![]() "If the Republicans will stop telling lies about the Democrats, we will stop telling the truth about them." |
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo http://www.pelicanparts.com/gallery/fintstone/ "The problem with socialism is that you eventually run out of other people's money" Some are born free. Some have freedom thrust upon them. Others simply surrender |
By Juliet Eilperin
Washington Post Staff Writer Friday, August 11, 2006; Page A03 Two new scientific studies measuring Greenland's rapidly melting ice sheet and the pace of Antarctic snowfall suggest that the sea level may be rising faster than researchers previously assumed. The papers, both published yesterday in the journal Science, provide the latest evidence of how climate change is transforming the global landscape. University of Texas at Austin researchers, using twin satellites, determined that the Greenland ice sheet, Earth's second-largest reservoir of fresh water, is melting at three times the rate at which it had been melting over the previous five years. A separate study by 16 international scientists concluded that Antarctic snowfall accumulation has remained steady over the past 50 years, with no increases that might have mitigated the melting of the ice shelf, as some researchers had assumed would occur. Taken together, the two reports indicate that global sea level rise may increase more rapidly in the coming years, though the Greenland study is based on only 2 1/2 years of data. The melting of 57 cubic miles a year from Greenland's ice sheet could add 0.6 millimeters alone, which is higher than any previously published measurement for Greenland, according to University of Texas Center for Space Research scientist Jianli Chen. "It's a very big number," Chen said, noting that for at least a hundred years the sea level has increased an average of 1.8 millimeters annually. |
Registered Usurper
I realize and respect that you are serious and sincere in what you say but balk at your unflagging certitude. And I would never call you stupid or a troll. I do suspect, however, that WI wide body is stupid and a troll.
'82 SC RoW coupe |
Chapter 10 Global Climate Projections In all scenarios, the average rate of rise during the 21st century is very likely to exceed the 1961 to 2003 average rate of 1.8 ± 0.5 mm yr–1 (see Section 5.5.2.1). The central estimate of the rate of sea level rise during 2090 to 2099 is 3.8 mm yr–1 under A1B, which exceeds the central estimate of 3.1 mm yr–1 for 1993 to 2003 (see Section 5.5.2.2). The 1993 to 2003 rate may have a contribution of about 1 mm yr–1 from internally generated or naturally forced decadal variability (see Sections 5.5.2.4 and 9.5.2). |
It appears intuitive that man would have to have some effect on global warming or cooling...but it seems intuitive that it would be insignificant compared to other factors...and short of returning the planet to the stone age...I fail to see how we can change enough to make anything other than a similar, insignificant change. My limited study of the subject does not show a consensus...or even enough data to work with. The voices of learned men have been drowned out those seeking political and financial gain. Current models are clearly inaccurate and will cannot be validated. If you run historical data...they fail to even match known history...so I wait for more information....but it seems clear to me that Gore's work is far beyond believable... As far as WI...we do agree on something finally...
Registered Usurper
'82 SC RoW coupe |
Yes. I don't know of a single significant scientific body that agrees to a sea level rise of anywhere near the magnitude of Gore's prediction. Do you? Since he is not a scientist...one can only wonder why anyone would think his predictions credible.
This author has an interesting take on the subject:
Gore Sea Levels? By Dennis Avery Al Gore’s movie An Inconvenient Truth says human-emitted CO2 will boost the earth’s temperatures enough to melt the Arctic ice cap—and suddenly raise sea levels by 20 feet. Phooey. First of all, let’s understand just how cold the Antarctic is. Winter temperatures on its high, cold interior plateau range from 40 to 95 degrees F below zero! In the summer (December) it “warms,” with temperatures dipping only to 49 degrees F below zero—and sometimes rising within 25 degrees F of the melting point (32 degrees F). But even then, the ice reflects virtually all of the sun’s rays back out into space. However, the world’s warming in the past 150 years has produced a change in Antarctica. The huge East Antarctic ice sheet, which contains nearly 90 percent of the world’s ice, has been thickening. European satellites measured the ice sheet’s thickness 347 million times between 1992 and 2003, and found it is gaining about 45 billion tons of water per year because the planet has warmed enough for snow to fall at the coldest place on earth. The study, “Snowfall-driven Growth in East Antarctic Ice Sheet Mitigates Recent Sea-level Rise” was led by Curt Davis of the University of Missouri, and reported in Science on June 24, 2005. Thickening ice in the Antarctic, in fact, is just about offsetting the meltwater being released from the edges of the Greenland ice sheet—which has also been thickening in its center. This leaves