Make Bruins Great Again
Por_sha911's Avatar
Question Can I "fix" a plug wire?
Ford F150 has a cut in a spark plug boot. It runs great until I go through a puddle of water and it arcs on the exhaust header. Its a small cut/hole about the size of a ballpoint pen point. Is there some sealant that I can fill in the cut in the rubber boot until I have time to locate the old wires from when I changed these out? I'm thinking some kind of silicone sealant... I'm not looking for a permanent fix.
Joe
Old 05-06-2009, 06:54 PM
Cars & Coffee Killer
legion's Avatar
Electrical tape?
5 liters of VVT fury now
-Chris
Old 05-06-2009, 06:56 PM
In the shop at Pelican
Jared at Pelican Parts's Avatar
RTV or shrink tubing. I've used both for this very exact thing.
Old 05-06-2009, 07:16 PM
Por_sha911's Avatar
I'm thinking Elec tape will unravel with the heat. Shrink tubing won't work cause its on the boot and it would be impossible to find a piece that big in diameter. RTV silicone has possiblities. Suggested brand that I can find at the local Lowes or FLAPS?
Joe
Old 05-06-2009, 07:34 PM
Registered abUser
TerryH's Avatar
Heat shrink comes in large sizes.
Wrap it in aluminum foil or you could change it out with a wire that isn't as susceptible to water intrusion.
'81 911SC Coupe SOLD
Old 05-06-2009, 07:50 PM
And you don't buy a new one because . . . ?
We're talking F-150 here right?
Rick
88 Cab
Old 05-06-2009, 08:15 PM
Because wrapping it in electrical tape and aluminum foil for the next 6 months, or major rain (whichever comes first) is easier than going to Autozone and getting the $15 set of plug wires for his common easily repaired domestic truck.
Mike Bradshaw
1980 911SC sunroof coupe, silver/black
Putting the sick back into sycophant!
Old 05-06-2009, 08:18 PM
Rick Lee's Avatar
I messed up a plug wire boot on the 993 plug wire change, which, if you've read anything about this job, is about as fun as a headliner replacement or an engine rebuild. I taped it up and it's been fine for three years now.
2022 BMW 530i
2021 MB GLA250
2020 BMW R1250GS
Old 05-06-2009, 09:31 PM
Just thinking out loud
mattdavis11's Avatar
A plug boot is less than $2 at the local parts store.
91 FJ80
84 Ram Charger (now gone)
Old 05-06-2009, 10:35 PM
Por_sha911's Avatar
I don't know where you guys shop but a set of wires is more than $15 and the FLAPS didn't have just the boot or one wire. That aside, I don't have time to change out the set and wanted to do a quick fix to tide me over till I had time to find the old set I replaced and dig out the old wire which worked fine but was replaced just cause (which you should already know if you took time to read what I originally wrote rather than use all your energy looking for witty put downs).
Joe
Old 05-07-2009, 05:50 PM
Zeke's Avatar
Jeez, at 15 that's cheap compared to our cars. But, he's right, you can buy "components." Hey, if tape works, it works. Put a tie wrap around the tape if heat is a problem.
Old 05-07-2009, 05:55 PM
canna change law physics
red-beard's Avatar
There is another form of electrical tape that fuses over time.
Option B: Electrical tape with a tie wrap over it.
James
Red-beard for President, 2020
Old 05-07-2009, 07:37 PM
