TerryBPP's Avatar
Juicy Juice Juice, I like Juice...
For the Dodge!
Old 04-15-2008, 12:34 PM
I'm with Bill
Jims5543's Avatar
Toretto approves:
1978 Mini Cooper Pickup
1991 BMW 318i M50 2.8 swap
2005 Mini Cooper S
Old 04-15-2008, 01:20 PM
TerryBPP's Avatar
I'm turning into such white trash. Its a shame.
Old 04-15-2008, 01:36 PM
What do you know of juice?
Old 04-15-2008, 02:07 PM
That is directly relevant to what type of dodge the nox will be mounted on.
Old 04-15-2008, 02:15 PM
I'm with Bill
Jims5543's Avatar
Do you know the REAL reason they call it laughing gas?
When you hit it for the first time in your truck you will giggle like a little kid doing something bad.
I used to run a 50 shot in my RX7 which when coupled with the turbo = 100 more WHP and I would laugh out loud after using it, it was insane.
2005 Mini Cooper S
Old 04-15-2008, 02:21 PM
gprsh924's Avatar
Jim that picture just made my day....I'm still giggling
It doesn't matter if you win by an inch or a mile...winning is winning.
Garrett
Living and Thriving
Old 04-15-2008, 02:50 PM
TerryBPP's Avatar
Dodge Ram Hemi. Doesn't get anymore country than that.
This kit is adjustable from 75,100,125.
Old 04-15-2008, 03:32 PM
I'm with Bill
Jims5543's Avatar
Wet kit, very good. Upgrade your fuel pump and put in a new fuel filter.
If your chipped, pull the chip out chipped engine + N2O = detonation.
If anything your supposed to retard your timing a little, but you can probably be o.k. with a 75 shot.
After test run check a couple of plugs and see how its running.
Enjoy!!
2005 Mini Cooper S
Old 04-15-2008, 03:35 PM
Dog-faced pony soldier
Porsche-O-Phile's Avatar
Why on earth do they even make dry kits? Alliance with engine rebuilders?
Black Cars Matter
Old 04-15-2008, 03:37 PM
Its cool in a truck... I just wanted to make sure you weren't puttin it in neon like the morons around here do.
TerryBPP's Avatar
Enjoy!!
Zex says my stock pump will cut the mustard. We shall see. I'm putting a fuel pressure saftey switch on just in case.
I have a SuperChips but I will load the 87 octane tune and use 92 gas. Thats been working for all the hemi guys.
Knocking the plugs down. 2 steps cooler.
No clue. Honda guys love them. This is a wet kit.
Ask anyone around here. Terry dont build neons.
Old 04-15-2008, 04:01 PM
From the Zex website.....
Q: What is better, a "wet" or "dry" kit?
A: It all depends on the application. A "wet" kit is ideal for both normally aspirated applications as well as forced induction applications. It can require a little bit more installation time than a "dry" kit, but is easier to tune if greater than stock HP settings are to be experimented with. A "dry" kit is excellent for normally aspirated combinations that have a return style fuel system. They are very easy to install and are a great "first time" nitrous system. It is not recommended that "dry" systems be used on forced induction engines.
I use a Zex dry kit in my Prelude and it runs the same as a wet kit. Change the jets for 50..75..or 100 xtra hp. It was easy to install and I've had it for three years now with no problems at all.
78 SC Targa Black....gone
84 Carrera Targa White
98 Honda Prelude
22 Honda Civic SI
Old 04-15-2008, 05:13 PM
