Custom User Title
rammstein's Avatar
Where can I get a connector thingy for this?
E46 manual transmissions have a reverse switch that looks like this:
So it has 2 metal blade things inside of a hole. I want to get the part that I'd stick into it. Is this some kind of standard thing, and that's why there isn't a BMW part number for it?
Old 11-21-2009, 08:24 PM
I'd be surprised if there wasn't a BMW part number for the connector. They usually do a pretty good job of supplying conectors for their wiring harnesses. Have you looked through the BMW microfiche?
JR
Old 11-21-2009, 08:26 PM
Cars & Coffee Killer
legion's Avatar
Sounds like a wiring harness to me.
5 liters of VVT fury now
-Chris
Old 11-21-2009, 08:27 PM
Custom User Title
rammstein's Avatar
JR
I've gone through all of the parts on RealOem.com, the equivalent of a microfiche.
Old 11-21-2009, 08:31 PM
Does it look like this?
826008-5 Product Details - Tyco Electronics
Rick
88 Cab
Old 11-21-2009, 09:03 PM
Custom User Title
rammstein's Avatar
Originally Posted by rick-l View Post
That certainly looks like I would expect... just hard to know if its the right size.
Old 11-21-2009, 09:08 PM
So, did you look through 61 15 and it's not there?
JR
Old 11-22-2009, 06:05 AM
Did you get the memo?
onewhippedpuppy's Avatar
It should be available. I've purchased connectors before, but always from the dreaded dealer. Often times the parts catalogs simply have a list of standard connectors, you have to find the right one. Sometimes it's a leap of faith because there's no list of applications for the actual connector.
‘07 Mazda RX8-8
Old 11-22-2009, 06:23 AM
Custom User Title
rammstein's Avatar
JR
RealOEM.com * BMW E46 325i Plug terminal ELO not waterproof
It could be one of these, but I'd have no idea which one.
Old 11-22-2009, 07:07 AM
does it look like the connector on a Bosch injector? AMP Junior Timer.
Rick
88 Cab
Old 11-22-2009, 09:16 AM
19 years and 17k posts...
azasadny's Avatar
Check McMaster-Carr online...
Art Zasadny
Learning the bass guitar
www.ford.com
Old 11-22-2009, 09:21 AM
I'm with Bill
Rick V's Avatar
Check at some local garage, I know when I have to install a used engine I keep the old harness just for the connectors.
Old 11-22-2009, 09:27 AM
Senior Member
NAPA has them.
Old 11-22-2009, 09:48 AM
You do not have permissi
john70t's Avatar
or print picture, side cutters, junkyard.
Old 11-22-2009, 10:33 AM
Custom User Title
rammstein's Avatar
OK- I do believe that I got the right part from the dealer parts counter. I'm now out $2.
Part 2 - for wiring that will find itself exposed to the elements, what should I use? Do I use regluar wiring and wrap it in good electrical tape? Is there a pre-insulated wire that I can use? I will need to run 2 wires about 3 feet. I only want to do this once. Any suggestions?
Old 11-23-2009, 02:26 PM
Custom User Title
rammstein's Avatar
Nevermind- I think what I need is 2-conductor trailer wire.
Old 11-23-2009, 02:32 PM
