temp sensor that will log to PC
I'm curious if anyone knows of a temp sensor that will connect to a PC that can then log the temp to a file. Not for the PC temp, but for room temp or something like that. It's nothing vital, so something cheap would be preferable.
Or if you have an idea where I could go to look for more info.
Nevermind, my previous searches didn't do much, but I just hit the jackpot.
Pico.
'66 911 #304065 Irischgruen ‘96 993 Carrera 2 Polarsilber '81 R65 Ex-'71 911 PCA C-Stock Club Racer #806 (Sold 5/15/13) Ex-'88 Carrera (Sold 3/29/02) Ex-'91 Carrera 2 Cabriolet (Sold 8/20/04) Ex-'89 944 Turbo S (Sold 8/21/20) |
For posterity, would you mind sharing the jackpot with the rest of us? TIA
'86 911 (RIP March '05) '17 Subaru CrossTrek '99 911 (Adopt an unloved 996 from your local shelter today!) |
In case anyone else is ever curious, here you go.
http://www.measurementcomputing.com/ It's battery powered and stand alone. The USB is only used to configure the thing and download the data. # Stores 16,382 temperature reading measurements # Supports -35 to +80 °C (+/- 1 °C accuracy) # Supports sampling intervals of 10 sec, 1 m, 5 m, 30 m, 1 hr, 6 hrs, 12 hrs $59 They also have a slightly cheaper $49 model, but the accuracy/precision is lower, the temp range is smaller, and the sampling intervals and memory is reduced. There's also a $79 model that's the same as the above except that it also logs up to 16382 relative humidity samples.
Nice. Thanks.
I never bought one of the units above, but I still want something. I just found another option. This option is wired and is what I was originally thinking about when I posted this thread. I discovered the info while looking into personal weather stations.
http://www.hobby-boards.com/catalog/index.php?cPath=22 Temp sensors can be bought from the same place for $18, combo temp/humidity for $52, barometric press for $60, rain gauge for $89, usb or serial adapter for $28, hubs for $50, etc.... http://www.hobby-boards.com/catalog/howto_basics.php Quote:
This looks like something that should be relatively inexpensive and that you can start and build on.
Onset Computer just up the road from me, makes a variety of sensors and data logging packages that have a very good reputation.
http://www.onsetcomp.com/
1985 911 Carrera Moss Green Metallic Steve Wong Chip, WEVO shifter & PSJ, Kuehl Air Conditioning |
AutoBahned
what I'd like is a nice cheap temperature sensor that communicates via WiFi...
canna change law physics
James The pessimist complains about the wind; the optimist expects it to change; the engineer adjusts the sails.- William Arthur Ward (1921-1994) Red-beard for President, 2020 |
http://www.temperaturealert.com/product_p/tm-wifi20.htm Not much cheaper, you could use something like this in conjunction with a serial sensor. http://www.usbgear.com/VSCOM-123WLAN.html Still, I wouldn't call either cheap. I think the problem is the "wifi" and "cheap" in the same sentence. Yes, you can get a cheap USB wifi adapter for a PC, but I think that's because the PC is the brains. The wifi adapter is just a tiny transmitter. It takes the PC's CPU and OS to make it work. I believe that there are wifi USB hubs. If there are any of those cheap, then you could probably couple one with a 1-wire temp sensor and be on your way. Still, it all depends upon how much you want the sensor and what you consider cheap. Ultimately, I think it would be great to be able to purchase a $25 wireless thermometer like you can buy at Walmart or Radio Shack that has a serial or USB connection for a computer. I wouldn't think that would cost that much extra to make and would still be pretty cheap. But I haven't yet found anything like that.
AutoBahned
yup, neither have I...
