Help me with these vectors, please
Problem:
u=i-3j v=ai+j Vectors are parallel. Find a. What I have so far: We know that: Code:
a₁a₂+ b₁b₂
cos Θ = ---------------
|u||v|
cos Θ = 1
(a)(1) + (-3)(1)
1 = ------------------
|u||v|
|u| = √(1² +(-3)²)
|v| = √(a² + 1²)
So what you get when you put them in is this: Code:
a - 3
------------------ = 0
√(10) √(a² + 1)
How on earth do you solve for a? The answer is: -1/3 The other way to attack this is to say: u=kv where k is a constant scalar since the two vectors are parallel, right? How can this be used? |
Seems you don't need an equation, just draw the two vectors on a X-Y chart.
i is the unit vector on the x-axis, i.e. the vector from (0,0) to (1,0) j is the unit vector on the y-axis, i.e. the vector from (0,0) to (0,1) unit vectors in red below vector u = i - 3 j is the vector from (0,0) to (1,-3). In blue below. It takes 1 step right for every three steps down. vector v = a i + j. Vector v is "parallel" to vector u. In green below. I guess that must mean it is parallel as in lies on the same line, but it must face the other way since the j coefficient is positive. It is the vector from (0,0) to (a,1). It takes 1 step left for every 3 steps up. But since it only takes 1 step up, it can only take 1/3 step left. Thus a = -1/3. Make sense? Maybe I didn't understand the problem or the word "parallel".
1989 3.2 Carrera coupe; 1988 Westy Vanagon, Zetec; 1986 E28 M30; 1994 W124; 2004 S211 What? Uh . . . “he” and “him”? Last edited by jyl; 04-28-2009 at 04:19 PM.. |
Check this --> http://www.onlinemathlearning.com/parallel-vectors.html
Jordi Riera '84 930 (modified) |
If you need to answer it using a computation, see here
http://www.onlinemathlearning.com/parallel-vectors.html This also gives you a = -1/3 (1, -3) = k (a, 1) 1 = k a => k = 1/a -3 = k 1 = 1/a 1 => a = -1/3 Edit: Oops, funny/sorry, jordi pointed to the same link.
1989 3.2 Carrera coupe; 1988 Westy Vanagon, Zetec; 1986 E28 M30; 1994 W124; 2004 S211 What? Uh . . . “he” and “him”? |
Yeah was already there. Can't seem to wrap around how to apply it to the question. Drawing a picture gets me to the answer, but it doesn't do anything for the application of the material in the section of the book though.
So when given two vectors that are parallel (or anti-parallel I guess), using u=kv is the best way to attack it? Last edited by exitwound; 04-28-2009 at 05:13 PM.. |
My question that remains is this:
This equation: Code:
a₁a₂+ b₁b₂
|u||v|
Jeepers you guys are smart. It's Greek to me...
87 blk coupe |
Semper drive!
Do these Vectors help?
![]() ![]() ![]() Randy
84 944 - Alpine White 86 Carrera Targa - Guards Red - My Pelican Gallery - (Gone, but never forgotten )One Marine's View Igitur qui desiderat pacem, praeparet bellum |
No. I'm already frustrated.
Semper drive!
Ahhhhh, a classic case of Vector Envy!
![]() Randy
In the equation in the initial post, square both sides. Left side is still 1. Right side is a polynomial numerator divided by a polynomial denominator, and will have gotten rid of the SQRT. Move denominator to numerator of left side, rewrite equation in polynomial = 0 form, and solution will be clear.
Banned
I am SO glad there we guys like you to cheat off in HS. Now give me your lunch money.
I thought you'd been banned for starting the Miss Australia thread.
u=2i+3j v=ai-j angle between vectors: 2pi/3 This ends up with some incredibly obnoxious polynomial equal to zero, which doesn't have any obvious solutions. Solving for it via a calculator comes out with two answers but the book only lists one. |
The dot product works doesn't it? The cos(0) = 1 so from your equation above Sqrt(10)*sqrt(a^2+1) = a-3 Square both sides 10*a^2+10=a^2-6*a+9 9*a^2 + 6 * a + 1 = 0 a^2 + 2/3 * a + 1/9 = 0 a=-1/3
Rick 88 Cab |
if they are parallel then the coefficients must have the same relations
1/a=-3/1 a=-1/3 |
