notfarnow's Avatar
need computer help... lost files
Was moving pictures from one folder to another, and I got the popup "this file name already exists, would you like to replace it?".
I thought they were the same images (about 10 of them), but they weren't, just had the same names. They've now been overwritten with the new images.
PPOT brain trust: Is there any way to recover them?
'03 Carrera 4s
+ a whole bunch of boats
Old 06-25-2007, 06:11 AM
id10t's Avatar
Nope....
Old 06-25-2007, 06:13 AM
Senior Member
Jake,
Did you "cut" them or just "copy" them from one folder to the other?
Old 06-25-2007, 06:24 AM
Dept store Quartermaster
lendaddy's Avatar
Isn't there a Windows feature that restores your whole system to a previous state?
If it's a MAC, then I think you're screwed. Perhaps either way.
Cornpoppin' Pony Soldier
Old 06-25-2007, 06:25 AM
notfarnow's Avatar
Originally posted by Joeaksa
Jake,
clicked & dragged.
Lendaddy, I'll check to see if I can do a system restore.
edit: system restore has been turned off on this PC... damn
'03 Carrera 4s
Old 06-25-2007, 06:34 AM
Information Junky
island911's Avatar
I think that the data could still be there ... if the new file size is larger than the old, it will be written to a different spot, and the old data will just be "deleted" (where the file space is switched to be available for writing).
...but then again, it's been a while since I've recovered files.
Disclaimer: the above was 2˘ worth.
Old 06-25-2007, 06:51 AM
notfarnow's Avatar
Why only one star?!? This easily is a 4 star thread.
Shoulda known:
It doesn't look like I'll recover the images. Too bad too, they were "before" pictures for my latest project.
'03 Carrera 4s
Old 06-25-2007, 07:01 AM
Senior Member
Just retrieve them from where you backed up your data...
You DID backup your data didn't you???? Ahmmm, if not then do it now and learn from this.
Wouldnt Norton find these old files if the hard drive space had not over-written the area?
Old 06-25-2007, 07:12 AM
Super_Dave_D's Avatar
Running a Windows system restore to the previous point will not do it. Since the names were the same - I think you may have lost them.
Stop calling pictures the same name - as an example: hot1, hot2 hot3 and so forth.
2015 Audi S3
1988 Carrera Coupe (gone and miss her)
Old 06-25-2007, 07:41 AM
Registered abUser
TerryH's Avatar
This is easy to do if you don't name your files. Digital cameras can use the same numerical names if you reformat the memory chip or change chips.
'81 911SC Coupe SOLD
Old 06-25-2007, 07:47 AM
Originally posted by TerryH
This is easy to do if you don't name your files. Digital cameras can use the same numercal names if you reformat the memory chip or change chips.
Correct - didn’t seem to be the case here. There is also a Free MS download that will enable you to rename 100's or 1000's of file and it will sequentially change them to actually mean something.
http://support.microsoft.com/kb/320167
Once you dowload this - its a 'right click' option.
2015 Audi S3
Old 06-25-2007, 07:50 AM
