AutoBahned
best drill bits??
cobalt??
or Ti (which are just coated, I'm sure) or??? this is all about drilling the center out of a damn roll pin.... maybe it's hardened |
Roll pins are a PITA to drill out. Go slow and use cutting oil. You'll eat up several bits no matter what they are.
Jacksonville. Florida https://www.flickr.com/photos/ury914/ |
MAGA
Yep Yep
German autos: '79 911 SC, '87 951, '03 330i, '08 Cayenne, '13 Cayenne 0% Liberal Men do not quit playing because they get old.... They get old because they quit playing. |
Again, what's a decent bit to buy. I've wondered this a bunch of times. I see lots of "coated with this" and "coated with that", and figure that some of that is just marketing hype. I'd like to buy a nice set of multipurpose bits, and possibly a decent set of occasional use metal bits. I don't drill metal often. When I do it's usually sheet metal and that sort of thing.
ROLL PIN drilling is torture. you need to start with a small enough bit. the bit will bite into the irregular "hole" formed by the rolled material, and snap it. repeat a few times, toss part into yard, kick part...hurt toe, feel dumb. (i've heard)
poof! gone |
Slumlord
Solid carbide bits. Not cheap.
84 Cab - sold! 89 Cab - not quite done 90C4 - winter beater |
My snap-on bits are pretty good, but$$$
1967 911R "Clone" Race Car 2.0 & 2.5 Twin Plug 1984 Mercedes 500 SEC 1991 Mercedes 420 SEL 1992 Ford F-350 Dually 28' Pace Trailer |
For everyday drilling I would recommend just plain old High Speed Steel (HSS). You can sharpen them and they don't chip as easily as carbide.
Matt Kellett 87 Carrera Coupe - Marine Blue 60 MGA - Chariot Red 66 Jaguar MKII - Sherwood Green 09 VW GTI - Candy White |
Broke about 5 Ti bits drilling out my roll pin...
Make sure to check out my balls in the Pelican Parts Catalog! 917 inspired shift knobs. '84 Targa - Arena Red - AX #104 '07 Toyota Camry Hybrid - Yes, I'm that guy... '01 Toyota Corolla - Urban Camouflage - SOLD |
Navin Johnson
try left handed bits
Don't feed the trolls. Don't quote the trolls ![]() http://www.southshoreperformanceny.com '69 911 GT-5 '75 914 GT-3 and others |
AutoBahned
HSS is good for wood IMHO, but not so good for steel.
Vash - I used a Dremel grinding bit to "initiate" the hole - works great for that and the cone shape creates a nice funnel shaped entry. But they can only go so deep... and the deeper they are, the more likely they are to break... I bought the Rigid cobalt bits. Home Despot also have Ti coated, and something else. The other two brands were DeWalt and Bosch or another good brand name. As usual, the sales clerk knew nothing at all about his wares. OTOH, I paid nothing at all either. My credit card points can be transmogrified into HD gift cards so I used that. The Rigid bits came in a nice case and the whole thing was clearance saled down to $20. They worked - I put in another hour drilling and none of the bits broke off. I was then able to... Drive Out the Spawn of Satan. But, with the roll pin out, I now need to be able to get the freakin' clutch lever off the shaft (the pedal cluster). I do not own a puller and my brass hammer has been ineffective in driving the shaft out the other way. Maybe the freakin' thing is not supposed to go out that way?? I am not clear on how a left handed bit would help with a roll pin??? |
What about a step bit (Unibit)? They're mighty strong.
Mike Bradshaw 1980 911SC sunroof coupe, silver/black Putting the sick back into sycophant! |
MAGA
I do have one set of cobalt drills that I have used a couple times in ten years when trying to drill hard stainless. When I rebuilt my pedal cluster, I used a punch and a big effing ball peen hammer to beat the effing roll pin out. In regard to your clutch lever/shaft.... You need a bigger hammer and a beefy brass punch..... HIT THAT SUMBEOTCH!!!!
an air hammer gets them right out and does the shaft too.
AutoBahned
Thx - I have no air tools at all.
No place in town carries brass drifts - already wasted days looking for one. |
Registered abUser
roll pins are hollow with a collapsible slot, dowel pins are solid.
to remove a stuck dowel pin, freeze the pin and heat the surroundings |
Senior Member
One very important principle to remember is the amount of force applied to the pin. WE usually fail to get enough force on it. Take for example the roll pins in Bilstein struts. You can bang a drift against that pin all day long with a full sized sledge hammer and not move it. Or you can drive it out with a medium ball pein hammer. The trick is to get the strut itself to not move. There is plenty of flex in the strut, so the pin will not feel the trauma of the hammer unless some sort of anvil-thing is held to the back of the strut.
Same with the old-fashioned method of releasing tapered shafts from tie rod ends. Whack them HARD with a steel hammer. It goes way easier if you hold another hammer against the back of the tie rod end.
Man of Carbon Fiber (stronger than steel) Mocha 1978 911SC. "Coco" |
The thing with drill bits... if they're not cutting, they're burning. Lots of times its hard to put enough pressure on a hand drill.
Charlie '67 S Tangerine |
Virginia Rocks!
I went to Lowe's and got a set of punches. They are blue Dasco Pro brand. I knocked out my pedal cluster roll pin no problem. I used them on the Bilstein and it was a little more effort. They are not brass, something harder but I'm not sure what. The mistake I originally made with the Bilsteins was not using the right size punch. They are tapered, so I though the pin went into the hole in the pin and the shoulders/taper rested on the outside edge. That has an amazing effect of mushrooming the roll pin. So did an air hammer my friend (a pro mechanic) used on his pedal cluster.
Rosewood 1983 911 SC Targa | Black 1990 944 S2 | White 1980 BMW R65 | Past: Crystal 1986 944 na Guards Red is for the Unoriginal
Randy, I would be my opinion that if you buy industrial bits from someone like McMaster Carr that you will get good merchandise. I have had two boxes of indexed bits for nearly 40 years. The softer ones get resharpend and replaced as needed. Many are original. The brittle ones will snap and I use them carefully when the going gets tough, like stainless. I don't know exactly what they are, so when one goes away, that slot becomes vacant. But they ain't newfangled. |
