I know XJ Jaguars had that on the drive axles ( inboard brakes ). A lot of larger 4 wheelers / rock crawlers use that technology.
A nose heavy airplane flies poorly, a tail heavy plane flies once. |
Dog-faced pony soldier
Interesting idea. Makes sense...
A car, a 911, a motorbike and a few surfboards Black Cars Matter |
You see driveshaft parking brakes on some commercial trucks.
Works great as long as the driver puts the transmission in gear - LOL! angela
Hello http://forums.pelicanparts.com/off-topic-discussions/1102514-we-lost-amazing-woman-yesterday.html |
My '95 Range Rover had one of those, Discoveries do too. Of course it was a massive drum as opposed to a disk. It is good for highlighting how much drivetrain slack you have but you can't use it to stop the vehicle.
Here is a pic of one on a Discovery transfer case.
Old Technology. Quite a few of the older Grain type trucks had that. Take the stopping force of the disc, multiply that by the ring and pinion ratio, and it will hold back quite a lot of weight.
Some Rockwell axles have the disc brake on the pinion gear, and none at the wheel. |
Mike 1976 Euro 911 3.2 w/10.3 compression & SSIs 22/29 torsions, 22/22 adjustable sways, Carrera brakes |
My 19,500 lb motorcoach (RV) has one
My old FJ40 Landcruiser had a drum on the rear output of the transfer case. I always thought it looked like a pretty good idea.
Jeff '72 911T 3.0 MFI '93 Ducati 900 Super Sport "God invented whiskey so the Irish wouldn't rule the world" |
Control Group
XKEs were like that too
She was the kindest person I ever met |
If it is a parking brake why is it a cross drilled disc? Is this maybe used as a single brake for hte rear wheels (with a locked differential)?
M |
Band.
It's a PERFORMANCE driveshaft parking brake.
1983 SC Coupe 1963 BMW R60/2 1972 Triumph Tiger 1995 Triumph Daytona SuperIII |
Nope, parking brake. The parts are sourced from motorcycles, it takes very little force to keep a gear-assisted parking brake locked, so it doesn't need to be big. It keeps the assembly up and away from dangerous rocks, and many of the 4x4 trucks that run these are running custom, handmade axles with no real parking brake application. Some people run linelocks/monolocks on the main brakes instead.
Mike Bradshaw 1980 911SC sunroof coupe, silver/black Putting the sick back into sycophant! |
Standard fare in the off-road world. Guys have been installing those on their mini's and 4Runners, since at least the early - mid 90's.
Josh 85 M491 Coupe - "Fat Bastard" |
Parrothead member
My '66 CJ 5 had a driveshaft parking brake. It was a drum brake on the transfer case output shaft
Vinny Red '86 944, 05 Ford Super Duty Dually '02 Ram 3500 Diesel 4x4 Dually, '07Jeep Wrangler '62 Mercury Meteor '90 Harley 1200 XL "Live your Life in such a way that the Westboro Baptist Church will want to picket your funeral." |
just stick a screwdriver in the u joint
chance favors the prepared mind 1987 944 n/a 5spd. who remembers dial phones?. 'STOP FIXING THINGS ONE STEP BEFORE YOU BREAK SOMETHING ELSE" |
Stock Dodge trucks from the 50's-60's had driveshaft parking brakes.
David 1972 911T/S MFI Survivor |
