bigchillcar's Avatar
Here's a screen shot:
If the upperfilters line does not exist, don't delete it
Delete the lowerfilters, close regedit, reboot and see what happens.
wilco. i can't recall how i used to take screen shots, but may not be able to now since i lost all the programs i'd downloaded over the past two years since i did the reset to original factory delivery..
To the memory of Warren Hall (Early S Man), 1950 - 2008
www.friendsofwarren.com
1990 964 C4 Cabriolet (current)
1974 911 2.7 Coupe w/sunroof 9114102267 (sold) 1974 914 2.0 (sold)
Old 02-21-2008, 02:42 PM
slodave's Avatar
To take a screen image of just the window you want - regedit, hold down the alt key and press "print scrn" (to the right of F12). Windows has a built in image editor, Goto Start->Run and type in mspaint.
Old 02-21-2008, 02:47 PM
hi dave,
still not seeing the cd after deleting low filters entry, exiting and re-booting. i did the alt/print screen, but nothing happened..or it took a pic and i don't know the file path it saved it under?
Old 02-21-2008, 02:55 PM
slodave's Avatar
You have to paste the screen shot into mspaint or other application (i.e. Photoshop). Optical drive may be bad. Do you have another that you can test with?
Old 02-21-2008, 02:57 PM
no, it's the only drive that i have.
Old 02-21-2008, 03:01 PM
slodave's Avatar
Optical drives are around $60.00. Ya may bite the bullet and pick a new one up. The registry trick only works if the drive is good, but a driver may have become corrupt. It was worth a try.
Old 02-21-2008, 03:05 PM
dave, no chance it could be a driver issue? although it shows to be working properly in device manager. did you decide it my model's a dual or single laser?
$60 for a replacement drive. okay..how much would best buy's geek squad probably charge to install? i've played inside plenty of desktops, but it's been a while and i've never opened up a laptop..
thanks so much for your help, dave.
Old 02-21-2008, 04:00 PM
slodave's Avatar
Whoops, I missed that it was for a laptop. Those drive are more expensive. There aren't really any drivers for an optical drive outside of the native windows drivers. There is a firmware upgrade for the drive, but it may not fix the problem. Laptop optical drives are usually easy to replace. Most of the time, there is a screw on the bottom of the laptop that secures it. Your drive is about $100.00. Google sony dvd+rw DW-Q58A. Lots of people having problems.
Old 02-21-2008, 04:07 PM
ahhh....i will google it. think i should replace with another brand/model? i think i see the screw. if that's all that holds it..great. i guess you could then pull out the entire drive unit and the cabling would come out, too, so you can detach and replace without opening more of the computer?
Old 02-21-2008, 04:20 PM
Could you just reformat and hope for the best? I've had things not "'take" the first time around. Another option is get a usb external drive. I have a Plextor that works nicely. Yeah - it's a pain to haul around an external drive, but not too bad. Plus I can count on one hand how often I use my drive.
Old 02-21-2008, 04:26 PM
slodave's Avatar
No cable should come out. The drive usually "plugs" into the laptop. If anything, you would have to take a plate off of the bad optical drive and put it onto the new one. If you were to get the same drive, it would be obvious of what needs to be moved.
You can't really just go buy any brand optical drive for a laptop. You would have to figure out what optical drive models are compatible for your laptop and that is not easy for an end user to do.
Dave
Old 02-21-2008, 04:40 PM
slodave's Avatar
Here's an example site that lists various drives for laptops...
http://www.bixnet.com/lapexcddriv.html
Old 02-21-2008, 04:41 PM
hey, bob..that's a reasonable idea..except i might use mine to watch movies while traveling.
thanks for the link dave...guess i'll get this taken care of tomorrow.
Old 02-21-2008, 05:20 PM
Formerly bb80sc
Vipergrün's Avatar
Chill, have you visited the Dell website yet? You should be able to look up your exact model and get all of the appropriate drivers.
Cheers
-Brad
2015 Cayman GTS
2015 4Runner Limited
Old 02-21-2008, 06:42 PM
Load the movies onto your hardrive (from the external drive). I think you use less battery that way - could be wrong.
Old 02-22-2008, 05:27 AM
