126coupe's Avatar
Had that done a few months back, $350.00
1967 911R "Clone" Race Car 2.0 & 2.5 Twin Plug
1984 Mercedes 500 SEC
1991 Mercedes 420 SEL
1992 Ford F-350 Dually
28' Pace Trailer
Old 05-31-2008, 05:51 PM
Detached Member
Hugh R's Avatar
Incredibly dangerous, yet looks easy. IIRC someone in my city got killed doing those a year or two ago.
Hugh
Old 05-31-2008, 06:24 PM
Bill Douglas's Avatar
Ha, I didn't know I was such an expert DIYer. I've done two garages and found it pretty easy.
I went to a garage door company and asked for a used spring and they said help yourself the skip's over there.
Old 05-31-2008, 06:25 PM
Having watched a pro replace mine (less than $200), I'd be tempted to try it myself (now), but I knew enough to call a pro the first time around
Old 06-01-2008, 03:15 AM
I had one replaced a couple of years ago, I thought it a bargain at $140. The risk/reward ratio made it an easy choice.
Jim
down to jap bikes that run and a dead Norton
Old 06-01-2008, 04:24 AM
Platinum Member
dad911's Avatar
Call someone, change both spring(s) on that door also, along with any other springs the same age.
The spring(s) needs to be properly sized, based on the weight of the door.
Anyone reading this thread that may have tension springs instead of torsion springs like this, make sure you have safety cables running through them, and change them if they are 10+ years old.
Old 06-01-2008, 06:47 AM
Unregistered
sammyg2's Avatar
Piece of cake if you know what you are doing. If you don't then stay away.
The hardest part is getting a spring. Good luck buying one from a store, your best best is to get one on-line. You need to know diameter, length, and right or left hand lay.
I had to pay someone to do it once which pissed me off but I needed to get it fixed quickly and couldn't wait to have a spring shipped and couldn't buy one locally.
Old 06-01-2008, 09:26 AM
That place in Chicago seems like where I got mine last time and they were really cheap i.e. << $350. If I went to the door installers shop in town they were 4 x as much just to buy a spring. Obviously they didn't want me to do it.
Oh yeah, one thing that had me stymied for a while was how to get the dead spring off the cones. I have a huge pipe wrench that worked great.
Rick
88 Cab
Old 06-02-2008, 09:27 AM
Senior Member
Superman's Avatar
Call someone. Homeowners have been killed by those springs.
Mocha 1978 911SC. "Coco"
Old 06-02-2008, 10:06 AM
I don't know...
Someone that can do all this $hit (http://rennlight.com/) probably has the core competencies taken care of.
Rick
88 Cab
Old 06-02-2008, 11:04 AM
TerryBPP's Avatar
I asked this forum the same thing when mine broke last year. Dual spring in fact. Pro charged $80 to fix and and greased and adjusted the drive for free. Watching him mess with it made me glad I called him. Didn't look like fun.
Old 06-02-2008, 11:23 AM
Unregistered
sammyg2's Avatar
A typical spring costs around $40 and takes about 15 minutes to install.
If .... you know how to control the energy.
Tip for those whose spring hasn't broken yet. buy some motorcycle chain lube or whatever and lubricate the thing. Usually these springs break starting with a stress fracture that grows from a corrosion pit. Lube it up, keep it from rusting or wearing against itself and it will last a lot longer.
Old 06-02-2008, 11:28 AM
Control Group
Tobra's Avatar
Correct me if I'm wrong, but I don't think you can even buy that spring in CA unless you're a licensed garage door installer.
my brother bought them and we installed them in a few minutes
Not difficult, but potentially deadly or crippling if you are inattentive.
Replace both springs at the same time.
I can guarantee you that you are more likely to fall and fracture your skull in the bathroom than you are to get hurt in the garage, statistically speaking
Old 06-02-2008, 01:57 PM
Thanks for the feedback - I'm going to sub this one out...
Old 06-02-2008, 02:43 PM
Skunk works
JV911SYDNEY's Avatar
my dad's company is a big manufacturer of garage doors in Aus
the spring is broken and needs replacing. best to call a pro as getting the right amount of tension on it is tricky
surface rust is a non-issue
964 RS-4
Old 06-02-2008, 05:19 PM
