exitwound's Avatar
Help me with these vectors, please
Problem:
u=i-3j
v=ai+j
Vectors are parallel.
Find a.
What I have so far:
We know that:
Code:
              a₁a₂+ b₁b₂
 cos Θ =    ---------------
                  |u||v|
cos Θ = 1
            (a)(1) + (-3)(1)
        1 = ------------------
                  |u||v|
|u| = √(1² +(-3)²)
|v| = √(a² + 1²)
So what you get when you put them in is this:
Code:
                  a - 3
            ------------------    = 0
            √(10)  √(a² + 1)
How on earth do you solve for a?
The answer is: -1/3
The other way to attack this is to say:
u=kv where k is a constant scalar since the two vectors are parallel, right? How can this be used?
-Patrick
Black 1986 944
Old 04-28-2009, 02:38 PM
jyl jyl is online now
jyl's Avatar
Seems you don't need an equation, just draw the two vectors on a X-Y chart.
i is the unit vector on the x-axis, i.e. the vector from (0,0) to (1,0)
j is the unit vector on the y-axis, i.e. the vector from (0,0) to (0,1)
unit vectors in red below
vector u = i - 3 j is the vector from (0,0) to (1,-3). In blue below. It takes 1 step right for every three steps down.
vector v = a i + j. Vector v is "parallel" to vector u. In green below. I guess that must mean it is parallel as in lies on the same line, but it must face the other way since the j coefficient is positive. It is the vector from (0,0) to (a,1). It takes 1 step left for every 3 steps up. But since it only takes 1 step up, it can only take 1/3 step left. Thus a = -1/3.
Make sense? Maybe I didn't understand the problem or the word "parallel".
Old 04-28-2009, 03:17 PM
jriera's Avatar
Send a message via AIM to jriera Send a message via Yahoo to jriera
Check this --> http://www.onlinemathlearning.com/parallel-vectors.html
Jordi Riera
'84 930 (modified)
Old 04-28-2009, 03:19 PM
jyl's Avatar
If you need to answer it using a computation, see here
This also gives you a = -1/3
(1, -3) = k (a, 1)
1 = k a => k = 1/a
-3 = k 1 = 1/a 1 => a = -1/3
Edit: Oops, funny/sorry, jordi pointed to the same link.
Old 04-28-2009, 03:30 PM
exitwound's Avatar
Yeah was already there. Can't seem to wrap around how to apply it to the question. Drawing a picture gets me to the answer, but it doesn't do anything for the application of the material in the section of the book though.
So when given two vectors that are parallel (or anti-parallel I guess), using u=kv is the best way to attack it?
-Patrick
Black 1986 944
Old 04-28-2009, 04:10 PM
exitwound's Avatar
My question that remains is this:
This equation:
Code:
              a₁a₂+ b₁b₂
                  |u||v|
should be able to be used whether or not the angle is 20°, 160°, or pi/4 or 0°. Correct?
-Patrick
Black 1986 944
Old 04-28-2009, 04:30 PM
Jeepers you guys are smart. It's Greek to me...
87 blk coupe
Old 04-28-2009, 04:38 PM
Semper drive!
rcecale's Avatar
Do these Vectors help?
Randy
84 944 - Alpine White
86 Carrera Targa - Guards Red - My Pelican Gallery - (Gone, but never forgotten )
One Marine's View
Igitur qui desiderat pacem, praeparet bellum
Old 04-28-2009, 04:55 PM
exitwound's Avatar
No. I'm already frustrated.
-Patrick
Black 1986 944
Old 04-28-2009, 05:02 PM
Semper drive!
rcecale's Avatar
Ahhhhh, a classic case of Vector Envy!
Randy
One Marine's View
Old 04-28-2009, 05:16 PM
jyl's Avatar
In the equation in the initial post, square both sides. Left side is still 1. Right side is a polynomial numerator divided by a polynomial denominator, and will have gotten rid of the SQRT. Move denominator to numerator of left side, rewrite equation in polynomial = 0 form, and solution will be clear.
Old 04-28-2009, 07:28 PM
Slackerous Maximus
HardDrive's Avatar
I am SO glad there we guys like you to cheat off in HS. Now give me your lunch money.
2022 Royal Enfield Interceptor.
2014 Triumph Bonneville T100.
2014 Cayman S, PDK.
Mercedes E350 family truckster.
Old 04-28-2009, 07:41 PM
jyl's Avatar
I thought you'd been banned for starting the Miss Australia thread.
Old 04-28-2009, 07:44 PM
exitwound's Avatar
The solution is not clear though on future problems.
u=2i+3j
v=ai-j
angle between vectors: 2pi/3
This ends up with some incredibly obnoxious polynomial equal to zero, which doesn't have any obvious solutions. Solving for it via a calculator comes out with two answers but the book only lists one.
-Patrick
Black 1986 944
Old 04-28-2009, 08:53 PM
This equation:
Code:
              a₁a₂+ b₁b₂
                  |u||v|
The dot product works doesn't it? The cos(0) = 1 so from your equation above
Sqrt(10)*sqrt(a^2+1) = a-3
Square both sides
10*a^2+10=a^2-6*a+9
9*a^2 + 6 * a + 1 = 0
a^2 + 2/3 * a + 1/9 = 0
a=-1/3
Rick
88 Cab
Old 04-28-2009, 09:27 PM
stevepaa's Avatar
if they are parallel then the coefficients must have the same relations
1/a=-3/1 a=-1/3
Old 04-28-2009, 09:40 PM
