miata
76 unimog 406
Dune Buggy!
Old 05-18-2007, 01:40 PM
notfarnow's Avatar
Laneco got me looking at thunder ranch, and they have their tube frames for the 550 kits
Something like that would be cool, if you could transfer 914 components directly onto it.
As for making a custom tube frame, I saw a neat trick on a build diary for a Bonneville streamliner:
They make a complete frame out of 2" PVC pipe, using heat lamps & torches to make the bends. Then, once the whole thing is mocked up, they disassemble it and use the individual pieces as templates for the steel tubing.
Neat stuff, and it saves them building it out of steel only to find they can't fit in it with their helmet on
'03 Carrera 4s
Old 05-18-2007, 02:04 PM
svandamme's Avatar
i don't understand this fascination for 914 parts?
do you have a full stock and no use for them?
i mean , it's tube frame, there's loads of parts that will fit
could even fit 944 steering racks and tranny if you want
or 968 or boxster
you asked for a tube frame 914 kitcar,
but now it's "a tube frame to put 914 parts like an Atom but with a 356 look"
that's a whole different story all together
Stijn Vandamme
Old 05-18-2007, 02:07 PM
notfarnow's Avatar
No, either you misunderstood me, or I wasn't clear with my first post.
My questions center around using 914 components as a base for a tube framed sports car. Bodywork, or lack thereof, is secondary.
Nope, but there are lots of 914 donor cars around.
My fascination actually goes back to a street legal Formula Vee I saw for sale a while ago. I was interested enough to start making calls and hunting around, but then got turned off by the low-tech aspects of them. Swing axles, drum brakes etc. A 914 seems like a better starting point for what I'm considering
'03 Carrera 4s
Old 05-18-2007, 02:15 PM
svandamme's Avatar
i just think you're going at it the wrong way
because you're thinking custom not kit, but you keep asking for kit
first you decide what you want to do with it
that determines layout, dimensions
then you look and figure out what you can put into that frame so it fits and the whole thing makes sense
the pic you posted, that's not what i call a tube frame chassis
that's closer to a beetle then to an atom
it would either require extensive custom work to add something on top of it ,or it would be no better then a beetle chassis
could just as well take a beetle chassis and start welding
and mod it for mid engine layout
many kit cars do just that, with VW gti engines and what not
but to be atom like, it's just completely the wrong setup
the atom is designed to be fully self supporting from the ground up
not as a skateboard with reinforcement
gotta think rigid from the start, not flex and then strenghten if you want Atom
Stijn Vandamme
Old 05-18-2007, 02:23 PM
Laneco's Avatar
Actually, the frame shown above is not the one I have in mind. We actually have a thunder ranch, but the frame is NOTHING like that one.
This frame is from Vintage Spyders and I think this is more what you need to start with. This is very similar to the frame we have. The front of ours is significantly different as we have double A-arm w/coil over with rack and pinion. This frame in the pic is VW front end. Hope it gives you some great ideas.
angela
Hello
Old 05-18-2007, 03:04 PM
