Senior Member
![]() ![]() ![]() Small problem is that I have found a couple of them around the world that I might be able to swing, but the cost of maintenance is simply unbelieveable. Last time I really looked into it we were looking for 20 hours of maintenance on the ground for every flight hour, then we have to input the cost of Jet-A and it goes out of the window.... until I win the lotto!
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
Dog-faced pony soldier
Last time I was out there (it was a while ago now, I've been out of flying for a while unfortunately) I got to park on the ramp right next to them. It was a cool experience being next to those aircraft, but it's still heartbreaking to think the end they're going to meet.
A car, a 911, a motorbike and a few surfboards Black Cars Matter |
Senior Member
Jeff,
Agree and there are more F-4's at Pt. Mugu, DM and Puerto Rico that you can count, but unfortunately 90% of them are turned into drones and shot down. I just want the bits left over. Out of 500 of them or so bet I could turn it into a flying example! Then how to get free jet fuel???
Unregistered
Here's a picture of a B-2 with the vapor cloud around it:
![]() At first I thought BS, a B-2 isn't supposed to go supersonic especially at that altitude and in level flight. I did some checking and found this: http://wilk4.com/misc/soundbreak.htm "Here are some fascinating (for some people anyway) photos and videos of interesting condensation clouds that form around jets as they fly at or near the speed of sound, (often called "going through the sound barrier" or "accelerating past the speed of sound"). Under the right conditions, and even at lower speeds, they sometimes cause a vapor cone effect. Understand that these Prandtl-Glauert condensation clouds can also occur at lower speeds, and are not really a visible manifestation of some kind of a sound barrier being broken." |
Control Group
Your proof only proves you have no idea what you are talking about. as I understand it, it is more like radar absorbing stuff applied to the aircraft
She was the kindest person I ever met |
Tomahawks also sit silently, like the fog, without the unbelievable amount of time and money a manned aircraft requires. Cruise missiles are part of the equation, so are manned bombers. The fact is that yesterday was more manned than unmanned, the future will be a reverse. Can't manage the battle space without a combination. Edit: BTW, in the future the bomber will be unmanned as well
1996 FJ80. Last edited by Seahawk; 02-24-2008 at 12:30 PM.. |
Sammy,
The B-52 is not necessarily cheaper when you add in the additional support aircraft (electronic warfare, more tankers, SEAD, etc.) to conduct missions. In other words what is the real total cost to an aircraft with a full bomb load over a target so that it can deliver it’s payload. This is where the military needs better accounting practices, to get a handle on the real costs. I have seen vapor trails from Herks at rotation so… The fact is the cost to conduct battle field interdiction (let alone CAS) via cruise missiles is not practical from either a financial nor technical standpoint. The heavy bombers can conduct BI further from an airfield or from aerial refueling point. That both the B-1 and B-2 can conduct these missions in higher threat areas is not in dispute. The B-1 I also used in show of force fly bys. Basically a high speed pass by the bad guys w/o using ordnance. Lots of savings. Gotta disagree with Seahawk on UAV/UCAV thoughts. The theory is comms cannot be jammed and even if they can the UAVs will be (semi) autonomous. By problems are that I have seen the command guidance for a Patriot jammed (demonstration) and the history of pre-programming before take-off of missions/targets (look to F-16CJ and EF-111 compared to EA6-B) is not good. Call me a doubter. The question is what is the total cost to get the mission accomplished? S/F, FOG |
Not the one they solicited proposals for last month.
Operational in 2012.
Rick 88 Cab |
AutoBahned
Bombers have dwell time over a target area; cruise missiles don't (they will in th future). Whether that is worth anything near the program cost is another matter.
The next step will be for large planes to control a number of air launched missiles and 'robot' planes. Sort of an AWACs with teeth. You'd like for such a control plane to have low observables, so you can think of the B-2 as like the 959 -- it led to a lot of useful technology in the 964 & 993 even if lost oney itself. Tht doesn't mean I defend the B-2; but it does have its points. |
So how many high-end bombers have you guys crashed this year?
Or maybe Dietrich was flying it?
Jeff '72 911T 3.0 MFI '93 Ducati 900 Super Sport "God invented whiskey so the Irish wouldn't rule the world" |
[QUOTE=RWebb;3790388]Bombers have dwell time over a target area; cruise missiles don't (they will in th future). QUOTE]
There is something to be said about having 16 JDAMS loitering over the battlefield and calling them down when needed. But I guess the ageless B-52 can do the same thing.
David 2015 Audi S3 1988 Carrera Coupe (gone and miss her) |
