Yeah, I like the angle of that last one and it is clear.
GAFB
Several BMWs |
Pre Registered
It definitely was a non-runner.
A few photos that I took of the Deutsche Rat motor at RRIII: ![]() ![]() ![]() Tim |
Pre Registered
Tim |
Gon fix it with me hammer
![]() ![]() ![]() ![]() ![]() ![]() looks like they prettied the car up these days, compared to when they actually built it and were testing with it... it looks to clean now compared to then
Stijn Vandamme EX911STARGA73EX92477EX94484EX944S8890MPHPINBALLMACHINEAKAEX987C2007 BIMDIESELBMW116D2019 Last edited by svandamme; 02-23-2008 at 01:22 AM.. |
resident samsquamch
So I think when you go to hell, Beelzebub gives you this exact engine and demands that you time the cams!!! If you succeed, then they give the accordion to play...
-jeff back in the saddle: '95 993 - just another black C2 *SOLD*: '87 930 GP White - heroin would have been a cheaper addiction... "Ladies and Gentlemen, from Boston Massachusetts, we are Morphine, at your service..." - Mark Sandman (RIP )
2 cam's per cyllinderbank, 1 crank it doesn't really matter if you have 2 cyllinders per cam or 8.. the actual timing works identical, same amount of effort required... at least that's what i'm thinking, i've never done a F-16 cam timing job myself
Stijn Vandamme EX911STARGA73EX92477EX94484EX944S8890MPHPINBALLMACHINEAKAEX987C2007 BIMDIESELBMW116D2019 Last edited by svandamme; 02-23-2008 at 05:11 AM.. |
For what it's worth, these were not small engines as some people have suggested. Their displacement was greater than the largest of the flat 12's that Porsche built. Porsche even went so far as to play with the image of the 16 cylinder in the comparison photo of the 16 and the 12, to make the 16 look smaller. They had designed it to have several possible displacements from 6.0 to 7.2 litres, although they didn't build all the variations after testing the first engine on the dyno and in the car. Basically, they were just using the different cylinders developed for the 12 cylinder to change the size. The 12 started out as a 4.5L and evolved into a 5.4L. Add 4 more cylinders and you can see how they got to the displacements they chose.
There is a second engine assembled and displayed in the factory museum. The car was lengthened to accomodate the larger engine and nobody liked the way it handled, so it was shelved. The turbo 12s made a lot more horsepower anyway, once they figured out the fueling problems they had initially. JR |
anyone know if the cooling fan was the same size for the 12 and 16? I'm just wondering, how much thermal "reserve" was built into these engines for the horses they made (vs a high hp street engine for example...) Did they accept higher temps, because of frequent rebuilds? OK maybe this is a tech question...
Peter '79 930, Odyssey kid carrier, Prius sacrificial lamb Missing 997.1 GT3 RSnil carborundum illegitimi |
Is this that engine? I had no idea what it was. This is from the Porsche museum the first part of December.
Rick 88 Cab |
i think it just did the trick if you look at how much power they got out of a 935, or the 917/30 also with the horizontal fan.. i think that if the fan was good for flat12 andflat12Turbo , as long as they had plenty of oil and oil coolers ...
Stijn Vandamme EX911STARGA73EX92477EX94484EX944S8890MPHPINBALLMACHINEAKAEX987C2007 BIMDIESELBMW116D2019 |
Green Skull 006
It's not currently a runner, but I talked to someone from the Museum at RRIII and she said that it is on the list of things to do once they move.
S Reg 823 R Gruppe 246 1955 pre-A Carrera Speedster...x 1974 leichtbau..."Sascha" "It makes me sad. Our cars were meant to be driven, not polished" - Ferry Porsche while surveying a PCA Parade concours field. |
Are they magnesium cases?
David 1972 911T/S MFI Survivor |
Most likely. That's what they look like and that's also what the 12 cylinder engines had.
JR |
Another great pano cover.
1977 911S Targa 2.7L (CIS) Silver/Black 2012 Infiniti G37X Coupe (AWD) 3.7L Black on Black 1989 modified Scat II HP Hovercraft George, Architect |
Green Skull 006
Yes, Mg case.
Do you think there are still some good-ol-boys around the Porsche shops that have both ingenuity, the curiosity and the permission to dream up new marvels like they did when they came up with this 16 cyl. masterpiece?
Green Skull 006
I'm sure they have a bunch of quality engineers but I think just about all of the good guys are gone. Sad, in a way... JR |
