Dottore's Avatar
Attention cyclists: delicate question....
Been trying to spend more time in the saddle, but suffer from the dreaded "nutsack chafe". How do you serious riders avoid this???
(I got the gel seat and bicycle shorts already—but they don't help. At least not enough.)
My neighbour douses himself with a bucket of baby powder before he rides, and when he takes off he looks like Johnny Depp in scene from "Blow". Not sure I want to go that route.
_____________________
These are my principles. If you don't like them, I have others.—Groucho Marx
Old 06-19-2009, 10:32 AM
jtkkz's Avatar
My freind who who I ride with uses vaseline..
Early Porsche Reproduction Products:
http://sycipworks.tripod.com/
Old 06-19-2009, 10:43 AM
Dog-faced pony soldier
Porsche-O-Phile's Avatar
I find a harder (non-gel) saddle actually is better. The gel ones simply contour to your soft tissue and increase the amount of rubbing that goes on - at least this is what I found...
Try different shorts (including bib shorts) until you find ones that work. *shrug* Don't know what else to tell ya. Have you tried adjusting seat and riding position? A few millimeters makes a big difference. You want your ass bones on the seat and carrying the weight - you don't want your soft tissue (buttocks, muscles, etc.) carrying any weight. This will make you uncomfortable and could help create extra movement "down under" that might be related to your problem.
I'd experiment with:
- saddle
- saddle position (geometry)
- shorts type
The lotions and creams and powders don't do jack - at least I don't think so. Once you're riding hard stuff gets sweated off anyway. If you're riding more than an hour I'd say it's not doing anything. Or else you're not riding hard enough... Just keep your shorts/gear clean and shower up right after you ride.
Black Cars Matter
Old 06-19-2009, 10:45 AM
- saddle
- shorts type
Black Cars Matter
Old 06-19-2009, 10:46 AM
canna change law physics
red-beard's Avatar
Butt Butter
or really
Butt'R
Butt everyone calls it Butt Butter
James
Red-beard for President, 2020
Old 06-19-2009, 10:48 AM
use saddle with hole in between. stay away from padded foam or gel. not good for long distance. the less cushion the better. also, pick a saddle that supports your butt bone only and slim up front. get a jar of assos brand chamois cream. it has a cooling agent. hope it works out for you. good luck.
Old 06-19-2009, 10:52 AM
crb07's Avatar
If you purchased your bike recently or use a regular shop take your bike there in your shorts and shoes that you ride in. Get properly fitted and a saddle that they recommend if yours is not comfortable. (if your shop is crap and they are not professional you are waisting your time). If your bike does not fit you or is not set up properly you may be doing more damage to your body than good. If you still have chafe try any of the products your local shop sells for this.
If you are sure your bike is set up correctly then I would say it is your shorts or saddle. I can due 3-4 hour rides 4-5 times a week and have no problems in htis area.
Chris
89 930, 87 930, 86 930 Ruf BTR tribute, 89 Ruf CTR tribute
Old 06-19-2009, 10:53 AM
cantdrv55's Avatar
Forget the gel saddle and shorts. Non-cyclists think the softer the saddle and also the shorts, the more comfortable you'll be. The exact opposite is true. As a matter of fact, a lot of touring cyclists, those who vacation on their bikes, swear by Brooks leather saddles. Those things when new is like riding on concrete saddle but when worn in are wonderful, I've heard.
Get a good leather saddle. I use the men's Terry Fly seat. They're about $100 or so. Also, invest in good bib shorts. I wear Pearl Izumis that cost about $135. Assos, which a lot of cyclists love, are about $200 or so. My PIs suits me just fine though. Lastly, your riding position can be the cause as well. Is your saddle pointing up slightly? It probably should not.
Old 06-19-2009, 11:06 AM
MichiganMat's Avatar
Send a message via AIM to MichiganMat
Ditch the gel-seat, put a proper saddle on it. Check out http://www.pricepoint.com for good cheap gear.
Also check out Chamios Butt'r, Dznuts, etc...
As mentioned above:
- Is your saddle level or pointed upwards? I ride mine pointed downwards, put the pressure on the buttbones
- Also, I ride a cheap hard saddle with basic roadie shorts from Performance Bikes, never had a problem
'75 911S 3.0L
'75 914 3.2 Honda J
'67 912R-STi
'05 Cayenne Turbo
'99 LR Disco 2, gone but not forgotten
Model Citizen
herr_oberst's Avatar
shorts and a saddle,
correct fit
(shorts come in styles these days that look like regular walking shorts but with a nice pad, so you can walk around in public without displaying your johnson,)
(not that I mind showing off the johnson, mind, you)
Old 06-19-2009, 11:10 AM
T77911S's Avatar
different shorts and saddle.
the first time i did a 100 mile ride, my shorts rubbed my head raw, raw like you would not believe. i could not not take it any more and had to stop at around 90.
new shorts, a good pair, and never had the problem again, or maybe it just toughened up. anyway, pearl izumi's is one brand i used. dont go cheap, get the best even if it means less pairs. i did go to bibs too.
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 06-19-2009, 11:52 AM
creaturecat's Avatar
Ride down to Campione Cycle.
Talk to Guisseppe.
Old 06-19-2009, 11:57 AM
I see you
flatbutt's Avatar
really top quality shorts an absolute. saddle position is critical and pay attention to it's position relative to handlebar height. I found mine a bit to low so I was always pushing myself backwards onto the seat to keep my weight properly positioned.
and when I'm going to do a really long day >75miles, I use a small piece of the pad from an old pair of shorts and stick it under the nutsack to give a little more bufer.
Old 06-19-2009, 12:01 PM
MFAFF's Avatar
The shorts are a must and it might be that its the actual material that is causing the chafe, certainly if its real chammy then that might be a problem..I used vaseline back in the day.
Saddle angle and your overall position on the bike is crucial.. check the stem length and height.. too much forward lean and its the nuts that take the load....
As others have said its worth fining a decent bike shop that can set you up properly and comfortably.
The type of saddle, if you are sitting on it incorrectly ill not solve any of the problems.. nor will good shorts.
Share with me. Teach me something I didn't know. Make me think. But don't make me a bit player in your passion play of egotism. Dueller. 13/03/09
Old 06-19-2009, 12:11 PM
Dottore's Avatar
Good advice, all.
Mille Grazie!
Old 06-19-2009, 12:33 PM
drag racing the short bus
dd74's Avatar
Vaseline. Spin at times, lift off the saddle at other times. It'll help you last longer (for your ride, that is).
The Terror of Tiny Town
Old 06-19-2009, 12:42 PM
red-beard's Avatar
About 5 miles to the end of the MS150 (175 miles over 2 days) last year, I was going along with a random group of people. One of the guys says "I need to pull over for a Butt Butter break".
They make small, single use tube. He had the big size as the picture above. So, we're parked at the side of a major road in a little dirt patch. He puts on about an oz of the stuff into his hand, I mean a huge amount, and sticks his hand in his shorts, and starts slathering it on his junk, his thighs, everywhere! Yup, right there in the street!
A site to behold...
James
Old 06-19-2009, 04:04 PM
Slackerous Maximus
HardDrive's Avatar
I thought showing off the Johnson was the entire point of cycling.
correct fit
Old 06-19-2009, 04:17 PM
Non Compos Mentis
Another vote for "Ditch the gel saddle, and get the bike fitted properly".
Old 06-19-2009, 04:51 PM
jtkkz's Avatar
Brooks Swift saddle are very comfortable... they are heavy but comfy.
It is true stay away from gel saddles....
Old 06-19-2009, 07:28 PM
