Dept store Quartermaster
laptop to plasma via HDMI
Why when I hook up my laptop to my AV system via HDMI does the sound not work? I thought HDMI carried all signals. What am I missing here?
Cornpoppin' Pony Soldier |
you have HDMI on a laptop? which one?
What is the AV system? Last edited by stevepaa; 10-20-2008 at 02:05 PM.. |
Dell XPS1530 The Receiver is a Sony and the Plasma is a Samsung.
so the HDMI from laptop goes to the Sony AV system then to the TV
how about connecting laptop to TV directly via HDMI and see if it is the Sony at fault. |
Band.
Is it possible there's a preference setting in the computer that controls what's coming out of that HDMI output?
Is it really HDMI, or a mini-DVI-HDMI adapter? DVI won't carry sound.
1983 SC Coupe 1963 BMW R60/2 1972 Triumph Tiger 1995 Triumph Daytona SuperIII |
The Unsettler
If it is an HDMI out, (and they do exist, have one in my conference room,) then you do need to set sound out to HDMI in Control Panel. If it's DVI then you need to run separate 1/8 audio out (headphone) to receiver input
"I want my two dollars" "Goodbye and thanks for the fish" "Proud Member and Supporter of the YWL" "Brandon Won" |
Maybe, I'll check into that. It really is HDMI though, it's labeled as such above the connection.
I found it but it appears to already be "on".
Also check the type of HDMI cable you have. Earlier cables had problems carrying bot the vidro and audio data. I think the latest rev. of HDMI cables is 1.3a but do a check with a site like monoprice.com to be sure.
good luck, Michael
-- '87 Diamond Blue Coupe -- '92 Miata -- '06 Scion XB (the wife's) -- '01 Audi S4 (Sold) -- '17 Tesla Model S60 |
I just thought of another potential snag for you. Your receiver might ONLY pass video via HDMI and not audio. The Onkyo home theater receiver I got for the bedroom had that problem.
Michael
Band.
HEEEY that sounds familiar to me as well. Try straight from the laptop to the plasma and see what happens.
I'm going to try straight through. I think you guys are correct.
I feel like Rodney Dangerfield
OK, still no dice. I switched the audio output to HDMI being the default and all looked good but even direct to the TV I got nothing.
I'll call Dell tomorrow.
Please let us know the outcome of this. I am looking into getting a laptop and it ahs to be able to do hdmi output- sound and video.
Thanks Gary |
Do you have another setup where you can verify the HDMI cable is OK?
I do, It was working fine from my DVD player when removed.
On my samsung tv I had to change the sound mode to PCM(?? I'm not by the tv).
Rick 88 Cab |
