Dept store Quartermaster
Press fit question for the machinists/engineers
We are having a friendly dispute here and I am looking for some input.
We have a pin (.234" dia 12L14 stock) that is getting pressed into a knurled knob (.375" thick also 12L14). What diameter should the hole in the knob be for a solid press fit? What would be "too tight"/"too loose"? Thanks.
Cornpoppin' Pony Soldier |
Are you planing to heat one (the knob) and freeze the other (the shaft)prior to assembly?
Makes a bit of difference in the tolerances.
Bob S. former owner of a 1984 silver 944 |
I'd add .0005" interferance and you will be fine
1981 911SC Targa-1966 912 -1989 Alfa Spider Graduate 1967 912-1985 Toyota FJ60 Landcrusier 1985 Toyota SR5 4x4-1965 Baja Bug-1997-4Runner-4x4 1966 Bug stock-2004 Toyota Rav4-1989 XJ6 Jag 1975 914, 1965 Norton N15CS 750, 1975 Husqvarna 360 CR GP 1982 Honda 500 XLS |
I would suggest an FN2 medium drive fit of 0.0008 to .0027" interference. Of course I'd need material and application for a more accurate number. Really, 0.001 is probably plenty.
2014 Cayman S (track rat w/GT4 suspension) 1979 930 (475 rwhp at 0.95 bar) |
Get out your Machinest's Handbook and look it up. I have the 1917 edition that was my Grandfather's.
Jacksonville. Florida https://www.flickr.com/photos/ury914/ |
Senior Member
How big is the hammer?
Man of Carbon Fiber (stronger than steel) Mocha 1978 911SC. "Coco" |
Thanks guys,
My machinists handbook is in my desk and I'm at home. I told them I thought a half a thou to a thou and a half would be fine, but they had it set for MUCH more than that. Can you believe .008"? Thanks again.
Cornpoppin' Pony Soldier Last edited by lendaddy; 10-04-2007 at 03:15 PM.. |
OF course the easy way might be to taper the end of the shaft and the hole in the knob. Very slightly of course than assemble in a hydraulic press.
Ya, we can still get it in there(we use an air over oil press) but you can bulge the pin with the required force.
Unregistered
Is it being held with just the fit i.e. no key, no set screw, etc?
If so I'd go with a minimum .001" interference and no more than .002" So, make the hole .232" to .233", but mic the pin up to make sure it is in tolerance prior to reaming the hole. |
Just interference, no locking fluid or set screw.
![]() Don't forget some lube, otherwise getting it in there might gall a bit.
Banned
A good press fit is about 0.005" to 0.008" interference in most materials. It does depend on the diameter. For a small pin, like yours, an interference of about 0.003" should be sufficient. NO less. Anything less will not stay put.
Don't forget to chamfer the end of the shaft!!
Slumlord
Did you mean 0.0005? Because 0.005" will be little difficult to assemble. Why not go with a slip fit and red loctite? |
If the pin is .234" , make the hole the following dimension (diameter) for a press fit.
.2340/.2335 this is the case if both are metal |
Un Chien Andalusia
Isn't it easier to size the pin to the hole, than size the hole to the pin?
That way you can ream the hole to a standard size then turn the pin to whatever size you want to fit the hole. It's usually more difficult to get a hole to the right size when you already have the pin, so it would probably be a good idea to make the hole first in future. However, if you already have the pin then here's my suggestion. For an interference fit I would think you'd be looking at 1 to 2 thou and a transition fit would be roughly half a thou either side of nominal. But if you want a press fit I would think that anything between 0.0005" to 0.0015" would be fine. You'd probably want to aim for the middle of that range and make it 0.001", but 12L14 is a lead bearing, free cutting, and relatively ductile steel so you shouldn't have any problem if you make it a little on the tight side. 8 thou is WAY too much!
2002 996 Carrera - Seal Grey (Daily Driver / Track Car) 1964 Morris Mini - Former Finnish Rally Car 1987 911 Carrera Coupe - Carmine Red - SOLD :-( 1998 986 Boxster - Black - SOLD 1984 944 - Red - SOLD |
This is a production part and the components are already made incorrectly. It is much easier to ream the hole than to turn down the pin at this point.
Banned
I meant 0.003", not 0.0005". You probably need to heat the hole, freeze the pin and use a 5 ton press to fit the pin, and yes it needs tapering on the leading edge. The materials are important. If the coefficient of expansion of one material is 3 times that of the other, its very important.
One example is a valve seat in a aluminum head. The valve seat may have an expansion rate of 6ppm/deg C and Al 22 ppm/deg C. You better have at least a 0.003" interference fit or the seat will fall out. For larger holes, like a cylinder sleve in a 4" bore, you may need 0.005" to 0.008" interference and thats for a steel sleeve in a cast iron bore. Materials, operating temp range, and stress conditions are all important so there is not a single good answer to your question, but only 0.0005" for a 0.3" dia is marginal. Last edited by snowman; 10-05-2007 at 09:01 PM.. |
