Apple users: How do I stream music to my stereo?
And control with my iphone? I have the airport express and the iphone but thought I needed the apple tv to stream to my stereo--is there something else I can use? how did you do it?? Thanks
1980 911SC Targa 3.6L
Old 12-09-2009, 07:29 PM
You have all the stuff... I am using this as we speak. Get a cable that goes from headphone to RCA and hook it up... Run the airport utility and setup your airport and open iTunes and click down in the lower right corner where it says computer and select your speakers... Voila...
Old 12-09-2009, 07:33 PM
Sidney--problem is my computer is upstairs and my stereo is downstairs so everything needs to be wireless--or am I reading your response wrong??
Old 12-10-2009, 10:21 AM
Have you got a wifi card in your computer? If so plug the airport in down by your stereo and hook it all up down there...
Shoot me a PM if you want my cell #.... I just went through this on tuesday...
Old 12-10-2009, 10:24 AM
sudo apt-get purge 930
equality72521's Avatar
I use an Airport Express and a 3.5mm jack to RCA cable. Plug the 3.5mm side into the Airport and the RCA side into the stereo. Turn on iTunes and select the Airport as the play to option in the lower right corner. Not sure about the iPhone part.
--clutch-monkey
Old 12-10-2009, 10:29 AM
Just realized I said exactly what Sidney already said.
--clutch-monkey
Old 12-10-2009, 10:31 AM
All you gotta do for the iPhone is install the app called "remote". Inside that you click add library and it pops up a code... Hammer that into itunes over at the side where it says "devices"... Badda bing badda boom....
It's ok mark... We'll forgive it ..... This time....
Old 12-10-2009, 10:32 AM
Nine17's Avatar
Your computer needs to have Airport enabled. Is it a Mac that came with it? I run iTunes on my iBook streaming via Airport to the Airport Express at my stereo, controlled by the Remote app on my iPhone that is sync-ed to iTunes on the iBook. Where it gets complicated is that the iPhone and iBook talk via Airport on a different wireless network than the Airport Express, working in tandem. Fortunately my wife has worked for Mac developers since Day One, but it still took her an hour to trouble-shoot the system. The best benefit has been the ability to use the iTunes EQ to adjust the output to suit the source material, speakers, and room!
'88 Carrera Coupe G.P. White
Old 12-10-2009, 10:33 AM
The Unsettler
stomachmonkey's Avatar
I use the Remote app.
Real convenient.
"I want my two dollars"
"Brandon Won"
The Airport is plugged into the outlet at the stereo and the cable runs from the Airport to the stereo. Your Mac will stream the music to the Airport wirelessly and send it to the stereo through the cable.
--clutch-monkey
Doesn't have to be a Mac at the sending end.... XP works just fine.... Just wish my wifi card didn't suck... it keeps dropping the signal...
Old 12-10-2009, 10:34 AM
True.
--clutch-monkey
Old 12-10-2009, 10:36 AM
Canadian Member
911Rob's Avatar
cool. thanks I'll try this too.
Rob McKibbon
Arena Red 96 993 TT LINK
Contemplate YOUR Success!
Old 12-10-2009, 12:55 PM
nostatic's Avatar
Or if you're really sassy and have digital inputs on your receiver, get one of these:
For only $2.09 each when QTY 50+ purchased - Toslink to Mini M/M OD:5.0mm, Molded Type - 6ft | Toslink to Mini Plug
Old 12-10-2009, 01:58 PM
