Wireless Router Question
I have my WiFi Router in the living room where it comes into the house. I have just purchased a new Roku player for streaming Netflix which has an ethernet port input which will be in another room.
Is there any way to buy a second WiFi router and use the WiFi to connect to my Main Router and then connect my Roku to the ethernet ports on the second router? I want to avoid having to crawl around under the house, running cable, drilling holes, etc. Thanks. Oh, my current router is a Belkin G
--------------------------------------------------------------------------- "There is nothing to be learned from the second kick of a mule" - Mark Twain |
The Unsettler
The units need to be bridgeable which not all consumer units are.
You are really looking for something more like an Access Point. You can buy a stand alone wifi adaptor for the Roku.
"I want my two dollars" "Goodbye and thanks for the fish" "Proud Member and Supporter of the YWL" "Brandon Won" |
Gon fix it with me hammer
my experience with wifi is such that, if you can use wire.. use wire.
wires don't disconnect by themselves at regular intervals, wifi's do.
Stijn Vandamme EX911STARGA73EX92477EX94484EX944S8890MPHPINBALLMACHINEAKAEX987C2007 BIMDIESELBMW116D2019 |
Yea, but it's a dry heat
Don't have one but according to the Roku site it has built
in wifi capabilities www.roku.com/technology.aspx |
Yes, it is possible with SOME wifi devices to have the two connect to allow devices to talk to each other.
It probably works best with the higher end devices than it does with the average home user's setup. You'd need to read about the capabilities of your existing device. If it'll do it, then you'd probably just want a twin router. If it doesn't do it then you'd want to buy 2 new routers. (really, WAPs, are usually more geared to this sort of activity) Good luck
The Unsettler
You do not say who your provider is (FIOS, RoadRunner, etc..) or what bandwidth you are paying for. Most home consumer broadband will have less bandwidth on the WAN than the LAN. Meaning your internet connection is most likely a bigger bottleneck than your wireless network. Really the only way for a device like that to work reliably given all the possible bandwidth limitations is to build a sufficient buffer and self adjust for latency. Imagine a bucket that empties faster than you can fill it, to keep it from running dry you let the bucket fill up enough so that it won't run dry when you open the spigot. Scott
I'm in a remote/rural location and my ISP is by wireless transmitter (receiver mounted on the side of the house). I'll have to check the specs. Thanks for the info, I didn't want to spend $$ needlessly
Back to back wireless like you're talking about - or wireless bridging - is not something the consumer type access points support.
Linksys's WAP54G does support it but it only works with like devices and in my experience - not very well. I tried it - it sucked so I got under my house and ran some wires. MUUUUUUCH Better speeds that way too.
-The Mikester I heart Boobies |
Roku? Why not an Xbox 360? Plays games, too!
I also use the streaming Netflix. I love it, plenty of content but they could use more HD and new release stuff.
'85 911. White - 53,000 miles bought 3-16-07. "Casper" '88 924S. Blue - 120k miles bought with 105k miles. '94 968 Coupe - White - 108,000 miles bought 9-28-17 '09 Cayman - Grey - bought 9-8-20 |
Samsung makes an OUTSTANDING Blu-Ray player that does Netflix and Pandora. And it comes with a wireless antenna. Very well reviewed at cnet.com
Don't be afraid of wireless. As long as you set it up properly and buy quality all should be well.
I have 2 Tivo HD units hooked up wirelessly running Netflix online and couldn't be happier. Wire is good but not necessary these days. I use the much touted D-Link DIR-655 N spec and have been very pleased.
Randy '87 911 Targa '17 Macan GTS |
