AutoBahned
RWebb's Avatar
another garage door question - what opener?
my cheapo chain drive Genie GD opener conked out
what should I get?
Chambers seems good, BUT I have a bunch of the Genie Intellicode remotes + a keypad on the wall outside... maybe $150 worth of remotes etc.
should I get another Genie model? If so, which one?
thx all.
Old 05-18-2010, 05:13 PM
jyl jyl is online now
jyl's Avatar
How does this work into the biological weapon? Bomb bay door?
Old 05-18-2010, 08:38 PM
3800 - DC Motor Residential Jackshaft Opener
1987 Carrera
Old 05-18-2010, 09:25 PM
+1 to radioactive.
That is what I use. I was able to keep my same outdoor keypad from my old opener.
Old 05-18-2010, 09:32 PM
1980 911 SC
I've had a Genie shaft drive for more than 10 years and still works well. Quiet too. Installed another one at a second property last year.
Is the problem with the chain drives the fact that the chain will stretch and jump track?
Life's a Beach
Old 05-19-2010, 09:38 AM
AutoBahned
RWebb's Avatar
not sure; the chains are noisier tho
I pulled mine apart & could never figure out exactly what was wrong - it was definitely cheaply made & hard to work on...
Old 05-20-2010, 11:55 AM
NASA instructor
bornrich's Avatar
My Genie shaft drive burned itself out literally after about 14 years use. I replaced it with a chamberlin belt drive. Mucho quiet and was an easy install
Matt Rich
1999 Porsche 911 Zeniith Blue
1999 BMW 540i
2011 BMW 535i
Old 05-20-2010, 04:01 PM
Zeke's Avatar
Better check with your local garage door dealer about the old remotes and the new unit for compatibility. If they work together, I don't see how you could not get another Genie. I've got a 30 YO Sears and only one remote left. Nothing will work with it. I think it's so old that even the code busters can't open it. And, it's a chain drive. I keep it well lubed.
Old 05-20-2010, 04:30 PM
AutoBahned
RWebb's Avatar
which is better, a chain drive or a screw drive?
2 co.s install Genie's here - one co. does chain drive & the other does screw drive
the chain drive co. claims those are less maintenance than the screw drives - but my neighbor says screw drive is the way to go (he is non-specific as to why and not at all a 'technical' type guy)
noise is no biggie; vibration might be if it loosens the bolts...
thoughts?
Old 06-28-2010, 11:36 AM
pwd72s's Avatar
Screw drive seems to be the most recommended....whether it's better or not, I dunno. Ours has functioned well for years (can't remember how many) with the occasional application of lithium white grease to the screw. Oh...it's a Genie brand.
(edit) I would suggest a garage door with no windows...there is a not so cute video on the net about how to open a garage from the outside by using a long wire to unhook the opener's "power off" feature.
Old 06-28-2010, 11:41 AM
JavaBrewer's Avatar
Same story here. My 7 yr old Genie chain drive (installed by builder) died a couple weeks back. Local garage door company wanted $500 for a new belt drive unit installed. After a bit of research I went with a Chamberlin 3/4 HP belt drive. Came with 2 remotes, a key chain remote, and a wireless keypad for $225 at Lowes. I installed myself in ~ 4 hours and only reused the existing angle bracket hangers. Most of the time was spent routing/tacking the sensor wires in an attractive manner. Very very quiet movement compared to the chain drive it replaced.
Old 06-28-2010, 11:58 AM
Marantec. Super quiet. You wouldn't know if its on, but you wouldn't find it at Home Depot. The only complain is that its slow. 30% slower then others. Who the heck really cares. Great unit. I wouldn't put anything else in my client's home.
Old 06-28-2010, 12:22 PM
AutoBahned
RWebb's Avatar
thx for the info - already have the door etc. (will check on window security) - also opener has to be a Genie brand to match my remotes
Old 06-28-2010, 12:39 PM
pwd72s's Avatar
Just block the windows of your door if it has has windows. The technique I saw on the video resembles the use of a coathanger to pull up a car door lock. Bad guys need to look through a window for the technique to work. New openers should come with remotes.
Old 06-28-2010, 02:52 PM
