Senior Member
Rust/corrosion inside a watch will do that. Pools have far too many chemicals that are not really good, then salt water is not good either.
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
Won't sudden temperature changes do the same thing? I took a new watch with 100m resistance from a hot beach to being splashed in the ocean. Fogged immediately and formed a drop. Screw down post certainly didn't prevent it.
Just sent it back today (androidusa watch). Will see what they say.
Warren Hall (Early S Man), 1950 - 2008 ------------------------------------ 2006 Tri D675 Scorched Yellow 2006 Ducati Sport Classic mono SOLD 1979 SCWDP #0020 Talbot Yellow SOLD |
Control Group
Never even went swimming in a pool with the TAG, lake, river, shower, it was a low end watch
She was the kindest person I ever met |
"YOU CANT RACE A CAB."
cameras and watches were NEVER MEANT to go UNTAWATA! even an OYSTER machined out of a block of stainless steel still has to have a hole drilled in it for the screw down knurled knob.
so as with a camera body...............when ya put a hole in it, well thats were mr. aqua wants to enter. and how they stop that, aint a submarine hatch...........its an lil itty bitty teensie weensie O-RING! heres a lil lesson on taking anything in pools. pools are berry berry bad on equipment. ALWAYS FLUSH THE HELL OUT OF GEAR WITH FRESH WATER. including flushing BC bladder completely and regulators as well as cameras and watches. now heres a lil lesson on the el mar. you have (2) things werking against you and your gear and o-rings. salt water crystals and sand. (1) measly ass salt water crystal or sand particle CAN and WILL RUIN YOUR DIVE/DAY/GEAR! you must clean cameras especially before opening in fresh water on board dive boat.............PERIOD! your watch dont woory about it unless you didnt tighten the hell out of the screw and then yer screwed. but cameras must be flushed with fresh water completely and then completely dry before opening for battery change/film change/camera card change. same with unta wata strobes. so anytime ya put a hole in some metal/plastic/lexan thats going untawata...........make sure yer O-RINGS are new and cleaned and lubed with silicone! ask me how i know????? |
Targa, Panamera Turbo
I hear Walmart is having a sale on bike helmets. Maybe I'll score one for the next time I race the P-car...
Michael D. Holloway https://simple.m.wikipedia.org/wiki/Michael_D._Holloway https://5thorderindustry.com/ https://www.amazon.com/s?k=michael+d+holloway&crid=3AWD8RUVY3E2F&sprefix= michael+d+holloway%2Caps%2C136&ref=nb_sb_noss_1 |
now i use a watch,set the bezel as i submerge, have (2) pressure gauges(re-dum-dancy), a scubapro dive computer that wipes my ass it has so many menus and AUDIBLE ALARMS, and i carry a SPARE AIR BOTTLE....................ALWAYS! and thats why im still alive today! and yes i have had to emergency ascend using my spare air bottle off of kona hawaii because of a POS hose splitting and the reg had just been serviced and the hose was NEW! POOOOOO DOES HAPPEN! |
time won't let you run out of air.... Thats what your SPG is for... |
FWIW.... I didn't buy this with the intention of diving with it... I already had it when I started the class and thought what they hey....
My fossil did just fine last time we dove in the pool... |
Did you activate the chrono buttons in the water? That will let water in on most chronos.
Personally, I would toss the invicta/flip it after you get it serviced, get a Seiko SKX007 for about $150, it will go deeper than you should.
88 Carrera Coupe Pelican Since 2002 All Zing, No Bling. ok, maybe a little bling. The Roach |
huh
![]() 100m surface. surely you need to be 100m down from the surface otherwise ts rated for 0, i.e. not water resistant
----------------------------------------------------------- The fear of God is the begining of wisdom <>< NotJustPorsche Subscribe: notjustporsche-subscribe@yahoogroups.com |
OK, I have a question for the scuba guys. My watch is a Seiko Pathfinder. On the back it says it is rated to 10 Bar. How many meters down is that?
