"Stretch" (tires that is) painful to read
Good grief
http://forums.vwvortex.com/zerothread?id=2234638
what is stretch?
- "stretch" refers to stretching a narrower tire over a wider wheel, the sidewalls stretch from the lip to the tread
why do stretched tires?
- well the whole thing started in germany/belgium, local laws required that the tire tread be within the fender line. well that doesnt allow one to run wider or lower offset wheels, so they put narrower tires on the wheel to maintain legality
- when you would like to run really wide or low offset wheels and keep the tire tread at the fender
- when you would like to go really low and not rub
isnt this unsafe?
- there hasnt been any soild evidence that running a stretched tire is any more dangerous than a regular tire.
where can i get tires stretched?
-any reputable wheel/tire shop should be able to do it. i know when i did a 215-45 kumho on a 8.5" wheel, it took one shop 90lbs to pop the bead. getting a 225-45 on a 9 and a 245-40 on a 10.5 took another shop 50 lbs
< continued in the link >
Old 06-22-2009, 09:17 AM
Bandwidth AbUser
Jim Richards's Avatar
Jim R.
Old 06-22-2009, 09:25 AM
Dog-faced pony soldier
Porsche-O-Phile's Avatar
Stupid knows no boundaries.
Black Cars Matter
Old 06-22-2009, 09:29 AM
Band.
If you think it's painful to read look at this:
Werd to the extreme.
1983 SC Coupe
1963 BMW R60/2
1972 Triumph Tiger
1995 Triumph Daytona SuperIII
Old 06-22-2009, 09:33 AM
Yep, like I said, painful.
and as far as loss of pressure is concerned, i tested my wheels the other day after putting them on, i drove around one day (~60 miles mixed highway/city) and one tire was at 10psi, no visual or performance cues.
Old 06-22-2009, 09:36 AM
Zeke's Avatar
Low riders in Ca have been doing that for 20 years.
Old 06-22-2009, 09:57 AM
David McLaughlin's Avatar
... because your expensive wheels should be the first line of defense to any curb or pother solid obstacle.
1970 914/6 RustoMod
2015 Mercedes E400
Old 06-22-2009, 10:13 AM
I see you
flatbutt's Avatar
well if you're a poseur and boulevard cruising I suppose it's OK. But not on my rides...nuh-uh.
Old 06-22-2009, 10:14 AM
coulda, woulda, shoulda
johnco's Avatar
used to take 2 vw rims, cut out one inner and outer lip and weld together for wide rims on my dunebuggy. mudgrips and innertubes and you could just about float the thing thru the swampmud
John
74 911s
Old 06-22-2009, 11:23 AM
MEXIPOKE!!! The Corrado guys do it too. I think it looks STOOPID.
Old 06-22-2009, 12:49 PM