us with a global warming sea level gain of about 1.8 millimeters per year—or 4 inches per century. The rise has remained constant during the 20th century despite the moderate 0.6 degree C warming of the planet. In the movie, a whole Antarctic ice sheet shatters on Gore’s computer screen. In the real world, that isn’t happening. It is only the Antarctic Peninsula—2 percent of the continent’s land area that sticks up toward the far-off equator—that is warming. It recently earned headlines by calving an ice floe as big as Rhode Island, not an unusual event. But the East Antarctic ice sheet is more than 2,000 times bigger than Rhode Island, and the ice is two miles thick! John Stone of the University of Washington, reporting in Science on January 3, 2003 says the West Antarctic ice sheet has been retreating so slowly for the past 10,000 years that it still has not fully accommodated the end of the last Ice Age, and apparently still has about 7,000 years of ice to melt—and the East Antarctic ice sheet is melting even more slowly than that. So. Al Gore says Antarctic melting will suddenly raise the sea levels by 20 feet, and the experts say 4 inches per century. Seth Borenstein, an AP science writer, did a column on June 27 headlined, “Scientists OK Gore’s Movie for Accuracy.” The dean of environmental studies at Duke is quoted as saying “He got all the important material and got it right.” Were they talking about the same movie I saw? Gore overstated the impact of global warming on the Antarctic glaciers by about 50-fold. Or did he mean that 7000 years was “sudden”? How can so-called scientists applaud his accuracy either way?
"http://yosemite.epa.gov/oar/GlobalWarming.nsf/content/ResourceCenterPublicationsSeaLevelRiseIndex.html"
Any search using the words "GlobalWarming" or "Sea Level Rise" gets you dozens of hits from various organizations
Bob S. former owner of a 1984 silver 944 |
What exactly did Gore predict? Please list some of his scientific predictions per sea level rise and the Gore quote to match what you imply? |
You posted that your "figures" contradict my post/position. Could you please illuminate me as to your reasoning...as it is not obvious.
Control Group
Is it t that tough to see that draconian restrictions on carbon output placed upon an essentially carbon based economy like the US will have an adverse impact? This whole thread sort of sucks, feel like I wasted some time, lucky I read fast. Oh, BTW, you guys do realize that ALGORE is not a scientist in any way, and has never "proved" anything about anything, right? He just collated a bunch of stuff other guys have done that supported the point he wanted to support so he could sell carbon off sets and gain power with the left. The Oscar and Nobel prizes were a happy bonus, but were more about making President Bush look bad than anything else, same reason Michael Moore is famous.
She was the kindest person I ever met |
fint:
There is enough info on that site alone to answer all your questions, both pro and con. I list it as an aid to those who seem to be hesitant to look things up on their own and get real answers. I can see why you would be "confused" (your smiley!!) Most of what is posted re: sea level changes is opinion and wishful thinking, both for and against the effects. Low lying areas of the world, according to many clmatologists are extremely sensitive to even a nominal rise. Add to any rise, the effects of storm surge during hurricanes and other tropical events, and the damage can be magnified relative to the damage at lower sea levels. Over the lifetime of the world, the seas have risen and fallen a number of times, but never when there were as many people as there are now lving close to the world's oceans. That is one of the most critical areas where any increase in storm activity/sea level would impact civilization. I find the situation interesting, but nothing that will impact me personally. I am just too old to be around when the seas rise (and they will). The worst case (which in all likelihood would not happen) would entail the melting of all surface (landlocked) ice in Greenland and Anarctica. It is estimated that there are 630,000 cubic miles of landlocked ice in Greenland and 6,000,000 cubic miles in Antarctica. Leaving Anarctica out of the equation for now, and taking into consideration that the oceans of the world comprise 139,000,000 square miles in area, then the melting of one cubic mile of ice would raise an area of the ocean five thousand two hundred and eighty square miles by one foot. 139,000,000/5280 = 26,326, or the number of cubic miles needed to raise the entire ocean by a foot. 63,000 cubic miles/ 26326 = 26.9 feet. Now if one wished to add Anarctica to the equation, there is an estimated 6,000,000 cubic miles of ice down there. So, it would appear that not much melting is required to affect places like, for example, Florida. To be fair, according to NASA, ice pack in central Greenland is growing, but the amount melting is six times the growth. Just interesting stuff.........
But I also wonder where you get yours from...so let me re-ask a question that you choose to ignore. "What exactly did Gore predict? Please list some of his scientific predictions per sea level rise and the Gore quote to match what you imply?" Thanx. |