I have been swimming with it before with no problem.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
for the FNG's...............right this very INSTANT you are living existing working screwing off IN THE 1st ATMOSPHERE! aka TERRA FIRMA.
the 2nd atmosphere is 0-33 feet. the 3rd atmosphere is 33-66 feet. the 4th atmosphere is 66-99 feet. und so veiter...................................... now why do submarines have a CRUSH DEPTH LIMIT? because of how many POUNDS PER SQUARE INCH of PRESSURE is exerted on their hull. and when they exceed that..................well its ADIOS MUCHACHOS for the bubbleheads. and the hull IMPLODES! or caves in . now for any "waterproof" gear to last, the tolerances held on machining items must be held very tight. kind of call your watch or camera a submarine cause the O-RINGS act as lil watertight doors. if the tolerance held is not correct, or the o-ring is compromised by sand or salt crystals or age or lack of silicone, you have catestrophic flooding of the object. now in the case of my regulator hose leaking. it was leaking a minute amount at the surface. not even enough to notice or hear or see on my SPG's(plural like (2). when i dove deeper pressure was exerted enough to cause it to leak at a furious pace. now since this was a NIGHT DIVE, nobody noticed. the deeper i got, the faster it leaked air and then i got my LOW AIR alarm from my scubapro uwatec decom meter(downloadable to my puter). WTF?????????????????????? as i look at both of my SPG's and they is below 500 psi. NOW WE HAVE A SER-I-ASS PROBLEMO! now considering we were watching multiple giant assed volkswagon sized manta rays with numerous dive boats and everyjuans dive light shining up...........it was kind of difficult to see any bubbles escaping let alone the divemaster. i finally grabbed my spare air bottle and had a death grip on it, and shined my divelight horizontal and found my divemaster and alerted him to my conundrum. i gave him the out of air signal and we proceeded up, about 30 feet from the surface i felt my poseidon regulator starting to breathe hard and knew the end was near and got ready to ditch regulator and slam spare air into my mouth. and then then the end came and i got spare air into my mouth for the rest of the ascent and the story was over. what i am trying to point out here is any minute leak or failure at the surface is exacerbated by pressure exerted pertaining to your depth. ie. the deeper ya go the more pressure exerted. sooooooooooooo......................with that in mind a watch that works in the shower or pool may not make it past the 2nd atmosphere if tolerances not held or o-rings compromised. now how do you suppose my reg hose was compromised since EVERYDAMN TIME I GO DIVING ALL MY GEAR IS SERVICED? well after a few beers discussing my activities and looking at the hose, we found the scuff marks and on my previous day dives we had bean diving the kona lava tubes off old kona airport road. and this is the home if the INFAMOUS KONA EXPRESS SURGE! while diving in there i had a few kona express surge rides and got banged up pretty damn good along the roof and sides of the cave. yeah not a hell of alot of fun. trust me more gawd damn sea urchins than i ever want to see in my life. anyway during one of these washing machine tumblers we suspect my hose was dragged along the lava tubes abrasive wall and compromised. solution.................all my hoses for my poseidon main and my poseidon octopus, my SPG'S(plural-like (2), and my BC and my drysuit are now SHEATHED IN KEVLAR SHEATHING! and thats how ya learn from your experience and live to tell about it! |
Senior Member
![]() 1 bar is about 14.5 psi, so we are talking about a lot of pressure. OJ's comments above are a good guide.
Senior Member
Again, send it in, get it cleaned up and sealed and try again.
I'm not gunna flip it... its still a damned nice watch... I just can't dive in it....
The same thing happens when you exit a cold movie theater into a muggy August afternoon-your glasses can fog up. And someone posted about a waterproof watch. It doesn't exist. Additionally, water resistance is a condition, not a guarantee. You could have had your watch be water resistant yesterday, knocked the crown on a counter today, and get water in the watch tonight.
95 968 Cab, Speed Yellow, Kinesis Supercups, Promax chip, Big Reds, SS brake lines, 5/35 brake bias valve, H&R sport springs, mo30 sway bars, LSD, Brey Krause control arm brace, Dynatech billet strut brace, Cargraphic 100 cell cat and ss exhaust, Club Sport steering wheel, short shift, sport seats |
