Need Computer Advice - Word & Vista
For some reason, after installing Microsoft Office 2003 on my friends new Vista computer...everytime we access Word or Excel or Outlook, the computer prompts to accept the license agreement (Every Single Time).
Is there a setting that needs to be checked that will eliminate this annoying step. We've accepted hundreds of times now & enough is enough.
Thanks.
Old 04-24-2010, 12:03 PM
Scott R's Avatar
Did you activate it?
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 04-24-2010, 12:16 PM
Formerly reformed
+1
It should ask you to activate the software when you first open it. Just inputting the reg info doesn't work.
1968 911P (Paperweight)
Old 04-24-2010, 12:30 PM
Unfortunately, I don't know. My friend did the install. However, to my knowledge, you have to install the key code at the very beginning to begin.
Now, when you open the program, it asked if you accept the license agreement. We click yes and the program works fine - until the next time you use it. Then, it pops up the same license agreement question.
Is there a way to activate the program from this point or should I uninstall and start over?
Old 04-24-2010, 12:55 PM
Scott R's Avatar
It's on the "help" menu in any of the office products. "activate products"
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 04-24-2010, 03:20 PM
3.4 Bigger is better
88-diamondblue's Avatar
You may need to run the program as administrator or log in as administrator and try starting the program. On software install with Vista admin mode is recommended. Program updates are best done logged in as administrator as well.
Michael
88 911 Diamond Blue CE Carrera 3.4 HC3.4 member
2020 Honda Passport
Old 04-24-2010, 07:31 PM
Get rid of vista.....
Old 04-24-2010, 10:42 PM
