They're probably thinking that eventually, the wood chocks will catch fire and burn, letting the doors swing shut.
Old 04-20-2010, 01:15 PM
Zeke's Avatar
Originally Posted by Jim Bremner View Post
Ok,
Next code please!
I have a steel roll up door that I do not use. What can I insulate the door with to stop it from heating up my warehouse? I had planned on expanded Styrofoam sheets from Home Depot. Any suggestions?
You need to show the type of door. You mention sheets, so I suspect it could be a sectional door. If it's a corrugated roll up, you won't be using the sheets and keeping the door operational.
That being said, a large door that opens slowly with an endless chain loop could hardly be considered a fire egress door.
There are 2 types of insulation that pertain to your situation. Conduction and convection. Sealing the edges against air movement is the latter. I assume you are interested in the former.
Two ways to do that as I see it. Your way with the foam sheets, or you could hang a soft barrier outside of the door to reflect the heat away from the exterior surface. The 2nd method will allow the door to be used if needed w/o any difficulty.
One of those silver faced tarps would be perfect for the job. Just make sure some air can circulate behind the tarp between it and the door surface.
Old 04-20-2010, 02:14 PM
