Slackerous Maximus
HardDrive's Avatar
Ducati only running on one cylinder
Gee, you think this might be the problem?
Its seems the previous owner was not the maintenance fanatic he claimed to be.
2014 Cayman S, PDK
Old 01-12-2010, 04:03 PM
Super Moderator
cstreit's Avatar
I see your problem. That's a spark plug, not a cylinder.
Did his own valve adjusts maybe?
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 01-12-2010, 04:18 PM
Registered ConfUser
That's a Ducati safety feature.
Mike
Old 01-12-2010, 05:05 PM
beancounter
jwasbury's Avatar
Are both plugs fouled like that? Could be a symptom of a different problem.
Jacob
Current: 1983 911 GT4 Race Car / 1999 Spec Miata / 2000 MB SL500 / 1998 MB E300TD / 1998 BMW R1100RT / 2016 KTM Duke 690
Past: 2009 997 Turbo Cab / 1979 930
Old 01-12-2010, 05:45 PM
holtjv's Avatar
Haven't you always wanted a big red (yellow, right?) thumper?
Warren Hall (Early S Man), 1950 - 2008
2006 Tri D675 Scorched Yellow
2006 Ducati Sport Classic mono SOLD
1979 SCWDP #0020 Talbot Yellow SOLD
Old 01-12-2010, 05:53 PM
Slackerous Maximus
HardDrive's Avatar
Unless I'm reading the plugs wrong, its running rich. I'm going to change the air filter, check the choke cable, then go after the carbs. Might just have the air/fuel mix off. The carbs were rebuilt recently, but god knows what the previous owner did.
2014 Cayman S, PDK
Old 01-12-2010, 10:43 PM
I'll actually go out on a limb and say that plug looks fine to me. It's not the problem.
Air-cooled, carbureted bikes need to run a little fat. Most will do so when operated at less than WOT, balls-to-the-wall riding, just so they don't lean out too much when you are riding in that mode. I think a lot of guys get used to seeing pristine, light ash colored plugs common to modern fuel injected motors that do a much better job of controling A/F accross the full range of throttle positions and loads, and assume all plugs need to look like that.
Well, they don't. Carb's just can't provide the accross the range mixture control that EFI can provide. There are rich spots and leans spots. The lean spots drive the tuning. In other words, the leanest condition cannot be so lean as to damage the motor. Everywhere else in the range just gets richer from there.
I doubt the carb's are the problem, jetting or otherwise. They don't operate in an "on/off" mode, where the cylinder either fires or doesn't. Electrical components do that. If it still has the stock coils, I would put those at the top of my list to check. They are notorious on these bikes for taking a dump.
Jeff
'72 911T 3.0 MFI
'93 Ducati 900 Super Sport
Old 01-13-2010, 06:46 AM
Student of the obvious
LeeH's Avatar
I just converted my wife's M900 from a single cylinder to a twin. And I agree that I'd think that plug would fire.
In the case of our Monster the push on connecter where the power lead attaches to one of the coils was loose. The rubber boot held it mostly in place, so that cyclinder would come and go.
Lee
Old 01-13-2010, 06:57 AM
Air cooled carburetted bikes don't NEED to run rich, they do so at certain points because of things like carb reversion. None of my plugs look like that and I own a whole buch of carburetted crap.
I'll second the notion that you should check the ignition system but I'll also add that you should take a look at the modifications done by the previous owner(s) (any jetting changes? muffler changes?) and double check that, after the carb rebuild, the mixture was set correctly. I like to see it set with a CO meter, which is more accurate than my ear/seat-of-the-pants/whatever. You may also find that the front cylinder and rear cylinder have different tuning needs. I'd try to make sure their flows are similar.
Good luck,
JR
