Best way to paint chrome?
I painted the chrome bumper and grill shell of my Dodge Ram about 6 months ago and its starting to peel already. My process was sand all the chrome with 200 grit, clean, sprayed with rattle can primer, then shot it will a lacquer based paint using a gun.
Any products out there that help with the adhesion? |
Have the chrome removed at a plating shop first.
JR |
Unfair and Unbalanced
Location: From the misty mountains to the bayou country
You'll be sanding a while. I don't think you can do it.
"SARAH'S INSIDE Obama's head!!!! He doesn't know whether to defacate or wind his watch!!!!" ~ Dennis Miller! |
Did you get the memo?
You did what I would have recommended. Perhaps you should have it professionally stripped as suggested?
‘07 Mazda RX8-8 Past: 911T, 911SC, Carrera, 951s, 955, 996s, 987s, 986s, 997s, BMW 5x, C36, C63, XJR, S8, Maserati Coupe, GT500, etc |
Banned
I stripped the chrome on a whole car once and painted it flat black. I had it sandblasted.
Feelin' Solexy
I would think that you would need an etching primer to properly adhere to the chrome surface.
Grant In the stable: 1938 Buick Special model 41, 1963 Solex 2200, 1973 Vespa Primavera 125, 1974 Vespa Rally 200, 1986 VW Vanagon Syncro Westfalia, 1989 VW Doka Tristar, 2011 Pursuit 315 OS, 2022 Tesla Y Gone but not forgotten: 1973 VW Beetle, 1989 Porsche 944, 2008 R56 Mini Cooper S |
Banned
No, now that you ask, we just blasted it, roughed it up, and I painted it with Imron, I don't know if they still make it or what. I was making a Knight rider looking 73 El Camino, dark gray, louvered hood, and all trim blacked out. I liked it at the time.
just buy some crhome polish and polish it to a high shine....should start peeling off in about 6 months!!
chance favors the prepared mind 1987 944 n/a 5spd. who remembers dial phones?. 'STOP FIXING THINGS ONE STEP BEFORE YOU BREAK SOMETHING ELSE" |
Be careful if you have something like that sandblasted. You could end up with a wavey part. The thinner the metal, the more careful you need to be.
JR |
Re sand part (sandblast if you have easy access) and prime with something like SEM self etching primer. Good stuff. Without totally removing chroming and doing proper prep it'll peel eventually.
'73 911 and other cool stuff |
Whats a good medium for blasting it? Sand?
I've been wanting to buy a blaster for awhile. Give me a reason.
Confer with a powder coater. They might suggest prepping or not. Powder coating is much more durable than spray paint, but you have to remove from the vehicle.
Sherwood |
Walnut hulls or glass beads work well. Sand can cause respiratory issues. There is also a soda blasting procedure but its designed to not damage chrome or glass.
