stevepaa's Avatar
well, rip the old stuff up
then prep the ground deep to about 12 inches with sand, lime, gypsum if you have any clay
roll flat and then have the sod installed
you can't get a blue grass to grow there?
Old 04-15-2009, 09:08 AM
Unregistered
sammyg2's Avatar
Originally Posted by schamp View Post
There are some products you can use to kill the weeds and crabgrass and doesn't kill the bermuda. MSMA is one, I believe and there are others. You might be able to use that and overseed. Would save a lot of work.
LOL I pay $50 per pint of a product called turflon ester to kill bermuda but not my fescue
Luckily one ounce covers 1000 sq. ft.
Old 04-15-2009, 09:12 AM
I was thinking about getting the soil tested as well...sounds like it might be a good idea.
As far as a connection to A&M, if you count 5 years of my life there, Class of 1994, then YES!
I was thinking about the sprinkler issues, I will certainly mark the location of the heads, I was thinking about changing the design of the system as well since I have put in new flower beds since the yard was originally installed. The heads are the kind that pop up about 3 inches before spraying so the depth shouldn't be too much of an issue.
Rick
1984 911 coupe
Old 04-15-2009, 10:49 AM
Did you get the memo?
onewhippedpuppy's Avatar
Get the sprinkler system changed before you resod. You don't want to be trenching in new lines through your new grass.
‘07 Mazda RX8-8
Old 04-15-2009, 12:06 PM
