http://www.recguns.com/Sources/VIIE8.html 223 Rem is 1,303 ft-lb energy 45-70 is 2,351 ft-lb energy
1989 3.2 Carrera coupe; 1988 Westy Vanagon, Zetec; 1986 E28 M30; 1994 W124; 2004 S211 What? Uh . . . “he” and “him”? |
Will be 'interesting' to find out what at 700 Nitro at over 8,900 ft/pounds or a 600 Nitro at 7,500 ft/pounds will do to a human body!!
Jordi Riera '84 930 (modified) |
least common denominator
Gary Fisher 29er 2019 Kia Stinger 2.0t gone ![]() 1995 Miata Sold 1984 944 Sold ![]() I am not lost for I know where I am, however where I am is lost. - Winnie the poo. |
Senior Member
Still, I respect your views and suspect perhaps I am missing something. Perhaps the beer will clear it up. BTW. I lived in Idaho Falls when we had the bunny overpopulation problem that was in the news nationwide. Bunny roundups and killing with bats. We would get a couple of boxes of shells and go sit and shoot bunnies. We used 110 gr "Kirksight) bullets with a semi-rounded nose. Solid brass. I don't recall the muzzle velocity, but those bullets went FAST. Fast enough that a square hit on a bunny made the bunny disappear into a cloud. Strange talk for a liberal, I suppose.
Man of Carbon Fiber (stronger than steel) Mocha 1978 911SC. "Coco" |
Jeff '72 911T 3.0 MFI '93 Ducati 900 Super Sport "God invented whiskey so the Irish wouldn't rule the world" |
It's velocity!
The lethality of a ballistic round has more to do with round placement and velocity at impact than total round mass when striking a target. This is the basis for the tungsten and depleted uranium sabots rounds that have been used with devastating effect by our tank and mobile armor divisions. Query for video clips of tank on tank sabots kills and marvel at the destruction. Most of the recent kills utilize a round that is 1/3 the size of the bore that actually fires the round… “M1A1 fires a APFSDS-T discarding sabot "anti-tank" shell, with the "sabots" peeling away shortly after the 120mm shell leaves the barrel. The smaller, 12 pound, 40mm penetrator thus travels at a higher speed (up to 5,000 feet per second), and can penetrate more armor when it hits an enemy tank. The high speed round hits its target with force equal to an eleven ton truck hitting something at a speed of 112 kilometers an hour.”
Yes, this discussion is about light arms but in the case of the 5.56/.223 round the higher velocity (fps), when compared to the heavy cal. 1900’s rounds, increases both the wound cavity and boat-tail tumbling effect of this wicked 55gr to 68 grain round. Couple this high velocity with the accuracy, cyclic rate of fire, and three round burst capabilities of the current “M-16/M4” and they make for a very effective weapon platform. 5.56 or 7.62 at 100m and you’re probably equally dead on a center mass shot. But for an extremity shot I’d rather catch a 7.62 then have a 5.56 tumble up and arm or leg. We’re not wimping out. What’s the mathematical equation that proves this out? And yes, the 7.62, a Lupa round or 50cal is a far superior long range tactical round to the 5.56.
Senior Member
Long time friend of mine shoots .416 Rigby Express from time to time. Gents, that thing will kill anything on this earth (except Hitlary, and you would need a wooden stake for her) with just one well placed shot. I do not ever want to shoot it again... was sore for a week.
