Epoxy floor covering
Looking at possibly moving into a house soon with a large garage/shop area to work in. Garage floor is bare concrete or cement, and was thinking about doing an epoxy floor coating if the landlord would permit. I don't see why he wouldn't.
Anyone got any good tips on this? Brands to stay away from? Anything offer water leakage protection? Insulative properties, etc? Garage is large enough to hold 3-4 cars.
'85 911. White - 53,000 miles bought 3-16-07. "Casper" '88 924S. Blue - 120k miles bought with 105k miles. '94 968 Coupe - White - 108,000 miles bought 9-28-17 '09 Cayman - Grey - bought 9-8-20 |
JW Apostate
'Shot blast' the slab prior to installation.
KT
'74 914-6 2.6 SS #746 '01 Boxster |
I wish my tenants wanted to epoxy their garage floors! All mine want to do is be late on rent and leave the garage full of crap when they leave!!!
1997 C4S stock...ish 1970 911T Restored Hot Rod....Sold ![]() http://forums.pelicanparts.com/porsche-911-technical-forum/418411-here-my-new-old-project-lilly.html |
Sultan of Sawzall
When I epoxied my new garage floor 6 years ago, I used a dilute citric acid solution to lightly etch. Still looks like the day I painted it, nothing has eaten through it! I used the cheap-o Rustoleum kit and it worked just fine. I know there are better products out there, but this has held up fine. Just be sure to have someone to help you "cut-in" your edges as you roll the main portion of the floor, because you've only got 30 minutes to work it & throw the paint chips (if you choose). Good luck on your project!
Gruppe B #319 2 '86 911 Carrera coupes (red & white) '66 Corsa convertible 140/4(red) '66 Monza coupe 110/PG(white) '95 993 cabriolet (wife's) |
Like everything, it's all in the prep. I used the Griot's floor paint about 6 years ago and I've not had any peel off. I used an acid wash first to break the skin on the concrete, this keyed the concrete to allow a good paint bond.
Matt Kellett 87 Carrera Coupe - Marine Blue 60 MGA - Chariot Red 66 Jaguar MKII - Sherwood Green 09 VW GTI - Candy White |
PPG industrial floor epoxy is good if you have a PPG industrial/marine dealer handy.
2014 Cayman S (track rat w/GT4 suspension) 1979 930 (475 rwhp at 0.95 bar) |
Have you thought about going with an acid stain topped with clear top coat? Several garages in my area have this and if you use 2+ stain colors it can look incredible. I did a 2 color stain on my BBQ island (poured concrete top) and it looks like worn leather. I'm definitely going that route in my 3 car garage. Cheap and easier than paint.
Edit- here's a pic of my BBQ island
i got my epoxy finish from my benjamin moore dealer, custom tinted to match the trim on garage. cost between rustoleum and u-coat it.+1 on the prep.
Gator 99 996 c4 |
Navin Johnson
Check to see that you wont have a problem from moisture coming up through the slab..
Tape a piece of clear plastic to the the floor... maybe a 2 foot square of plastic using duct tape..Check the plastic after a day and see if any moisture is visible.. If you see alot of condensation, you would be better with a stain... Excess moisture will cause the epoxy to bubble and delaminate.. I live quite close to the ocean and bays and estuaries... ground water is only a few feet beneath the ground here.... unless a barrier is placed under a slab here, most garage floors don't do well with epoxy coatings (here)
Don't feed the trolls. Don't quote the trolls ![]() http://www.southshoreperformanceny.com '69 911 GT-5 '75 914 GT-3 and others |
I'm with Bill
Make sure there is no grease or oil or any kind of oil based anything left on the concrete. This will cause the epoxy to not stick.
Electrical problems on a pick-up will do that to a guy- 1990C4S |
Like Tim said, you should check your concrete for moisture somehow.
My folks had the griot's garage paint professionally applied in their garage almost 15 years ago. It still looks the same as the day it was put on. No lifting whatsoever. Theirs looked so good, I had the same guys do my garage, with the same paint. Mine lasted 3 years or so before moisture rising up from the concrete got to it. |
Go to the www.garagejournal.com they have a whole section just on garage floors. They have more information than you will ever need.
2 - 75 914 Sold 76 912E Sold ![]() 81 911SC Sold 05 Boxster Sold ![]() 06 Cayman S Sold 14 Cayman S ![]() 14 Explorer XLT DD |
I had epoxy professionally installed (Dupont 2-part) about 3 years ago. It looks great....but....I have a problem with the garage door seal sticking to it. It is had to open after a day...and almost impossible to free after a week. Eventually the seal shreds and I replace it to start the cycle again. Anyone else have this problem?
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo http://www.pelicanparts.com/gallery/fintstone/ "The problem with socialism is that you eventually run out of other people's money" Some are born free. Some have freedom thrust upon them. Others simply surrender |
Non Compos Mentis
Don't use the water-based "One-part Epoxy" from Home Depot.
My garage floor at home is chipping/peeling. Out at the airport, I painted the hangar floor with Amaron products from Parker Paint. Two coats primer, two coats high-gloss finish, after an acid wash. Couldn't be happier. |
As others have stated, go with quality! (Griots or similar)
I went with Lowe's epoxy and the hot tires baked it off within 2 years! Prep work on the concrete is paramount.
Rod... 2010 - 997 PDK, Black on Black, Daily driver. 1987 - 930 Grand Prix White, Not looking for crazy HP, just harmony! |
Good stuff guys. thanks.
I looked at the floor again today and it does look like there' some old grease/oil staind etc. Can't really tell for sure about water, but it's something I'll look into. I did some searching and it looks liek there some sort of water vapor kit available...
Byron ![]() 20+ year PCA member ![]() Many Cool Porsches, Projects& Parts, Vintage BMX bikes too |
I don't have any personal experience, but have heard that if you plan on doing any welding, epoxy is NOT the way to go.
Josh 85 M491 Coupe - "Fat Bastard" |
Yes. No luck. It is like the chemicals in the floor melt the seal a little and make it stick. It doesn't matter if it is hot or cold either.
How about placing one of those rubber seals on the floor, I think they are used for stopping water creeping under the door, but I think would work for your application to stop the door sticking to the floor.
