Experimental Turbine Porsche 928/boeing Car Jet Engine
1974 911s "It smelled like German heaven" http://www.youtube.com/watch?v=6ySt9SeZl9s Last edited by austin552; 05-14-2008 at 06:24 PM.. |
Un Chien Andalusia
That is awesome!
2002 996 Carrera - Seal Grey (Daily Driver / Track Car) 1964 Morris Mini - Former Finnish Rally Car 1987 911 Carrera Coupe - Carmine Red - SOLD :-( 1998 986 Boxster - Black - SOLD 1984 944 - Red - SOLD |
I like it!!!
Byron ![]() 20+ year PCA member ![]() Many Cool Porsches, Projects& Parts, Vintage BMX bikes too |
Dog-faced pony soldier
That is pretty cool, although I'd have found a nicer way to style the hood. . . um. . . "scoop". . . thingy. Right now it just looks like a coffee can up there. Or maybe the exhaust stack from a diesel generator. Or a chimney. Or maybe a grain silo. Or a missile launch tube. Actually that last one WOULD be cool. Should paint it black with some faux rivets and a big # on the side of it.
![]() Top speed only 125?
A car, a 911, a motorbike and a few surfboards Black Cars Matter |
Custom User Title
That's just a simple turbocharger "jet". Easily made but very limited on thrust. Lots of neato stuff you can do with 'em though. Check this:
Jet powered barstool: http://www.turbinegroup.com/page2.html Jet powered beer cooler: http://www.asciimation.co.nz/beer/ Jet powered go-kart (well, you already found one): http://www.youtube.com/watch?v=Ar4dtYBlZ8s Jet powered bicycle: http://www.youtube.com/watch?v=Ar4dtYBlZ8s Possibly the coolest one - jet powered skydiver: http://www.youtube.com/watch?v=2fLOgMQon7c&feature=related
A car, a 911, a motorbike and a few surfboards Black Cars Matter Last edited by Porsche-O-Phile; 05-14-2008 at 08:41 PM.. |
Registered Abuser
I Want One!
MT 930 1987 930 - Gone but not forgotten A man with priorities so far out of whack doesn't deserve such a fine automobile. I would rather wake up in the middle of nowhere than in any city on earth - Steve McQueen американский |
I'm a little confused - if the exhaust comes out the big pipe in the top, how does it go? Is there a driveshaft out the back end or something?
'87 924S (Sold) |
Banned
Those jet boots are TOO cool.
Un Chien Andalusia
A turboprop aircraft uses a gas turbine. It sounds like a jet but it has a propeller driven via a gearbox off the turbine shaft. The engine in that 928 would be driving through a reduction gearbox then most likely on to the automatic transmission. What I don't knowis how you would control speed of the car. I wouldn't have thought that you throttle back the engine so I imagine that the gas turbine runs at a constant speed and there is some way to control how much 'drive' you put out into the transmission?
2002 996 Carrera - Seal Grey (Daily Driver / Track Car) 1964 Morris Mini - Former Finnish Rally Car 1987 911 Carrera Coupe - Carmine Red - SOLD :-( 1998 986 Boxster - Black - SOLD 1984 944 - Red - SOLD Last edited by Aerkuld; 05-15-2008 at 05:26 AM.. |
I'd think it'd be way easier/safer with a manual transmission. Dunno how you go about integrating that with a fully automatic transmission unless a panic stop is done by throwing the throttle to idle and applying the brake (just like any other automatic car). Assumption is that the "idle" setting on the turbine reduces output shaft torque to the point that the clutches on the automatic transmission know what's going on and de-couple the engine from the rear wheels. Pretty big assumption.
Chrysler shaft turbine powered car from the 1960s:
http://www.allpar.com/mopar/turbine.html As for the 928, no more water pump/timing belt changes! I bet a surplus shaft turbine might be cheaper than a rebuilt 928 engine!
911 driver wannabe Collecting data now for use later |
This is about the most work I've seen somebody do to get out of timing belt changes!
'87 924S (Sold) |
Did you get the memo?
"Only one on my block"
‘07 Mazda RX8-8 Past: 911T, 911SC, Carrera, 951s, 955, 996s, 987s, 986s, 997s, BMW 5x, C36, C63, XJR, S8, Maserati Coupe, GT500, etc |
Jay Leno's jet powered motorcycle it just exits by his leg.
Uses a turbine engine from a helicopter. Has no idea how fast it will go. |
