Montana 911
k9handler's Avatar
Send a message via Yahoo to k9handler
Another Math help question?
Ok my semester is almost over, but I am in need of some assistance.
Describe in words the graph of each of these curves below. Include in your description the shape, along with other possible relevant information such as length, width, and center points.
a. Y = 3X2
b. (X-1)2 + (Y-8)2 = 16
c. (X+2)2 + (Y-4)2 = 36
d. Y = X2 - X
H.D. Smith
2009 997.2 S 3.8 PDK
2019 Ford Ranger Lariat FX4 Baby Raptor
2019 Can Am Renegade 1000R XC
2020 Yamaha YFZ450R
Old 08-20-2008, 02:34 PM
Unregistered
sammyg2's Avatar
Is that y=3x times two or y=3x squared?
Old 08-20-2008, 02:46 PM
Unregistered
sammyg2's Avatar
b. CIRCLE radius = 4 center at (1,8)
d. y=x^2 - x =x(x-1)
is a parabola, concave upward, with y-intercept (0,0) and x-intercepts (0,0) and (1,0)
The vertex or bottom of the curve is at (1/2, -1/4).
The axis of symmetry is x=1/2
google is easier than doing math.
Old 08-20-2008, 02:50 PM
Montana 911
k9handler's Avatar
Y = 3X2 is what is posted on the online class.
H.D. Smith
2020 Yamaha YFZ450R
Old 08-20-2008, 02:52 PM
Band.
Y= 3X2.
Y= 6.
Sorry man, you knew someone was gonna do it.
1983 SC Coupe
1963 BMW R60/2
1972 Triumph Tiger
1995 Triumph Daytona SuperIII
Old 08-20-2008, 02:55 PM
Unregistered
sammyg2's Avatar
Confused. Plot for Y=6X or Y=6 times x plus 2?
Standard form nowadays is not the same as standard form was when I was a kid, chisling my homework on a rock.
Old 08-20-2008, 02:58 PM
Montana 911
k9handler's Avatar
my guess is Y=6 times x plus 2...this class will not end soon enough. Thanks for the help though.
H.D. Smith
2020 Yamaha YFZ450R
Old 08-20-2008, 03:19 PM
a. Y = 3X2[/b]
A skinny Parabola. I suspect, based on the other equations, that the formula should read Y=3x^2. It seems unlikely that they'd ask about a straight line like "y=6x" in the same set that askes about circles and other second degree equations which is why I think the 2 should be a ^2. They also don't use the ^ notation on the circle formulas.
circle
The standard equation of a circle with center C(h,k) and radius r is as follows:
(x - h)2 + (y - k)2 = r2
Another circle, but for this one the center is (-2,4)
d. Y = X2 - X
This one is a bit different. It's got a vertical asymtope at x=0, and a horizontal asymtope at y=0. You can graph it here
http://www.freemathhelp.com/equation-grapher.html
just paste this in x^2-x
Old 08-20-2008, 04:00 PM
Montana 911
k9handler's Avatar
Steve that is awesome, thanks a bunch! All of you guys are a savior to my semester.
H.D. Smith
2020 Yamaha YFZ450R
Old 08-26-2008, 06:19 PM
Montana 911
k9handler's Avatar
What are they asking here? For some reason this math stuff just confuses me beyond belief.
Find the equation for each of the following items below:
a. A line that passes through (1, 1) and is perpendicular to the line 3x+4Y=12.
b. A line that passes through (5,4) and has a slope of 2.
c. A line that passes through (9,8) and has a slope of -1.
d. A line that passes though the points (1,2) and (12,24)
e. A circle with a radius of 9 and a midpoint at (3,3)
Solve for the following items:
a. The point on the x-axis that is equidistant (equal distance) from (10,4) and (6,2).
b. The distance between the points (4,4) and (20,4).
c. The distance between the points (1,4) and (19,5).
d. The midpoint between (12, 4) and (18, 6)
e. The midpoint between (-8, -6) and (25, 3)
H.D. Smith
2020 Yamaha YFZ450R
Old 08-26-2008, 06:39 PM
See if I did this right
Rick
88 Cab
Old 08-26-2008, 08:30 PM
answers inline.
------- oops, didn't read carefully enough, that "perpendicular" part will get you every time. Rick's got it right.
-------- same drill, but this time they give you the point and the slope, substitute in and solve
------- ditto
------- now you have to use the info on this page http://www.purplemath.com/modules/strtlneq.htm and then scroll down to where it says " * Find the equation of the line that passes through the points (–2, 4) and (1, 2)."
------ check "example 1" http://www.analyzemath.com/CircleEq/Tutorials.html
------- http://www.purplemath.com/modules/distform.htm
------- ditto
------- http://www.purplemath.com/modules/midpoint.htm
------- ditto
Old 08-26-2008, 08:39 PM
Montana 911
k9handler's Avatar
thanks a bunch fellas for your hard work, I am getting better at understanding it but i'll be damn if I don't feel like I have to guess most of the time until I get it right.
H.D. Smith
2020 Yamaha YFZ450R
Old 08-27-2008, 06:28 AM
Slumlord
Porsche_monkey's Avatar
Take your iPhone to the exam.
84 Cab - sold!
89 Cab - not quite done
90C4 - winter beater
Old 08-27-2008, 06:58 AM
Send a message via AIM to DavidB911
If you need more help, then I would suggest going to the library and looking at some algebra books for more problems. If you can understand how to do these problems, then go there and solve a new set of problems. That will help solidify the steps needed to solve these problems. If you still don't understand the steps to solve these problems, then get into engineering. You will know how to do these problems in your sleep once you graduate.
Old 08-27-2008, 09:15 AM
k9,
I am wondering why you need to take this classwork when it is not so fun for you? What grade are you in? Maybe you have changes schools and missed an important prexquisite class that you should ask your teacher or consuler about.
These are very importnat concepts that you should have a firm grip on before going to college. Are your SAT scores ok?
--s
2002 RS
Artic Bloo
Old 08-27-2008, 09:35 AM
Originally Posted by swang View Post
k9,
--s
hahahahah.
K9, sophomore, right??
How are the hot 16yo chicks in your class?
hahahaha
Old 08-27-2008, 10:33 AM
Slumlord
Steve: I resisted. You gave in to temptation.
84 Cab - sold!
Old 08-27-2008, 10:40 AM
Montana 911
k9handler's Avatar
ha ha I wish I was 16 again....almost 40 and doing what I should have done years ago.
H.D. Smith
2020 Yamaha YFZ450R
Old 09-03-2008, 04:34 PM
