126coupe's Avatar
Help with hornet/wasp nest
These guys keep trying to build their nest and I keep knocking it down, its right next to the front door. Is their something i can treat the area with so they don't come back?
1967 911R "Clone" Race Car 2.0 & 2.5 Twin Plug
1984 Mercedes 500 SEC
1991 Mercedes 420 SEL
1992 Ford F-350 Dually
28' Pace Trailer
Old 07-10-2009, 07:44 AM
Rick Lee's Avatar
Glue traps.
2022 BMW 530i
2021 MB GLA250
2020 BMW R1250GS
Old 07-10-2009, 07:45 AM
Wandered off somewhere...
Drdogface's Avatar
I would think you could hose the area down with some of that wasp nest spray. It's not really a spray but more like a mini fire hose containing the usual chemicals. I would suspect it would keep a residual of odor, etc. for long enough to convince them to go elsewhere.
Mark...
Porsche Boxster S
2012 Jeep Wrangler Rubicon..Crush Orange
Old 07-10-2009, 09:12 AM
charleskieffner's Avatar
WD-40 and a TORCH!
Old 07-10-2009, 09:15 AM
126coupe's Avatar
I did that and they continued building the next the very next day.
28' Pace Trailer
Old 07-10-2009, 10:16 AM
Demon WP. I'm pretty sure that'll get em and stop them from coming back. You can get it on Amazon.
Old 07-10-2009, 10:45 AM
Michael Delaney wanna-be
Netspeed's Avatar
I tried those hanging bags that look like wasp nests. The theory is that, because they're so territorial, they'll avoid the area that has been staked out by other wasps......it didn't work at all.
The best thing I've found is to spray the nest with a can of wasp spray (sorry....don't know the chemicals). They key is to do it around 10pm when the sun goes down and it starts cooling off. They all go back to the nest for the night and that spray will knock them down in no time flat. Don't destroy the nest right away as any straglers the next day will come in contact with the poison if they land on the nest. After a few days, crush the nest.
88 Carrera Cab
C.R.A.P. Gruppe Member #7
Old 07-10-2009, 10:53 AM
JOT MON ABBR OTH
Groesbeck Hurricane's Avatar
Paint the area sky blue. Less hassle and the pesky vermin will leave it alone. They will think it is part of the sky.
'83 SC Targa (sold ) MANLY babyblue honda '00 F250 7.3L (MINE!)
'15 F250 Gas (Her Baby) '95 993 (sold )
I don't take scalps. I'm civilized like white man now, I shoot man in back.
Old 07-10-2009, 11:16 AM
Evil Genius
Rusty Heap's Avatar
Here's mine, under a 2 foot wide eave so it's at least a foot wide, and it's 25% bigger now as I took this photo a week or two ago.
Unfortunately it's about 20 foot off the ground top of a second story.
When it was the size of a cantalope, I took a pressure washer with a 0 degree tip (bullet stream) and blasted 1/2 of it down. They just rebuilt it.
Last night I hit it with a can of wasp killer that shoots 15-20 foot. Knocked a bunch of them out dead, but they're still crawling around........second dose of wasp killer spray at dusk tonight.
Life is a big ocean to swim in.
Wag more, bark less.
Old 07-10-2009, 11:58 AM
Feelin' Solexy
Tishabet's Avatar
I just found a spot where they are entering my home... through a little gap in a brick wall. It is looking like they may have built a nest between my ceiling and roof, and are gaining access to the area through the gap. I just noticed that there were a lot of wasps hovering in that area, and put two and two together.
Assuming I can seal the hole will that be it? i.e. will the ones stuck "inside" just die off?
Grant
In the stable: 1938 Buick Special model 41, 1963 Solex 2200, 1973 Vespa Primavera 125, 1974 Vespa Rally 200, 1986 VW Vanagon Syncro Westfalia, 1989 VW Doka Tristar, 2011 Pursuit 315 OS, 2022 Tesla Y
Gone but not forgotten: 1973 VW Beetle, 1989 Porsche 944, 2008 R56 Mini Cooper S
Old 07-10-2009, 12:22 PM
Netspeed's Avatar
That thing's huge! That's not the normal paper wasp nest that I'm used to seeing.
88 Carrera Cab
Old 07-10-2009, 12:27 PM
Netspeed's Avatar
Originally Posted by Tishabet View Post
I just found a spot where they are entering my home... through a little gap in a brick wall! It is looking like they may have built a nest between my ceiling and roof, and are gaining access to the area through a spot where the cement between two bricks is missing. I just noticed that there were a lot of wasps hovering in that area, and put two and two together.
Assuming I can seal the hole (which looks to be the space between two bricks, 2 inches by maybe .25 inch), will that be it? i.e. will the ones stuck "inside" just die off?
I'd spray it and then seal it.
88 Carrera Cab
Slumlord
Porsche_monkey's Avatar
Place a vacuum hose near where they enter. As they fly past they get sucked in, then put the vacuum hose onto the lawnmower exhaust...done.
This does work.
84 Cab - sold!
89 Cab - not quite done
90C4 - winter beater
Old 07-10-2009, 01:10 PM
winter-hater club member
nynor's Avatar
stanley steemer carpet spot remover. kills em dead dead dead, right NOW. and they don't come back for some reason. i discovered this on accident. seriously, it kills them faster than any insect killer i've ever seen.
"COOL PRIUS!" - Nobody Ever
Old 07-10-2009, 03:55 PM
Zeke's Avatar
this is what he is talking about
I just leave them alone and they leave me alone.
Old 07-10-2009, 06:43 PM
AutoBahned
RWebb's Avatar
"don't know the chemicals"
it's a neurotoxin and WILL affect you, so be careful
wear gloves, maybe mask - ls shirt & wash right afterwards.
St. Steamer stuff would be great - I never knew that...
Old 07-10-2009, 07:03 PM
74 911Ebay
definitely chemicals. Dont know how the EPA lets it be sold.
Try aerosol Break Parts Cleaner. Will kill the the ones it comes in contact with. The rest just sort of give up. When you use it on ant piles, the ants dont even try to collect the bodies.
Oh yea, it works pretty good on breaks too.
Old 07-10-2009, 07:56 PM
vash's Avatar
jeezus! i would call a pro!!
one of the few creatures i am truly scared of.
poof! gone
Old 07-10-2009, 08:38 PM
Hornets nest. And lots and lots of hornets. I have found that once they think they have been found they move somewhere else. Don't think those are going anywhere. You can spray and spray. Be very careful they will come after you. When you are spraying one hole they come out of the second one. Call it an entrance and exit. The more you mess with them the quicker they will be to attack.
1990 Wanderlodge PT-40
75 911S Silver Anniversary
1952 MGTD
1983 Mercedes 300 TD
1969 Lincoln
Old 07-11-2009, 05:07 AM
AutoBahned
RWebb's Avatar
he's in Calif. so do they have hornets there?
this is imp. b/c the behavior of the things depends on what they are
a pro. is always nice no matter what...
Old 07-11-2009, 12:27 PM
