Custom User Title
Dave L's Avatar
ice maker = suck
5 year old kenmore side by side with an ice maker. The ice maker was replaced once under warranty because it wouldnt make ice. Tonight after making a R&C for the wife and I the ice maker started to click.
After a quick search it appears that this is common and its best to just replace the whole unit.
Anyone else run into ice maker issues, is it normal that the fridge would be on its 3rd ice maker in 5 years?
Old 10-30-2009, 07:00 PM
Banned
gassy's Avatar
Send a message via ICQ to gassy Send a message via AIM to gassy Send a message via Yahoo to gassy Send a message via Skype™ to gassy
A couple of times mine stopped working. I took it out and there was ice all around the spinny thing inside. I let it all melt off and it was fine. I think mine was clicking too when it was happening. There was a lot of ice built up.
Old 10-30-2009, 07:45 PM
The Unsettler
stomachmonkey's Avatar
Any time I've had problems with them it's been (ironically) ice related. As in damming up and causing water leaks/lack of ice.
"I want my two dollars"
"Brandon Won"
Old 10-30-2009, 08:07 PM
Senior Member
10 year old Amana side by side with icemaker. Still going strong but knocking on wood as I type...
Old 10-30-2009, 08:18 PM
vash's Avatar
i do not like ice makers. had one growing up, and the ice just tasted "off". at my home, i go old school. i use trays. i keep the rotation up, and run the trays thru the wash cycle regularly.
3 trays for ice, 2 trays for food stuff...like leftover coconut milk, beef stock, etc.
poof! gone
Old 10-30-2009, 08:55 PM
Detached Member
Hugh R's Avatar
Usually too cold, turn up the temperature. Go to applianceguru.com and do a free search or pay $5 to register and ask questions. The forum is like PP, It has saved me a few bucks.
Hugh
Old 10-30-2009, 10:04 PM
lin7310948's Avatar
ice maker
i was told by the last technician to see mine that the measured amount of water filling the icemaking area was too much. evidently this is a fairly precise volume of water. when it is too much, the ice forms over the level of the ice cube depth and the ice maker mechanism is not strong enough to break up the ice into the individual cubes. adjusting the water level was a five minute job using a graduated cylinder marked in cc's and 100 dollars.
69 bronco..... 91 mustang ssp santa clara county sheriff's office ...2017 focus rs tuned on 93 400 chp
Old 10-31-2009, 03:51 AM
19 years and 17k posts...
azasadny's Avatar
Our GE icemaker is pretty reliable but every once in awhile, it will stop for no apparent reason. We'll reset it and 12 hours later, we'll have a full bin of ice...
Art Zasadny
Learning the bass guitar
www.ford.com
Old 10-31-2009, 04:44 AM
UnRegistered User
billybek's Avatar
You have to watch the level sensing arm doesn't get buried in the ice. The ice maker will try to lift it during operation to dump the ice.
If you hear the frig making some clicking noises, chances are the arm needs to be set free. If it stays locked up in the ice, it could damage the gears inside the ice maker.
Bill K.
Old 10-31-2009, 07:33 AM
Custom User Title
Dave L's Avatar
it feels very iced up where its making the cubes, I think I will remove the ice maker, let it defrost then see what I have.
Old 10-31-2009, 09:37 AM
Detached Member
Hugh R's Avatar
Turn down temp and use a hair drier
Hugh
Old 10-31-2009, 12:02 PM
Custom User Title
Dave L's Avatar
temp is in the recommended range but it will bump the temperature up a bit. Im on my way to get the wifes hair dryer now.
Old 10-31-2009, 12:15 PM
78 in a '71
mossguy's Avatar
Hugh, Thanks for the heads up on the samurai appliance guru site! I checked it out, joined it, and saved myself quite a few bucks on a timer problem with my Kenmore/Whirlpool dryer today.
Best,
Tom
On glide path......
1971 911 T Targa
2013 Ford Fusion Titanium AWD
Old 10-31-2009, 04:42 PM