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
A bullet dissipates its energy -- when stopped in an animal -- in a fraction of a second; the high power for a fraction of a second actually represents minimal amounts of total energy (work). Your observations when bullets hit animals was not energy from the bullets "knocking" the animals down. It was gravity acting on them when they fell down, combined with the energy in their muscles from (most likely) their attempts to run away. |
Banned
Here is a 45-70 with a hot load for a modern gun
Trajectory (Basic) Output Input Data Manufacturer: Barnes Description: 0.458 dia. 350 gr. X Flat Base Muzzle Velocity: 2400.0 ft/s Sight Height: 2.00 in LOS Angle: 0.0 deg Cant Angle: 0.0 deg Wind Speed: 0.0 mph Target Speed: 0.0 mph Temperature: 75.0 °F Pressure: 29.92 in Hg Relative Humidity: 50.0 % Altitude: 0 ft Std. Atmosphere at Altitude: No Corrected Pressure: Yes Target Relative Drops: Yes Zero at Max. Point Blank Range: Yes Calculated Parameters Elevation: 9.13 MOA Azimuth: 0.00 MOA Atmospheric Density: 0.07378 lbs/ft³ Speed of Sound: 1133.6 ft/s Maximum PBR: 293 yds Maximum PBR Zero: 249 yds Range at Max Height: 140 yds Energy at PBR: 2610.7 ft•lbs Sectional Density: 0.238 lbs/in² Calculated Table Range Drop Drop Windage Windage Velocity Mach Energy Time Lead Lead (yds) (in) (moa) (in) (moa) (ft/s) (none) (ft•lbs) (s) (in) (moa) 0 -2.0 *** 0.0 *** 2400.0 2.117 4475.7 0.000 0.0 *** 50 2.0 3.8 0.0 0.0 2297.0 2.026 4099.9 0.064 0.0 0.0 100 4.4 4.2 0.0 0.0 2196.5 1.938 3749.0 0.131 0.0 0.0 150 4.9 3.1 0.0 0.0 2098.5 1.851 3421.9 0.201 0.0 0.0 200 3.5 1.7 0.0 0.0 2003.1 1.767 3117.9 0.274 0.0 0.0 250 -0.1 -0.0 0.0 0.0 1910.4 1.685 2836.0 0.350 0.0 0.0 300 -6.1 -1.9 0.0 0.0 1820.6 1.606 2575.5 0.431 0.0 0.0 350 -14.7 -4.0 0.0 0.0 1733.8 1.529 2335.7 0.515 0.0 0.0 400 -26.1 -6.2 0.0 0.0 1650.3 1.456 2116.2 0.604 0.0 0.0 450 -40.8 -8.7 0.0 0.0 1570.3 1.385 1916.1 0.697 0.0 0.0 500 -59.0 -11.3 0.0 0.0 1494.3 1.318 1734.9 0.795 0.0 0.0 550 -81.1 -14.1 0.0 0.0 1422.4 1.255 1572.1 0.898 0.0 0.0 600 -107.5 -17.1 0.0 0.0 1355.2 1.195 1427.0 1.006 0.0 0.0 650 -138.6 -20.4 0.0 0.0 1293.0 1.141 1299.1 1.119 0.0 0.0 700 -175.0 -23.9 0.0 0.0 1236.3 1.091 1187.6 1.238 0.0 0.0 750 -217.0 -27.6 0.0 0.0 1185.5 1.046 1092.0 1.362 0.0 0.0 800 -265.2 -31.7 0.0 0.0 1140.7 1.006 1011.1 1.491 0.0 0.0 850 -320.1 -36.0 0.0 0.0 1101.8 0.972 943.2 1.625 0.0 0.0 900 -382.1 -40.5 0.0 0.0 1067.8 0.942 886.0 1.763 0.0 0.0 950 -451.8 -45.4 0.0 0.0 1038.1 0.916 837.3 1.906 0.0 0.0 1000 -529.5 -50.6 0.0 0.0 1011.6 0.892 795.1 2.053 0.0 0.0 THe permanent wound channel would be close to 3/4 of an inch. The temp channel ??? but big very big. I would not want to be struck by any round, even a 22 short, but the good old 45-70 would still drop an elephant at 800 yards. http://www.eskimo.com/~jbm/ballistics/traj_basic/traj_basic.html Last edited by snowman; 05-22-2007 at 05:52 PM.. |
"The temp channel ??? but big very big."
and also meaningless... most tissue being elastic and all... except the (liver is it?) also... how come i dont get thrown back when i fire my muzzle loader if for every action there is a reaction? why am i not being thrown to the ground? didnt mythbusters even do a show in this because its such a misconception? i take the 45 auto out and shoot a 60lb steel target and it just barely wiggles when the full force of the bullet is transmitted to the front of it... all XXXXft\lbs Did anyone consider the fact that a big slow bullet is easier to stop with body armor then a smaller faster bullet? so if its all about creating the biggest >>>>permanent<<<< wound channel .... if the bullet never gets in.. then that would be a problem...
