Retired in Georgia
Help With Physics Problem
My kid is struggling with this one...I put it to the brain trust to help him out a bit HOW to solve? And, correct answers I can use to check his work..
- - - begin - - - A chain consisting of five links, each of mass 0.094 kg, is lifted vertically with a constant acceleration of 2.42 m/s2, as shown ![]() (a) Find the force acting between the bottom link and the next one up. _______________ Find the force acting between the second link from the bottom and the one above it. _______________ Find the force acting between the third link from the bottom and the one above it. ______________ Find the force acting between the fourth link from the bottom and the one above it. _______________ (b) Find the force F exerted on the top link by the person lifting the chain. _________________ (c) Find the net force accelerating each link. ________________ - - - - end - - -
I've got five kids, an Italian wife, and I (used to) write about lawn mowers. You think you have problems? -Robert Coats |
Unregistered
I'm pretty sure it's spelled "fysics".
No thanks necessary
F = mA
the force at each link is the sum of the masses in the links below it *A
I believe gravity on the Earth and ignoring air resistance is 9.8m/s2 regardless of other forces.
2022 BMW 530i 2021 MB GLA250 2020 BMW R1250GS |
.094kg * (9.8+2.42)m/s^2
link 1 1.15N up (minus 9.8*.094=.92) --> .23N net You get the same thing from 2.42*.094 so, do you need the forces, or just the net force. If just the net force, then it's exactly what Bill said I'm guessing .23, .46, .69, .92 is the net for each link and for the gross, 1.15, 2.3, 3.45, and 4.6
as the chain is lifted, all links will stay together....but it might swing a little bit from side to side
acceleration is the change of velocity with respect to time. D O P E !
Information Junky
What if it's made of Jello? ....warm Jello, w/ added gin.
Everyone you meet knows something you don't. - - - and a whole bunch of crap that is wrong. Disclaimer: the above was 2¢ worth. More information is available as my professional opinion, which is provided for an exorbitant fee.
Did you get the memo?
Free body diagrams, enough said. Upwards force is the total mass * vertical acceleration, weight is total mass * 9.81 m/s^2
‘07 Mazda RX8-8 Past: 911T, 911SC, Carrera, 951s, 955, 996s, 987s, 986s, 997s, BMW 5x, C36, C63, XJR, S8, Maserati Coupe, GT500, etc |
There are 2 parts to the resolution of this problem
the static case(before upwards acceleration) and the dynamic case (during the upwards acceleration) assumption; this is taking place near the surface of the earth in a total vacuum chamber. since we only care about the forces during the acceleration we add the acceleration due to earths gravity to the imposed acceleration net A = 9.8 + 2.42 = 12.22m/s2 from bottom to top force in Newtons at each link F = .094 * 12.2 = 1.1468N F = 2 * .094 * 12.2 = 2.2936N F = 3 * .094 * 12.2 = 3.4404N F = 4 * .094 * 12.2 = 4.5872N F = 5 * .094 * 12.2 = 5.734N
So then wouldn't the net force be the mass * the acc which in this case is actually 2.42m/s^2? The Force of gravity down minus the Normal Force (the chain links holding the bottom links up) should cancel each other out and the net force would be the upward acceleration which is only 2.42?
Like this
As I said 2 parts static case, just hangeing there each link exerts a force to to counteract the force of gravity. up = down because it's not moving. from lowest to highest F = .094 * 9.8 = .9212N F = 2 * .094 * 9.8 = 1.8424N F = 3 * .094 * 9.8 = 2.7636N F = 4 * .094 * 9.8 = 3.6848N F = 5 * .094 * 9.8 = 4.606N now add the imposed force that adds the additional 2.42m/s2 acceleration again from lowest to highest F= .094 * 2.42 = .22784N F= 2 * .094 * 2.42 = .45496N F= 3 * .094 * 2.42 = .68244N F= 4 * .094 * 2.42 = .90992N F= 5 * .094 * 2.42 = 1.1374N add the 2 components( I rounded in the previous response hence the dicrepancy) .9212N + .22784N = 1.14904N 1.8424N + .45496N = 2.29736N 2.7636N + .68244N = 3.44608N 3.6848N + .90992N = 4.59472N 4.606N + 1.1374N = 5.7434N It's a lot easier to do the math if you first add the acceleration components then multiply, but it can be done either way.
