jyl jyl is offline
jyl's Avatar
Trees To Block Off Sound/View Of A Road?
I could see the street next to me becoming noisier in the next 5, 10, 15, etc years.
It is not particularly noisy now, but the city is growing and there is room to expand from 2 lanes to 4 - they'd have to eliminate bike lanes and piss off an influential neighborhood, but you never know. . .
So, I was thinking about planting some trees as a sound and visual block now, in case they are needed in 10 years.
I could plant them along the sidewalk grass strip, they'd have to go between and in the shade of a pair of huge, old existing trees. Or I could plant them at the edge of my side yard, which is elevated appx 6' above street level, but also shaded.
Question - how effective are trees, to reduce car noise? What types of trees are most effective? Cypress? Some sort of evergreen? Are deciduous trees are less effective (simply because they're leafless part of the year).
In case it is not obvious, I know zip about trees . . .
Old 09-24-2007, 12:14 PM
Registered abUser
TerryH's Avatar
Yes, Italian Cypress. Better than a sound wall. They can grow to 40+ ft and extremely dense. Each of ours is about 4ft in diameter. So 3 ft apart should create a solid barrier in the future. Ask your local nursery for recommendations.
'81 911SC Coupe SOLD
Old 09-24-2007, 12:24 PM
Seldom Seen Member
Burnin' oil's Avatar
Thujas
http://www.fast-growing-trees.com/ThujaGiant.htm
Why do things that happen to white trash always happen to me?
Got nachos?
Old 09-24-2007, 12:35 PM
Bamboo works pretty good as well.
Old 09-24-2007, 12:39 PM
Control Group
Tobra's Avatar
Cypress is a messy tree, okay if you are not going to be hanging out anywhere nearby. Oleander is popular, as long as you have no kids or livestock to eat it.
pwd72s's Avatar
Better check with zoning, planning, road dept. where you live. Many municipalities have regulations on roadside trees...what types can be grown. This is to prevent them becoming a nuisance for various reasons, including roots in sewer lines, lifted roads and sidewalks by roots, etc....
Old 09-24-2007, 12:42 PM
Registered abUser
TerryH's Avatar
Messy? I don't think so. A few dead inner twigs occasionally nest the base of the trunk and serves as mulch.
http://www.tytyga.com/product/Italian+Cypress+Shrubs+and+Trees
Old 09-24-2007, 12:44 PM
Evolved
Mo_Gearhead's Avatar
QUOTE: "Question - how effective are trees, to reduce car noise? "
____________________________
They aren't. Unless you have the room to plant several acres of them between you and the road in question.
Don't fear the reaper.
Old 09-24-2007, 12:50 PM
Personally I feel a wall of stone or concrete would be more effective in blocking sound. Then use shrubbery or evergreens to hide. That said, in these parts one can plant right up to the property line as opposed to having an offset for a fence.
Another trick is to mask the sound with a fountain.
Warren & Ron, may you rest in Peace.
Old 09-24-2007, 01:16 PM
Trees, any trees, any amount of trees and type of trees will do nothing for sound decay.
What will affect sound levels (measured)?
1. Square of the distance the sounds fades away.
2. Sight lines (concrete wall close to source or even a tall earth berm).
What will affect perception of sound levels (subjective):
1. Tall trees which block the view and sent/clean or filter the air.
2. Tall fence which gives privacy (that loud sound is on the otherside of the fence, what do I care).
All that said, in my own mind I like to think trees can diffract some sound. All that really means in real life is that the direction of the sound source will play tricks on you, and not much else.
Old 09-24-2007, 02:01 PM
Unconstitutional Patriot
turbo6bar's Avatar
Budget for better windows and insulation if you perceive a problem down the road.
Outdoors? I think you're screwed. Wear earplugs.
Old 09-24-2007, 02:06 PM
Laminated glass, a winner.
Old 09-24-2007, 02:08 PM
Registered abUser
TerryH's Avatar
Here's a tree wall bordering my yard that absorbs sound. Got some rain and wind so they are little mussed, but they clean up well. The wall next to them is six foot for reference. These are Italian or Mediterranean cypress.
TerryBPP's Avatar
We use berms or a wall to reduce noise when highways get close to homes. Walls are about pretty expensive. Berm takes up more room. Trees may muffle it a bit but wont silence the traffic.
Old 09-24-2007, 03:16 PM
Dog-faced pony soldier
Porsche-O-Phile's Avatar
Topographical features work better (berms) but dense vegetation will help somewhat with diffusion.
Black Cars Matter
Old 09-24-2007, 03:20 PM
Evolved
That borders a street/highway with moving traffic? Or your neighbors yard?
TEST
1. Get a decibel meter.
2. Take readings as cars, trucks, motorcycles pass on the city street.
3. Plant as many trees as you can.
4. Wait 10-?? years for trees to mature.
5. Take decibel reading.
6. Compare step 2 readings to step 5.
I'll await the results.
Old 09-25-2007, 08:09 AM
TEST
The experimental methodology is flawed - there's no way to ensure that any gains or losses in dB are due to the vegetation. If traffic density doubles in that 10 years, even a positive effect by vegetation would be shown as a loss. Conversely if the vegetation does nothing and the traffic density decreases in 10 years, you'll show a gain.
Objects do diffuse sound waves and absorb some of their kinetic energy.
Black Cars Matter
Old 09-25-2007, 08:52 AM
Banned
You guys that are saying it doesn't matter are quite wrong.
We are in the middle of a huge landscaping project that has required us to take down a swath of ornamental trees and bushes. There is considerably more noise from the street now. We will be replanting a 'green wall' to suck up some of the sound. High quality windows, good insulation and well sealed doors have a significan impact as well.
Old 09-25-2007, 09:06 AM
AutoBahned
RWebb's Avatar
"Trees, any trees, any amount of trees and type of trees will do nothing for sound decay."
- Wow - I rarely see such completely incorrect statements. I simply cannot understand why people post this stuff when they obviously don't know which end is up.
Trees will significantly attenuate sound and this is well published in the scientific literature. How much depends on foliage characteristics.
You might try Doug. Fir - they will grow very quickly around here and have rel. dense, persistent leaves (evergreen). You can put something you like better behind them. Plant another row in a few years -- When the originals get too tall, you can cut them and sell them or just rely on the ones behind. You may have some shading issues eventually - if so, cut the tallest ones down.
You can also use slower growing but more ornate trees in the second or 3rd rows you plant.
D Fir is a very fast grwoing tree in the PNW and into SFO as well.
Old 09-25-2007, 12:29 PM
Evolved
QUOTE: "Tress will significantly attenuate sound and this is well published in the scientific literature. How much depends on foliage characteristics.
You can also use slower growing but more ornate trees in the second or 3rd rows you plant."
OK, time to ask JYL for some data. How far is your home from the street/road that is causing the 'problem'.
My point (somewhat tongue in cheek) was; unless he has several hundred feet of space, to plant (as you suggest) row after row of trees and then wait for them to grow and make a difference ... he is better off with suggested 'other' noise abatement methods.
And yes, my 'TEST' was not at all scientific, just an attempt to show the humor of a few trees planted in an attempt to reduce road noise.
Old 09-25-2007, 01:03 PM