SWB Last edited by air-cool-me; 05-22-2007 at 06:54 PM.. |
Anyway, I have observed the same reaction in a few deer I have shot. It really is pretty impressive; they appear for all the world to have been all but bowled over, ass over teakettle, by the bullet's impact. I even had one jump straight up in the air one time, like five or six feet straight up. Of course, he should have been knocked away from me, if it really was the impact. Hmm... I have always ascribed this reaction to nervous shock. All nerves fire upon the bullet's impact; kind of like a really big hammer to the knee at the doctor's office. It's a reflexive reaction. It sure can make it look like they got "knocked over", but the vast majority do not react in this way. Much has been written about the effects of nervous shock imparted by the impact of a very high velocity rifle bullet. It can, and will spectacularly kill some animals. Deer tend to be wound a little tight. They are very much on the "nervous" end of the spectrum in the animal world. I guess I would be too, but I digress. Moose, for example, are on the other end of that spectrum, sporting notoriously phlegmatic nervous systems. It takes one a long time to figure out they are dead. You won't see one react to nervous shock. Most deer won't either, so we rely upon the permanent wound channel and massive blood loss to kill. Men are even more susceptable to nervous shock than deer. We are quite easy to kill compared to just about any game animal. This atribute has been used to help justify the current "sub-caliber" infantry rounds. What does not seem to be accounted for, however, is the affect of adrenaline on a man's ability to absorb, and shrug off, any kind of nervous shock. Now we are back to the permanent wound channel. This has been demonstrated in battle ad nauseum, from the failed introduction of the .38 Special during the Morro insurection to the tragic deaths of the FBI agents in Florida. There is a difference between killing and stopping; a sub-caliber round may very well eventually kill, but if that happens even a minute after impact, it can be a real problem. We want to see opponents stopped; right here; right now. Big calibers do that better.
Banned
I have let others shoot my 45-70. What I observe is that the gun twists their body half way around and backwards about 6", with every shot. Thats when they are braced against it. Last edited by snowman; 05-23-2007 at 08:03 PM.. |
When I did my army service, we had two main types of weapons. 7.62mm were bulky and hard to carry. They also had lower velocity but higher energy. 5.56mm were easier to carry and were almost "high velocity". I had a privilege to be teached by a guy who was also a teacher at military academy and he said: 1. 5.56mm is more accurate, easier to handle and easier to carry. 2. Main objective is not to kill but to wound the enemy, thus tying more resources. 3. A bit more powder would make 5.56 into "high velocity" weapon. A high velocity bullet will project a shock-wave trough soft tissue which is actually worse than being hit by bigger but slower projectile. This shock-wave will destroy tissue around entry point w/o mechanical contact. You get a conically shaped wound and if projectile starts tumbling (which it often does) the wounds are actually worse than 7.62mm stuff. So yes, 5.56 isn't so bad when it comes to infantry weapons. We use 12.9 Barret for wrecking stuff. 5.56 is for soft-target combat and I understand why. You have to pick the right tool for the job.
Thank you for your time, Last edited by beepbeep; 05-24-2007 at 12:40 AM.. |
durn for'ner
In the Military they had us shooting heavily sedated pigs to show the impact result of high velocity weapons like the AK-5. The light, unstable bullets start to tumble in the body at impact. The result is just awful. A tiny little entrance whole and an enormous crater where it exited along with most of the internal organs of the poor animal. Truly heinous.
Markus Resident Fluffer Carrera '85 |
(the shotguns)
this is sort of not on point, but in duck hunting and, to a much smaller extent dove hunting, there are four factors in the ammo choice: 1-size of pellet 2-speed of pellet 3- # of pellets 4- density (material choice) of pellet. If you gather a dozen duck hunters you will find more than a few different combinations of these choices. interesting stuff as the goal is to kill the bird stone dead and absolutely minimize cripples. as it happens i currently prefer light, fast loads. my hunting partner is very content with his heavier, slower loads.
there is of course no 'tumbling' effect with round pellets but some prefer softer tungsten etc. based pellets which are said to deform slightly on impact and create a bigger mess internally. the most spectacular (i.e. dead in the air and dropping like a stone) kills i have witnessed tended to be shots in which pellets went clean through (hitting vitals is the name of the game). there is a theory that while the duck certainly didn't bleed out instantly it was the 'shock' of the impact (minimum 3 pellets COM in my experience) that killed the bird. not sure how this works myself but if it means absolute minimal suffering i'll take it! as i said, this doesn't quite apply to humans and boattail rounds but it is interesting.
***************************************** Well i had #6 adjusted perfectly but then just before i tightened it a butterfly in Zimbabwe farted and now i have to start all over again! I believe we all make mistakes but I will not validate your poor choices and/or perversions and subsidize the results your actions. Last edited by berettafan; 05-24-2007 at 04:40 AM.. |
Lots of the more lethal ammo like large calibre, hollowpoints, etc are against the law...that is why the military does not use them.
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo http://www.pelicanparts.com/gallery/fintstone/ "The problem with socialism is that you eventually run out of other people's money" Some are born free. Some have freedom thrust upon them. Others simply surrender |
"...expanding point ammunition is legally permissible in counterterrorist operations not involving the engagement of the armed forces of another State."
I recall seeing ballistics tests which show that the .223 not only tumbles, it breaks apart into (usually) two pieces which diverge. Who needs a hollowpoint when you already have a tumbling, fragmenting bullet?
