What would be a better Autocross car?
I am looking for a beater to run autocross in to save the paint on my precious 944. I have kinda narrowed my sights on a 914 or a MkI GTI. I know the cost of entry will be close on both and the parts will be cheaper for the GTI. But in the end will the handling of the 914 make the cost worth it? Or should I just buy a good GTI put some suspension on and drive it like I stole it?
Old 06-05-2009, 10:24 AM
Z-man's Avatar
Tough question. I'd say both the 944 and 914 have an edge on the VW GTI due to the rwd layout.
But the GTI has more power than the 914, unless you are seeking a modified 914.
I can tell you at the last NNJR PCA autocross, a modified 914 took the top honors (Fastest Time of the Day). Smokin' hot driver, and a well setup car. I have NEVER seen a GTI take FTD in any autocross.
-Z-man.
2010 Cayman S - 12-2020 -
2014 MINI Cooper S Coupe - 05-17 - 05-21
1989 944S2 - 06-01 - 01-14
Carpe Viam.
Old 06-05-2009, 10:32 AM
Takin' hard left turns
Amail's Avatar
I'd say get a beater 944. There are tons for sale for $3k and under, you're familiar with how they handle, and you'll have lots of competition. If you're in PCA, compete in GS, GP or 944 Spec and you'll have a serious load of fun.
A reasonable 914 won't be as cheap or competitive as a 944.
Old 06-05-2009, 10:39 AM
Not sure what risk there is to paint in an autocross but the 914 would wax a 944 or GTI.
JR
Old 06-05-2009, 10:41 AM
Amail's Avatar
I retract what I said about 944's beating 914's. All things being equal, the 914 should beat the 944. Looking back at the results of my last AX I see that 914's took 5th (AM), 13th (AI), 16th (AI) fastest. Fastest 944 was 19th (944 Spec).
Old 06-05-2009, 10:54 AM
Not sure what risk there is to paint in an autocross...
JR
x2. You have a good autocross car, just drive it.
1987 GP White 930
1977 Ford Bronco
Old 06-05-2009, 10:59 AM
Custom User Title
Dave L's Avatar
+3, the chance to mess up your paint is about as likely as hitting a zebra
Old 06-05-2009, 11:15 AM
pwd72s's Avatar
Check the history of Porsche Parade autocrosses. More often than not, the TTOD car is a 914...
Old 06-05-2009, 11:17 AM
s_wilwerding's Avatar
Check this out:
http://www.914club.com/bbs2/index.php?showtopic=143731
This guy has built a great AX car out of a 914, and is priced at, what I think, is a steal.
Steve Wilwerding
1998 3.4L Zenith Blue Boxster
2009 Meteor Gray Cayenne
Old 06-05-2009, 11:39 AM
What, no miata option (which would be better than the 914 and GTI)? Cheap, reliable (bottom end from a turbo car similar to an SC), cheaper parts, lots of aftermarket support including factory support. You can purchase parts from Mazda's racing stuff if you've got 2 autoX under your belt, I think is the rule.
Old 06-05-2009, 11:43 AM
Komenda Fan's Avatar
When miata's show up at autox I attend, they leave everyone for dead. Between your choices, 914 would have to be the way to go... but your paint should be fine in an autox...
2012 911 Black Edition Cabriolet
2008 Cayman S Grey on Black - flooded, written off
1977 930 Turbo Carrera Black on Red #411
1987 951 Black on Black - sold to make room for the 930
1972 911 2.7 - I regret selling her every single day....
Old 06-05-2009, 11:47 AM
914s perform well for a 40 year old design but unless you want to spend big dollars and time you won't be winning your class at a SCCA a/x. Ask me how I know.
Old 06-05-2009, 11:56 AM
Banned
get a go cart
Old 06-05-2009, 11:58 AM
austin552's Avatar
Can't the 914 take a larger porsche motor?
1974 911s
Old 06-05-2009, 12:07 PM
You can fit 911s motors in 914s. You can fit V-8s in 914s. I think you can get just about anything you want in one. I think SBCs aren't uncommon. I think I've also heard of Cadillac Northstar V-8s in them.
Old 06-05-2009, 12:48 PM
Non Compos Mentis
Lots of good ideas here, but they all depend on one unanswered question:
What class do you want to run?
Old 06-05-2009, 02:11 PM
I'm with Bill
Jims5543's Avatar
Just drive your 944 and stop being a pansy, cars are meant to be driven.
I Autocrossed my 911 quite a few times I did less damage to the paint hitting cones than I do to it when I took road trips to the mountains with it. I AX my RX7, which when I started 8 years ago had pristine paint. Guess what, the paint is not shot from Autocrossing its shot from being old. I am about to drop it off for a repaint and I fully intend on AXing it once its done.
The money you will drop on another car, sorting it out mechanically, then upgrading it to be competitive (where you could have done the same to the 944) then buy tires for it....... yada....
You could get the 944 painted again and again.
I vote AX the 944 and stop worrying about the cone rash, it waxes off. Even better don't hit them.
1978 Mini Cooper Pickup
1991 BMW 318i M50 2.8 swap
2005 Mini Cooper S
Old 06-05-2009, 03:10 PM
Zeke's Avatar
With a LOT of work done on it. A stock 914 with the 4 cyl engine is a roach. I've had 2, one was a full on race car. It took 10 grand and a year's worth of work to make it work. Won it's class the first time out at AX under new ownership. I never AX'd it, only DE. With 130HP and at 2000 lb., they are fine. That's far from stock.
TTOD 914's are usually flat out GT class race cars.
Old 06-05-2009, 03:19 PM
fastfredracing's Avatar
I am with milt on this one, If you are looking for a budget auto x car, the GTI is the way to go. While a sorted 914 is a super fast auto cross car, you will spend a small fortune getting it there. Unless you buy someones already set up car. Stock 4 cyl 914's were pretty slow at our local auto crosses.
I hand grenaded my sc a while back, and while I was reassembling ( 2 years), I ran a 1991 16V GTI. I think I spent about $1500.00 on it , to set it up, and it was a blast to drive, easy to drive, and was fairly competive. I ran the snot out of it for 2 seasons, broke one motor mount, and ate one set of tires. I think my set up was real simple, H@R sport springs, koni sports, a large rear addco sway bar, lots of negative camber ( $15 crash bolts ) and victoracers. While I never FTD'd, I was usually pretty close to the fast guys, and this car was an absoloute blast . Add a limited slip, and you are really talking. Just my .02
No left turn un stoned
Old 06-05-2009, 03:35 PM
Custom User Title
rammstein's Avatar
For cheap AutoX, I'm under the impression that Miatas are the way to go. No matter what though, cones won't hurt your car. Unless you think your car is like a concours car or something.
Old 06-05-2009, 03:46 PM
