Any closed loop chilled water experts?
We have a 3000 gallon closed loop cooling water system (two 240 ton chillers) at work. I can't find any real "experts" on the system. I can find plenty of salesmen who want to sell us water treatment, but none who really seem to know what they're talking about.
Most of the water treatment systems are for open loop, cooling tower systems. I have found some info on chemical treatment to add to the water and I'm leaning towards trying those although the original installer mentioned off the record that pure water was fine. If we don't add chemicals to the water, I wonder how often we should change the water. Thanks for any advice
2014 Cayman S (track rat w/GT4 suspension) 1979 930 (475 rwhp at 0.95 bar) Last edited by David; 06-04-2009 at 07:11 AM.. |
Senior Member
Have you ever gotten the water checked for what minerals and such are in it? That would be my first step.
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
Registered abUser
Not sure what you're asking, but don't you want water treatment? Maintaining a PH level, descaling, and hardness isn't too difficult on a closed system. Piece of cake compared to evaporative towers as there isn't nearly the amount of make-up water being added to the system. You can service this system yourself or choose not to service at all.
Usually rodding out the condensors/heat exchangers annually can be beneficial too. Last edited by TerryH; 06-04-2009 at 08:03 AM.. |
Unregistered
We use GE/BETZ for our water conditioning and they do all the sampling and testing, but like you said that's an open coolling tower situation.
canna change law physics
I guess it first depends on what the rest of the materials are in the system. Fully demin water is corrosive, so usually you need an anti-corrosion additive. If the materials in the system contain cast iron, you'll be changing it more often than aluminum, copper or stainless.
What is the chilling application?
James The pessimist complains about the wind; the optimist expects it to change; the engineer adjusts the sails.- William Arthur Ward (1921-1994) Red-beard for President, 2020 |
This is for the HVAC system on our 100,000 sq ft machine shop. It has two 240 ton chillers and 15 air handers. The water loop is about a 1000 feet. The majority of the piping is carbon steel.
As much as I hate GE, they do make good products so I was looking at the GE Corrshield, but I'll get the water chemistry checked first.
2014 Cayman S (track rat w/GT4 suspension) 1979 930 (475 rwhp at 0.95 bar) |
Slumlord
We just added a anti-fungal / anti-bacterial agent a few times per year. Started with city water. It has been in there ten years now with the occasional top up.
84 Cab - sold! 89 Cab - not quite done 90C4 - winter beater |
This is what one looks like that is really-really-really dirty. ![]() ![]() That is a combination of rust particles and cosmoline. It was in the water system.
The water (tap water) is still almost crystal clear after a year with no additives, but I'll get it sampled and report back
UnRegistered User
There are lots of suppliers for water treatment. Try to find one soon.
New systems are degreased with a scrubbing solution with several water changes afterward. I would strongly recommend at least a good inhibitor from a reliable supplier that will give you a test kit with the purchase. Once a closed loop is set up it really needs very little attention. What chillers were installed?
Bill K. "I started out with nothin and I still got most of it left...." 83 911 SC Guards Red (now gone) And I sold a bunch of parts I hadn't installed yet. |
I'm not in my office so I don't have the model handy, but they're 239 ton Carrier units.
