Fogless Shower Mirror
anyone use a good one? recommendations? want to shower-shave-go.
Tru6 Restoration & Design |
I got one that was supposed to be fogless... It was the first time I used it... Not anymore.... I just run some hot water on it or smear a little soap on it....
Banned
I've been shaving in the shower without a mirror for years. It took a couple weeks but you get the hang of it pretty quickly. Well worth giving it a try. Once you get it down you'll wonder why you didn't start it years ago.
I need a mirror.... I don't shave it all off...
i shave IN the shower. a little spit and its good to go. sometimes soap and water.
i also brush my teeth in the shower. the more time i spend in the shower, the better
I shave in the shower without a mirror, but there are times when I think it would be nice to have a mirror. I'd be impressed if someone could come up with a fogless mirror. It's more about temperatures than chemical make-up. Take a shower with cold water and you'll have a fogless mirror.
i prefer to shower with a friend, and let her handle the "manscaping"
![]() this thread will not be gettng any pix of said showers.
chance favors the prepared mind 1987 944 n/a 5spd. who remembers dial phones?. 'STOP FIXING THINGS ONE STEP BEFORE YOU BREAK SOMETHING ELSE" |
I use the kind that screws in between the outlet and shower head. It trickels a low stream of water bypassing the shower head to heat the mirror. Works great, I have used them for many years.
"The smaller the fine print, the larger the risk." 1988 911 coupe 2008 VW R32 2004 530I |
Either that or having it plug into the wall with an electric heating element.
There is a product skiers have used for years to keep their goggles from fogging up. It's rather improbably called "CAT CRAP". Works like a charm. I see no reason why it shouldn't also work on your shower mirror.
Google it. Comes in little red tubs.
_____________________ These are my principles. If you don't like them, I have others.—Groucho Marx Last edited by Dottore; 12-11-2009 at 02:34 PM.. |
I was thinking of some type of Divers anti fog...
Banned
Fog X?
Found the cat crap, thanks, and for all with suggestions. if it's all about equalizing the mirror temp to the air temp, also thinking of mounting a mirror on a shallow Tupperware(TM) container (or similar) that I can fill up with hot water and then hang on the wall/over the shower arm.
You can smear some shaving cream on the mirror while you are taking a shower, rinse it off, and it won't fog up. Works like a charm, David
99 996 C4 11 Panamera 4S 83 SC Targa converted to a 964 cab (sold) 67 912 (sold) 58 Karmann Ghia choptop (traded for the 912) |
Control Group
Use your finger as a guide. I use the shave mug, post shower.
I like Shaun's ghetto solution though.
She was the kindest person I ever met |
